Home > Help Needed / General Tech Chat > what needle
t3gav
Member #: 229
Gavin@minispares.com
kent
ok started playing with my car today ready for the rebuild aiming for the famous 200bhp break, and was wandering what i should do to my carb, i notice avonbar do a 12 psi needle is this the same needle used for 20 psi or is it modified any other comments on carbs would be great also.
You're not going to be able to buy a needle off the shelf. Every engine varies dependent on cam choice, timing, compression, boost etc etc. Every modification will make a difference to the needle profile. Your going to have to build your engine and get along to a decent rolling road with an operator who really know A-Series Turbos and knows how to set-up an SU.
Good luck. *smiley*
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
In kent... try Sanspeeds (iirc)
Alex
AlexF
jamesfawcett
Member #: 218
Bingley, West Yorkshire
I was lucky to get quite an accurate one from avonbar for mine, but will be different if i say, fit a larger head.
Mine does overfuel a hell of alot at 3,200 rpm though, its always driven below that though.
t3gav
Member #: 229
kent
cheers guys is there any other upgrades i should do while the carb is off, can they be rebuilt bearing there sealed units never got that bit
yes they can, i have rebuild kits in stocks with new bearings, seals, shafts and a plain butterfly so that dump valve works correctly
*smiley*
pm me if you want one.
I also wrote a guide on how to do it, in the "HOW TO" section I believe.
using one of my kits *smiley*
its all genuine SU stuff
Shameless plug Iain.....!!!!!!!!!!!!!!!
I get special privileges *happy*
worth plugging though, great parts at great prices *smiley*
t3gav
Member #: 229
kent
cool just waiting for me student loan he he the i'll order one
Shameless Plug 2!!!!!!!
And if you read my guide to carb rebuilding there is Shameless Plug 3 in there (on your behalf!!)
what shameless plug? the one about the carb rebuild kits i sell? *happy*
Do you sell those? Blimey now theres a useful bit of info......
Anyone know where I can get a carb rebuild kit from?
T3Tone
Member #: 252
Sunny suffolk
I remember iain saying on here that he sells them dave!
-MINI CLUBMAN 1380 TURBO-
Iain, as in Iain off www.turbominis.co.uk sells Carb rebuild kits?
Jeez, why didn't anybody mention this?
I'll get one ordered right now. *laughing*
*happy*
chominsh
Member #: 8160
, mitcham, surrey, london, cr4
*smiley*
hi
do you still have carburettor rebuild kits?
what exactly is there?
and how much you want for it?
thank you
Nothing special!
turbo hogster
Member #: 178
stowmaket suffolk
just use a b needle gav then get it to the rollers mate that way she will be good for the emmision test
turbo hogster
Member #: 178
stowmaket suffolk
about bloody time gav, oh buy the way the new clutch arms are bloody good but you need to look at the angle agai i think its to close to the bell housing thus loosing some throw, every thing else is new and at times can be a bit crunchy through the gears especially when doing quick gear changes
i think he will be sorted by now hoggy *wink*
turbo hogster
Member #: 178
stowmaket suffolk
i dount it its gav we are talking about lol
EssexSteve
Member #: 7029
Wickford Essex
will the carb be good enough for 200 bhp?
Steve
It's been proven over 300hp. Ask mr Williams.
