| Home > Help Needed / General Tech Chat > k1200 head: worth the hassle? | |||||||
160 Posts Member #: 1085 Advanced Member Netherlands |
24th May, 2011 at 08:25:41pm
A question to those who've been there and done it: is fitting one of these worth all the trouble, compared to just sticking to a 5 port head? Just wondering since I've found a K1200RS head locally (albeit way overpriced at 500 euros). I still haven't completely decided which way to go, but the base will be the (ex-Prawn) Mpi block with the 18cc accralites and a GT1752. The way I see it getting the 5 porter on injection is going to be a pain, but fitting a K head is not easy either (but looks wicked :)
1963 Cooper
282 Posts Member #: 1404 Senior Member The Netherlands |
24th May, 2011 at 08:55:04pm
All i can say is that a 5 porter turbo is fun enough for me.
there is nothing wrong with a A-series that a turbo can't fix.
1391 Posts Member #: 1686 Post Whore Oxford |
24th May, 2011 at 09:49:32pm
Personally the extra control the 16v head provides is undeniable. Yes this control can be had from a 5 port with siamese port injection for example. However its a bit of a faff really given no parts are "off the shelf"
OMG Robert that's a big one |
24th May, 2011 at 10:26:17pm
the 2 main reasons amoungst others for me are.
Edited by minimole23 on 24th May, 2011. On 7th Oct, 2010 5haneJ said:
24th May, 2011 at 10:29:51pm
Mine is great fun, drives completely different to a 5 port. It is alot of work, more than just bolting on a conversion kit, especially if you go down the turbo route. But if you enjoy a challenge, then it will certainly give you one! Edited by matty on 24th May, 2011. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
547 Posts Member #: 2928 Post Whore peterborough |
25th May, 2011 at 12:03:33am
On 24th May, 2011 matty said:
Im running around 9:1 and it'll run 25psi even on 95RON fuel. :) Sorry for not having a valuable input here but, matty, I had no idea that amount of boost could be used with cheap fuel and that high compression, out of interested how much power are you getting from your current engine spec? Jack Jones |
25th May, 2011 at 10:17:58am
thanks for the replies sofar guys :) 1963 Cooper
25th May, 2011 at 10:23:19am
Once the engineering bit is done, its just like any other engine to build and rebuild. and once you sort the packaging into the car out, you'll reap the benefits later. I don't think any one will tell you its easy, but its only hard at first, like most things. On 26th Oct, 2004 TurboDave16v said:
976 Posts Member #: 3228 Post Whore North of the Netherlands |
25th May, 2011 at 11:10:44am
And it has been done some times already; a lot of lessons have already been learnt..
Dazed and Confused.... |
25th May, 2011 at 05:06:26pm
Are you aware of the EFI mini`s website? chuck edi minis into google should bring it up.
25th May, 2011 at 08:28:16pm
Im running around 9:1 and it'll run 25psi even on 95RON fuel. :) Sorry for not having a valuable input here but, matty, I had no idea that amount of boost could be used with cheap fuel and that high compression, out of interested how much power are you getting from your current engine spec? Neither did I until that bad influence wreckless driver Robert convinced me it wants more boost.
It was 155bhp at 10 psi on a 8.4:1 CR , no idea what it at now with the new turbo higher CR and boost... https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
25th May, 2011 at 08:40:05pm
CR isn't a problem really, don't forget you can use a higher CR with the K head because of its design. Im running around 9:1 and it'll run 25psi even on 95RON fuel. :) I have been toying with using my existing 1380 engine as a base (As to date its covered 55 miles), and on that basis I reckon I can get away with 15psi on 9.5:1 - though I'll stick with the v power fuel. Decisions decisions! Edited by minimole23 on 25th May, 2011. On 7th Oct, 2010 5haneJ said:
25th May, 2011 at 09:12:34pm
I generally stick to V power, and thats what I mapped it on, but on long runs it gets kind of expensive!
25th May, 2011 at 09:25:12pm
I've gotten the bug I guess. That is to say I picked up a K1200RS/GT head tonight. Initially the seller wanted 500 euros, but when I explained what the plan was he got so enthousiastic I could pick it up for 175 (albeit without cam cover or TB's, but I'll worry about those later). It came off a police bike that threw a rod at 27k miles, but appears to be undamaged. Edited by Arnoud on 25th May, 2011. 1963 Cooper
25th May, 2011 at 09:40:29pm
Matty we need to get together some time and seriously upgrade the firmware and software for your ECU. Many many excellent changes available On 26th Oct, 2004 TurboDave16v said:
25th May, 2011 at 09:42:38pm
On 25th May, 2011 Arnoud said:
I've gotten the bug I guess. That is to say I picked up a K1200RS/GT head tonight. Initially the seller wanted 500 euros, but when I explained what the plan was he got so enthousiastic I could pick it up for 175 (albeit without cam cover or TB's, but I'll worry about those later). It came off a police bike that threw a rod at 27k miles, but appears to be undamaged. Get the cam cover if you can, unless its damaged, they are not freely available second hand, and cost about £120 new
25th May, 2011 at 09:54:15pm
I have updated it to the 93 version, is there another new one available? lol
25th May, 2011 at 10:07:10pm
On 25th May, 2011 Sprocket said:
Get the cam cover if you can, unless its damaged, they are not freely available second hand, and cost about £120 newI know. he had it available, but wanted € 110 which seemed a bit steep to me and I just didn't have it on me at the time. He told me the cover gasket is another € 50 from BMW! I'll try my luck elsewhere first; if I fail I can always get back to him; he's breaking these on a regular basis. 1963 Cooper
25th May, 2011 at 10:10:48pm
cover gasket costs naff all, certainly not 50 euros On 26th Oct, 2004 TurboDave16v said:
25th May, 2011 at 10:18:42pm
When you add the cost of cam cover bolts and seals it soon adds up though!
25th May, 2011 at 10:19:59pm
trouble is its the cab covers that get it if the bike is dropped. On 28th Aug, 2011 Kean said:
25th May, 2011 at 11:39:42pm
On 25th May, 2011 matty said:
I have updated it to the 93 version, is there another new one available? lol I still haven't managed to get the vemstune working though, which is annoying.
I need you to come and have a look, and wave a magic wand to get my oil leak fixed before Avon. :) Latest version vemstune available for download from http://vems.hu/vt/ Before you do anything with the your current set up make sure you back up all your configs in Megatune AND more importantly download the configs using the bat files first. Then use vemstune to also download config. Vemstune config format is different. 1.0.93 is a completely different animal to 1.1.88. you will find lots of things you will have never seen before. don't expect them to work without tweaking. Loads of help files throughout. At least have a look over it and familiarise yourself with it. Just don't get yourself into bother. I have no problem driving down to help you, just not right now
Use F1 key in config windows and the main help files in the tool bar. 1.1.88 is the latest stable firmware. Use the web tool to download and install the firmware, then you can open the default config file and have a browse around. On 26th Oct, 2004 TurboDave16v said:
25th May, 2011 at 11:43:37pm
Thread hijack
by all means :) 1963 Cooper
27th May, 2011 at 08:07:57am
i have to agree with what has been said, the build especially if you do it yourself is hard work and can be time consuming. i have made a few mistakes, but this is how you learn. glad to see you have gone with the bmw conversion, i am confident that you will not be disappointed. |
27th May, 2011 at 02:29:17pm
On 27th May, 2011 philc said:
i am confident that you will not be disappointed. thanks Phil :) I've found a K1100 valve cover for 40€, so at least the cams won't go rusty while I gather the rest of the stuff I need. I take it there's no drawings of the front plates somewhere on the web, or maybe someone who has given up and willing to sell their kit? (can't blame me for trying, right?
The first quote for dry decking the head was €150-200... in no hurry tho (my mini pick up is still at the shotblaster's). I have nothing but respect for those who built those spaghetti style manifolds for fitting the turbo, but wouldn't a "mirage" type item work too? sure, it may not be as efficient or handsome looking, but it's a lot less work and underbonnet heat would be reduced quite a bit? 1963 Cooper
