| Home > Help Needed / General Tech Chat > problem still there =( | ||||||
![]() 281 Posts Member #: 441 Senior Member |
20th Mar, 2005 at 11:53:33pm
changed the head gasget and all seems fine,except it still wont go over 90mph!!! sounds like its miss firing and wont go any faster. what could be causing this?? could it be timing not advance enough??? |
450 Posts Member #: 449 Senior Member Oxford |
21st Mar, 2005 at 12:00:24am
sounds like an igntion fault, could be one of many things.
21st Mar, 2005 at 01:22:48am
Rolling Road session needed I think.
21st Mar, 2005 at 08:45:35am
yeah i just thought id take it up to 90 to see if it still does it
21st Mar, 2005 at 08:47:44am
do you know where i can get hold of an ignition module? and how much? |
21st Mar, 2005 at 09:45:21am
from hellfords easy enough, about ?30 i reckon |
21st Mar, 2005 at 10:16:03am
?30 for that little thing! has anyone got a spare floating about?? i dont wanna spend ?30 on onw and it turns out to be something else |
21st Mar, 2005 at 10:33:05am
never know if a 2nd spare is any good though.... |
21st Mar, 2005 at 11:27:00am
I can test ign modules...
AlexF |
21st Mar, 2005 at 11:33:09am
does this sound like it could be the module then??
21st Mar, 2005 at 11:37:37am
oh yeah dunno if this means anything but im running a live off the fuse box for the coil and removed that pink one as it made it missfire,standard coil.
21st Mar, 2005 at 08:56:21pm
No that wont fuck it up, rolling road will tell you if its faulty though. Trust me its well worth the money if you get your car totally checked everywhere, it unlocked 111bhp for me on a standard turbo engine! The guys on here are never wrong.
21st Mar, 2005 at 09:35:57pm
standard coil as in 'standard metro' or 'standard mini' coil? On 17th Nov, 2014 Tom Fenton said:
21st Mar, 2005 at 10:13:18pm
stuart gave it me,a black coil.original one.
21st Mar, 2005 at 11:14:46pm
not sure, from what i've been told about the modules they just break down, mainly when under load but seem fine at idle/ On 20th Oct, 2015 Tom Fenton said:
22nd Mar, 2005 at 08:18:06am
thats what i mean,sems fine in every gear at any revs,until you hit 90mph.
22nd Mar, 2005 at 08:59:24am
come on guys whatd you reckon?
![]() 2102 Posts Member #: 432 Post Whore Swindon |
22nd Mar, 2005 at 09:38:45am
just go down to halfords, buy 1 for 30 squid, fit it. and if that does fcuk all put it back in the box and say it was the wrong 1!
Edited by Mini_Andy on 22nd Mar, 2005. |
22nd Mar, 2005 at 10:07:01am
if it only does it at 90 mph, indicates its more of a mixture problem. The increasing load with each gear will be demanding more and more fuel/air.
22nd Mar, 2005 at 10:11:41am
oh just a check that can cause problems check the vacuum advance/retard pipe is connected to the carb/dizzy. If it is check there are no holes in it, can cause prolems with timing and the fuelling Edited by mikemph on 22nd Mar, 2005. |
22nd Mar, 2005 at 10:34:50am
right,im thinking its the fuel pump,or regulator.
22nd Mar, 2005 at 10:36:55am
fuel pump should be on consant, check the power and earth to the pump On 15th May, 2009 TurboDave said:
22nd Mar, 2005 at 10:39:05am
spi and mpi's come as a different part number but not sure whether the interfaces are the same.
22nd Mar, 2005 at 10:42:19am
also takes a few goes to get it started sometimes,even when warm,then slowly starts,and you gota rev it up so it ticks over nicely
22nd Mar, 2005 at 10:49:19am
that the pump is picking up air and not just fuel. thats why the pumps tend to sound funny.
works for me.
