| Home > Help Needed / General Tech Chat > Manifold gaskets anyone seen this before! | |||||||
24th Apr, 2011 at 07:06:27pm
I was pissing about the car today and I seen that there was some smoke coming from the manifold on start up and this is what I seen.
![]() 864 Posts Member #: 951 Post Whore Bromsgrove |
24th Apr, 2011 at 07:20:39pm
I was warned off using this type of manifold gasket,cheap but not cheerful.Now I see why.I would stick with the original type,often on ebay,about £12 plus p&p,but worth it. 'Where does the engine go?' |
24th Apr, 2011 at 07:34:17pm
Have you got any links mate. I have started posting on Instagram also my name on there is turbomk1golf
24th Apr, 2011 at 07:45:31pm
http://www.minispares.com/Product.aspx?ty=...id=38056&title=
24th Apr, 2011 at 07:48:50pm
I have just been looking at them.
24th Apr, 2011 at 07:49:22pm
Composite gaskets will de-laminate like that where they are not trapped/compressed properly.
24th Apr, 2011 at 07:55:51pm
I was thinking that is where the problem is Rod I cannot get the full washers in there as it’s too tight! I have had to grind a spanner down a bit to get in at 2 of the nuts. I have started posting on Instagram also my name on there is turbomk1golf
![]() 296 Posts Member #: 9117 Senior Member Northampton |
24th Apr, 2011 at 08:09:06pm
hi madmk1 the inlet flange on the inlet looks thinner than the exhaust flange this will result in sealing problems, good luck hope u can sort it Confessed addiction to everything mini |
24th Apr, 2011 at 08:19:51pm
You want the paper type with metal rings on the exhaust ports. I used to get no end of hassle with the other style of gasket! |
24th Apr, 2011 at 08:19:52pm
549 Posts Member #: 5327 Post Whore Dudley, West mids |
24th Apr, 2011 at 08:24:03pm
As above. I've never had a problem with them. |
24th Apr, 2011 at 08:44:54pm
I used the same as Ron, but as also said above the flange on the inlet and outlet look different thicknesses, and could be a contributing factor.. |
24th Apr, 2011 at 09:03:10pm
On 24th Apr, 2011 boostjunkie said:
hi madmk1 the inlet flange on the inlet looks thinner than the exhaust flange this will result in sealing problems, good luck hope u can sort it Right then, I just have been out and got it off and its bad, as for the inlet flanges, they have been welded to build them up the same as the outlets so they should been fine. I think I will need to find some Locating Rings for the inlet flanges. Also see if I can fit the big washers on there but I will have to dent the manifold to get the nuts in.:( I have started posting on Instagram also my name on there is turbomk1golf
24th Apr, 2011 at 09:16:20pm
This one Ron.
On 24th Apr, 2011 gr4h4m said:
http://www.minispares.com/Product.aspx?ty=pb&pid=38056&title= I use one of these suckers but then I don't run a turbo I have started posting on Instagram also my name on there is turbomk1golf
24th Apr, 2011 at 09:31:00pm
That one I use is steel backed and has the crush rings for the exhaust ports. I love them. I run a supercharger and I don't care the TB is on the wrong side.
24th Apr, 2011 at 09:32:12pm
I've used the layered metal type, as in your picture, for years & never had an issue at all. |
24th Apr, 2011 at 11:39:57pm
I have found the type of gasket you use total shit, In my experience they last ten minutes at best.
24th Apr, 2011 at 11:46:38pm
On 24th Apr, 2011 wil_h said:
I have found the type of gasket you use total shit, In my experience they last ten minutes at best. I use this type and have never has an issue i cant find one any where mate, I have been looking all night. I have started posting on Instagram also my name on there is turbomk1golf
24th Apr, 2011 at 11:53:03pm
Maybe try a wanted add and promise to replace when they come back in stock. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
24th Apr, 2011 at 11:56:05pm
I may have to mate, I am not to keen on ebay as I am not to sure what I am looking at lol I have started posting on Instagram also my name on there is turbomk1golf
25th Apr, 2011 at 09:29:09am
I've probably got a good used one in the garage if you are struggling.
In the 13's at last!.. Just |
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
25th Apr, 2011 at 09:32:37am
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
976 Posts Member #: 3228 Post Whore North of the Netherlands |
25th Apr, 2011 at 10:41:04am
A bit of a hi-jack, but anyone know how big is the diameter of the holes for the inlet ports on both MS turbo and injection gaskets are? Dazed and Confused.... |
25th Apr, 2011 at 04:07:32pm
i dont use any gasket . simon, just something i noticed , you may want to try and stop that inlet flexi pipe melting ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
25th Apr, 2011 at 04:20:49pm
On 25th Apr, 2011 robert said:
i dont use any gasket . simon, just something i noticed , you may want to try and stop that inlet flexi pipe melting ? So none at all mate, as for the flexi pipe its way off mate its just the way the pic is. I have started posting on Instagram also my name on there is turbomk1golf
