| Home > Help Needed / General Tech Chat > 4 pot calipers, just how good are they? | |||||||
11th Mar, 2011 at 08:29:40pm
At our club meet the other night i gave a few members a passenger seat ride in the mini, a bit of spirited driving was done just to show the performance as quiet a few where intrigued. Had to use the brakes fairly hard a couple of times, then noticed them getting more and more harder on the pedal and not pulling up as good, i originally put this down to lack of servo due to the boost, but when i pulled over into the car park, i could smell them seriously bad, even after a cool down they are not as good as they where, what could have happened to them? Brakes are minisport 4 pot alloy calipers with green stuff pads and drilled and grooved discs, could it be because the discs aint vented, just how much difference do vented make?
133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
11th Mar, 2011 at 08:33:59pm
i fitted a set of greenstuff pads to one of my cars probablyabout 7 years ago. it had 8.4 2 pot setup . took it for a good blast throught the lanes, when i got out there was a fair amount smoke coming from behind the front wheels?? the car was a standard non cooper spi. i never rated the greenstuff linings to be honnest, have reccently tried mintex1144 over the standard pads, and they make a world of difference
Edited by welshdan on 11th Mar, 2011. |
11th Mar, 2011 at 08:36:46pm
hmm.. so could be the pads mine are on a ten inch setup as well. 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
11th Mar, 2011 at 09:04:33pm
Brakes basically convert movement into heat. The more you move or the faster you move it the more heat is generated. At a given point it all gets too hot and stops working as well, which is why you have to push the pedal harder and harder.
![]() 611 Posts Member #: 5222 Post Whore Northumberland |
11th Mar, 2011 at 09:14:41pm
On 11th Mar, 2011 chinlesswonder said:
green stuff pads I would say thats your problem,I have had a few experiences of them and have always found them to be total shite. Cheers Ross. On 20th Jan, 2011 apbellamy said:
I have a bit of a fetish for tools |
11th Mar, 2011 at 09:19:09pm
yes, they're a big pile of wank, std ones are better IMO, On 28th Aug, 2011 Kean said:
11th Mar, 2011 at 09:25:19pm
Absolutely -green pads are well advertised rubbish |
11th Mar, 2011 at 09:31:28pm
keith for fook sake DUMP those green stuff pads Pronto!!!!
11th Mar, 2011 at 09:32:27pm
put green stuff on mine for the lakes Keith and they were wank. put Ferodo Premiums back on and new disks as the green stuff shite had bonded material onto the old disks. I put grooved discs on this time and at Coombe they were great again.
11th Mar, 2011 at 09:34:21pm
better bin mine before I do some damage then On 26th Oct, 2004 TurboDave16v said:
11th Mar, 2011 at 09:35:02pm
i have used greenstuff in the past and were crap didnt last long and destroyed my disks on the pug waste of money, i used mintex on the mini and now the pug, mini had trackday pads or something never faided once have std on the pug and they get a tad warm sometimes but still work well :) Drives
11th Mar, 2011 at 10:00:58pm
Double post Edited by hazpalmer on 11th Mar, 2011. |
11th Mar, 2011 at 10:06:17pm
yeh when i changed the pads on mine, i put in mintex M144 because i read green stuff were shite |
![]() 902 Posts Member #: 111 Post Whore Loughborough |
11th Mar, 2011 at 10:39:33pm
I had green stuff pads with metro 4ports kill them in a few laps of a track day. Mintex pads seem a much better. |
12th Mar, 2011 at 10:50:07am
mintex are the better ones. talk to tom at minisport. he also says the green stuff ones are shite. he reccomended some better mintex ones. only cheap too :) |
![]() 257 Posts Member #: 7048 Senior Member Bridgend |
12th Mar, 2011 at 02:43:13pm
I've got a standard metro turbo 4 pot vented setup on mine. With standard mintex road pads. I've done 2 trackdays, loads of spirited road driving and am yet to feel any fade with them. Turbo parts collector at the moment, almost ready. |
12th Mar, 2011 at 04:12:07pm
You may also have boiled your brake fluid a bit too, probably worth pumping some fresh through. On 11th Feb, 2015 robert said:
12th Mar, 2011 at 04:43:00pm
As Benross said, I use use cheap pads too on the Sprint, Apec if I recall. But, I bought my daily Mk1 with Greenstuff in S callipers and theyre great I seriously doubt it! |
13th Mar, 2011 at 08:49:07am
ive always heard of problems with greenstuff pads, my mate craig had some, they were absolute shite. The blackstuff are so much better imo, but i think ill try the mintex next time around as they seem to be a favourite On 26th Jan, 2012 Tom Fenton said:
![]() 558 Posts Member #: 8143 Post Whore London |
13th Mar, 2011 at 11:38:36am
Another vote for greenstuff being absolute shite, probably good on a track day where you can warm them up properly but no good for daily driving.
![]() 209 Posts Member #: 6451 Senior Member South East Northumberland |
13th Mar, 2011 at 01:50:26pm
Glad I read this - I've got bad disc warping after only 4000 miles. Guess what - Greenstuff! Last set of discs didn't last too long either. Time to change I guess. |
13th Mar, 2011 at 02:30:58pm
On 12th Mar, 2011 apbellamy said:
You may also have boiled your brake fluid a bit too, probably worth pumping some fresh through. A friend mentioned that too, says to use Dot 5 brake fluid over the standard stuff? are they much the sameness in brake feel?. 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
20th Mar, 2011 at 11:19:44am
Here is some interesting information on the Green Stuff pads.
20th Mar, 2011 at 12:07:37pm
When I was looking at pads for My wilwoods I looked at the frxtion info for various pads,
21st Mar, 2011 at 11:58:01am
These got my attention, but then I'm not sure if they fit standard mini calipers as I'm running ford stuff..
