Home > Help Needed / General Tech Chat > Roof Liners
Zeemax Power
Member #: 393
Oulton Park
Who Likes Fitting Roof Liners
Yes NO!!2 Votes 2 Votes - 0%
http://www.Zeemax.com
Zeemax Power
Member #: 393
Oulton Park
hate them fucked two now never touch factory finish stuff
if its all fitted correctley and you have some slightley baggy corners
get a kettle and STEAM these to tighten them up
i used to do this in the 70s
that was the way then and still is on minis
go carefully and make sure you DONT scalled yourself!
nogin
Member #: 487
westbury, wiltshire
dont think it works on the new roof liners the steam trick that is as different material now used eg fire retardent stuff,
"Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
i also make things
i love coming home to chrome
jamesfawcett
Member #: 218
Bingley, West Yorkshire
Gonna get me a black one.
Do they have interior light holes already cut? I dont want one
b16_b
Member #: 429
newcastle upon tyne
if you aint got one is it really noisy? was hoping to get a england flag sprayed on the inside eventually! proud to be brittish! (me be rare soon if they keep shipping them in)
Zeemax Power
Member #: 393
Oulton Park
your alright mate they come as a sqaure piece of material and what ever you do don't cut it at all off the car!!! i cut it ruffly the same as the old one with a bit over (BIG MISTAKE)!!!!
Might as well of shucked my money away
what you lads stick the edges with i've been using super glue
minimark
Member #: 19
newcastle
spray glue , onto both car , and cloth
1) Buy around 75 of those little bullbog clips from staples/partners/wherethefuckever.
2) Fit rods into new headlining and suspend (make sure you have rods in the correct order, front to back).
3) Fit headlining rods up into the correct holes.
4) Starting at the front centre or rear centre ,pull the headlining so the rods are upright, not cocked over. Put a few clips on to hold it.
5) Pull at the rear and secure with clips.
6) Now stick your head in through the side, and you'll see that the folds in the lining that the rods run through are pulling at the ends. Take a knife and put a cut along the fold, which will allow the ends of the folds to fall away from the rod, and make the side-fit a lot better...
7) Pull&clip the drivers/pass sides around 2" either side of the 'B' pillars
8) Go round the whole car, pulling and clipping. If neccesary, trim off the excess so you have around 2-3" to 'play' with...
9) repeat step 6 as appropriate
10) Get it as tight as you can, and leave it overnight
11) Come back to it and re-pull/clip it to get it tight as possible.
12) Creases/loose bits are sorted with the wifes/mums hairdryer. Gently heat the material AROUND the offending area, then quickly re-pull and clip to remove the creases.
13) Leave overnight again (i'm sure there are lots of other jobs you can do in the meantime?)
When you return - If you feel the need, use the hairdryer to heat, pull and re-clip again.
14) Once happy with the fit, trim off the excess using scissors.
15) Now get some Evo-stick contact adhesive, remove one clip at a time, apply to both surfaces, wait for the adhesive to set, then pull and stick the lining to the door/windo surround.
16) Repeat 60-70 times (depending on how many clips you have)! As you confidence grows, you may find it possible to glue/stick 3-4 clips at a time...
That's the hard bit done!
Remember to poke the wires through for the interior light.
I fitted the minispares 'black' headlining around four months back. Was pretty easy - just time consuming, but the results were perfect; A really tight, ripple free headlining. The rear corner pieces (between the rear window and side windows) were pants however. I ended up removing the black cloth off the backing board, re-cutting the backing board to size, then sticking into place.
Kean
Member #: 341
aka T2clubby
South Staffs
LOL *happy*
Are you some sort of football thug? :$
If you haven't got any clips available to hold the headlining in place while fitting it, then just cut an old side rear window seal into pieces about 1.5" long and use these to hold it in place.
Phil. *smiley*
my clips cost ?4 for a packet of 30 from staples. Much easier than trying to cut up a rear window seal IMO - but good tip for the pikeys amongst us...
Edited by turbodave16v on 29th Mar, 2005.
dave you missed step 17
17)get dumped by girlfriend for not seeing her all weekend, and prefering to spend time with the car than her
thats what happened to me
if she's that petty, you're better off without her!!
i'm getting hassle from my fiancee for NOT spending enough time on the car!!
ha ha, wish i got that sort of hassle! i just ignore her now and go in there anyway!!
mikemph
Member #: 449
Oxford
i fitted mine with out any hassle took about 5 hours tho. I would recormend using evostick
Nik,
The car I fitted the headlining into, along with the vauxhall engine, rollgace, new sills, recaros, etc, etc is also (now) my ex...
thats it then, i'm never fitting a headliner!
Good plan.
Get your missus to do it whilst you go the pub to watch the match.
jamesfawcett
Member #: 218
...yes it is ALOT louder without a headlining, you can also hear every drop of rain! I didnt have one for first year of driving my mini with the 998cc *tongue*
Im going to do mine soon
AllanMcD
Member #: 414
Dalbeattie Scotland
I lined my whole van with carpet it was easy I used carpet spray glue the whole job was pretty cheap and looks pretty good and keeps the noise down.
http://www.rabdunn.co.uk/
stupid women
Zeemax Power
Member #: 393
Oulton Park
at the end of the day lads its of them jobs that i hate tip for you don't cut to size off the car. don't pull the liner to tight don't glue with super glue cos you can't get the windows in the rubbers next one i brought is black not sure whats its going to look like but the other one got so dirty trying to put it in this seemed a safer idea
not sure how I'm going to get headlining to fit
