| Home > General Chat > softer ride. | |||||||
![]() 902 Posts Member #: 111 Post Whore Loughborough |
30th Mar, 2011 at 09:56:22am
Hi Guys,
Site Admin 6297 Posts Member #: 1 The boring bloke who runs this place. Berkshire |
30th Mar, 2011 at 10:04:16am
For the record, my car is EXACTLY like this, with the same setup (Gaz + Hi-Los) and I was whinging about it just last night.
30th Mar, 2011 at 10:05:23am
The Gaz shocks are known for Seizing. Take one off and have a look. If something is worth doing, it's worth doing half of. |
30th Mar, 2011 at 11:03:40am
When i jack the car up all four wheels drop, does that indercate there ok? or do i really need to take them off to have a better look?
30th Mar, 2011 at 11:22:07am
Doesn't sound like they are seized then. Tried turning them down? If something is worth doing, it's worth doing half of. |
30th Mar, 2011 at 11:23:10am
Riding on the bump stops? Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
998 Posts Member #: 2178 Post Whore Leyland, Lancs |
30th Mar, 2011 at 11:54:31am
When you jack the car up, do the wheels drop very slowly? If so, you might have the dampening/rebound set too hard. I had issues with this on my Gaz - I thought I'd only stiffened them up a few clicks, but it went from quite hard ride, to teeth shattering. I wound them back out a bit and the car is supple enough not to break teeth, but stiff enough not to roll too much.
a breif struggle ensued but Will emerged the victor with a pair of undies in his possesion On 21st Sep, 2009 apbellamy said:
No, but you did chuck your guts up over my front gate the Saturday before! You even managed to get a bit in your arm pit... |
30th Mar, 2011 at 12:04:48pm
Mine are on the softest setting - still too hard for my liking! |
30th Mar, 2011 at 12:19:42pm
Your springs may have gone hard.
30th Mar, 2011 at 01:03:04pm
Similar to an Elise then i suppose - they are always a bit crashy. |
30th Mar, 2011 at 01:11:29pm
abits fine, but relieing on the harness to keep me in the seat over and man hole cover is abit much. I'll have a play around to night.
30th Mar, 2011 at 01:24:36pm
Mines like this. Same setup.
In the 13's at last!.. Just |
30th Mar, 2011 at 03:09:00pm
i have my gaz shocks on 3 clicks at the front and softest on the back . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
30th Mar, 2011 at 04:29:31pm
iv got gaz and orginal dohnuts its dosent seem too hard bit bouncy maybe on a crap road but there set at bwt 10 alround Done now needs redoing lol |
30th Mar, 2011 at 06:40:30pm
I was always under the impression that the softest setting was similar to a standard damper so you should start from there. Set them all to soft and go for a drive. Adjust 2 clicks harder all round at a time and go for another drive. keep doing this untill it's 'uncomfortable', then back off 4 clicks, if that takes you back to the softest setting, so be it, job done. there is no need for 28 or 32 settings on a road car! double upthe clicks and halve the problem On 26th Oct, 2004 TurboDave16v said:
30th Mar, 2011 at 07:21:42pm
Sounds like you have been driving modern cars too much :)
![]() 257 Posts Member #: 7048 Senior Member Bridgend |
30th Mar, 2011 at 07:33:33pm
Mines the same and is too stiff. I think a set of new doughnuts might help me because mine are squished right down. Turbo parts collector at the moment, almost ready. |
30th Mar, 2011 at 07:43:22pm
Mine is looovly with its red dot cones, gaz's on 3-4 rear and 5-6 front.
Edited by Joe C on 30th Mar, 2011. On 28th Aug, 2011 Kean said:
![]() 667 Posts Member #: 5232 Post Whore basingstoke |
30th Mar, 2011 at 07:45:33pm
I spent ages hating the ride in my mini, I've got Gaz coilovers, and had them set at 20 clicks rear and 28 front, thinking hard way the way forward for a fast road setup. I had a hateful ride and sodd all grip from my a032r's.
Mr. Prawn, the friendly Crustacean- slowly making steps towards forced induction. |
30th Mar, 2011 at 08:45:22pm
Pah... What you lot need it Hydro. I run a supercharger and I don't care the TB is on the wrong side.
30th Mar, 2011 at 08:55:30pm
On 30th Mar, 2011 gr4h4m said:
Pah... What you lot need it Hydro. I have a spare set of rear progressive bump stops for one of those. Helps stop body roll. lol On 26th Oct, 2004 TurboDave16v said:
30th Mar, 2011 at 09:30:15pm
Already got them on. but the rears are starting to look a bit beat, the lip on the body cuts into them I run a supercharger and I don't care the TB is on the wrong side.
30th Mar, 2011 at 09:46:23pm
Already got them on. but the rears are starting to look a bit beat, the lip on the body cuts into them Check the for sale section
181 Posts Member #: 9072 Advanced Member Jersey, Channel Islands |
30th Mar, 2011 at 09:54:01pm
I have no experience as new to the Mini scene but would it be an idea to change the rubber cones for some coil springs? I was reading a Mini mag the other day (not sure which one), but it mentioned about better ride quality and how to fit them.
Speed doesn't kill, suddenly becoming stationary, now that's what'll get ya! |
31st Mar, 2011 at 07:34:57am
What company is it that sells them stubby spring that go in place of the rubber donuts?
