| Home > Technical Chat > Actuator Options | ||||||
20th May, 2011 at 08:18:28pm
Just wondered what actuators people are using for 20-25 psi boost.
20th May, 2011 at 10:40:57pm
that should do .... itll be about 1,3 bar id expect ,so about 20 psi , then bleed it a bit for your boost level ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
20th May, 2011 at 10:44:15pm
Thanks Robert. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
20th May, 2011 at 10:53:25pm
Waste... gate....? On 28th Aug, 2011 Kean said:
21st May, 2011 at 09:07:06am
So we can read this as being gauge pressure then:
21st May, 2011 at 09:16:49am
On 20th May, 2011 Paul S said:
Just wondered what actuators people are using for 20-25 psi boost. We have the standard actuator for the Gt2056 which is probably only rated for 6-8 psi. The spec quotes "1.280 - 1.420 bar = 4.00 mm" 1.28barA is 4.116psiG and 1.42barA is 6.174psiG So 4mm preload should equate to 4psi start to open and 6psi full open? On 26th Oct, 2004 TurboDave16v said:
21st May, 2011 at 09:50:32am
No, because the actuator is a proportional modulating device, not an open/closed switch.
21st May, 2011 at 09:54:53am
For example, the Gt17 actuator is quoted as:
21st May, 2011 at 10:55:28am
Ah right so the stock setting on the GT20 is 18psi?
21st May, 2011 at 11:12:37am
On 21st May, 2011 Sprocket said:
How do you intend to run lower boost? That is a very good question! We don't fancy going straight to 18psi (or more), 12psi would be a good starting point. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
21st May, 2011 at 11:36:06am
I'm glad that this thread has popped up. I've been experiencing an odd boost issue at anything over 15psi. Instead of boost climbing smoothly, it fluctuates before contiuing to climb. I was wondering if either the actuator was struggling or my bracket was flexing at higher boost.
In the 13's at last!.. Just |
21st May, 2011 at 11:39:34am
If you do not set enough preload, then the pressure in the turbine housing will force the wastegate open.
21st May, 2011 at 10:53:13pm
Pull the pipe off the actuator and you'll soon see how much boost it's capable of making on the standard actuator.
22nd May, 2011 at 06:01:31am
Pull the pipe off the actuator and block it, maybe, or wont you get uncontrolled boost if the actuator is just disconnected ?
22nd May, 2011 at 09:48:29am
You're not wrong Dave.
22nd May, 2011 at 10:39:30am
http://www.dtsturbo.com.au/751578_dash_500...plied%29/pd.php
22nd May, 2011 at 11:00:29am
On 22nd May, 2011 tadge44 said:
Pull the pipe off the actuator and block it, maybe, or wont you get uncontrolled boost if the actuator is just disconnected ? Please tell me if I am wrong - I often am. uncontrolled to a point, the wastegate itself can get blown open by the exhaust gas pressure, if the actuator is to weak this can limit boost even if the actuator feed hose is disconected. This issue limited me a while back, and as stevie pointed out, didnt become apparent till i ran with the actuator hose disconnected! turbo 16v k-series 11.9@118.9 :)
22nd May, 2011 at 11:02:11am
Gary...... NO! On 28th Aug, 2011 Kean said:
22nd May, 2011 at 11:09:00am
No what?? lol
22nd May, 2011 at 11:14:21am
we both know once that pipe comes off, theres no way it'll ever go back on LOL On 28th Aug, 2011 Kean said:
22nd May, 2011 at 11:14:55am
I thought 2056 acutator was 15-16 psi like sprocket says. I have one on my 17 it did 12psi. Probably weakend over time 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
22nd May, 2011 at 11:17:34am
On 22nd May, 2011 Joe C said:
we both know once that pipe comes off, theres no way it'll ever go back on LOL In the 13's at last!.. Just |
![]() 667 Posts Member #: 5232 Post Whore basingstoke |
22nd May, 2011 at 11:22:06am
Pull the pipe off the actuator and block it, maybe, or wont you get uncontrolled boost if the actuator is just disconnected ? Please tell me if I am wrong - I often am. In theory tadge, you're totally right, assuming a fully working actuator. However, if the actuator spring has gone weak, then the pressure in the exhaust housing will be able to overcome the actuator spring holding the gate closed, and force it open, thus limiting boost in a different way Mr. Prawn, the friendly Crustacean- slowly making steps towards forced induction. |
22nd May, 2011 at 11:39:06am
Yep,
22nd May, 2011 at 10:46:10pm
it isnt pressure x area.
