| Home > General Chat > Mini exhausts | |||||||
30th May, 2011 at 09:58:04pm
Why are they so loud?
30th May, 2011 at 10:02:01pm
I don't think they are that loud, just the car has bad soundproofing. Plus, drivers ear to end of exhaust is shorter than most other cars! |
1391 Posts Member #: 1686 Post Whore Oxford |
30th May, 2011 at 10:16:36pm
Bad sound proofing, thin panels. Space constraints for decent silencers. On 19th Feb, 2011 Miniwilliams said:
OMG Robert that's a big one |
30th May, 2011 at 10:19:43pm
mine doesnt seem that loud, although its a single box rc40, i rarely hear it over the engine noise unless both my windows are open On 26th Jan, 2012 Tom Fenton said:
![]() 259 Posts Member #: 9335 Senior Member Bromley, SE London |
30th May, 2011 at 10:21:43pm
I think poor sound proofing is a large cause of the boom and reverberation you get in the cabin.
30th May, 2011 at 10:31:39pm
The fact the silencer is straight through is the culpret for most of the noise.
30th May, 2011 at 10:42:14pm
Colin so you recon the side exits don't reach the same db's. Thinking about it modern systems have loads of bends. I run a supercharger and I don't care the TB is on the wrong side.
30th May, 2011 at 11:41:43pm
i used the same exhaust silencer i have on the turbo now on a 998 i once had (bike can) and i could hardly hear it. and thats all i had. plus there are no bends in it at all. but its quiet, produces a very nice sound, and seems to give me great power output.
784 Posts Member #: 912 Post Whore North Yorkshire |
30th May, 2011 at 11:46:36pm
Why would you choose to run a cat Colin..?
On 30th May, 2011 Sprocket said:
The fact the silencer is straight through is the culpret for most of the noise. Me personally when I'm done will have the turbo, a sports cat, a mid section and the rear box, all in 2 1/4" Will be interesting to see how loud that is at full bore. I drill holes in everything..! |
31st May, 2011 at 05:50:07pm
On 30th May, 2011 Si P said:
Why would you choose to run a cat Colin..? Question being after reading Dave Walkers column in this months Track Driver Mag. He claims that they are the work of the devil.. So hence the question..? Si Since you don't really know the context in which Dave meant his comment, it is easy to make assumptions. Consider that BTTC and WRC all have to have a cat fitted, and while yes, they might release an amount more power, I don't see them being 'The devils work'. Its vehicle construction and use legislation. One thing I recon Walker might be spouting off about is the that his tailpipe lambda readings will be all to cock. I don't agree with those who remove a cat from a car that should have one, and then find a 'friendly' MOT man. Its not the MOT man these people should worry about, its the VOSA man. Fit a quality sports cat (£200+), not a £60 ebay special. My car should have a cat, so a cat will go back on. Simples You live your life by values. For me, if refitting the cat means I'm doing a little bit for the better, however minute it may be, I'll be happy knowing that its right
1226 Posts Member #: 9271 Post Whore Stoke on Trent |
31st May, 2011 at 06:03:13pm
1 3/4 RC40's are'nt loud but at what sort of power output do they become restrictive? one day boost will be mine!
On 10th Mar, 2012 Joe C said:
TBH peple stick it everywhere... and theres merits to each... |
31st May, 2011 at 06:19:15pm
i have no silencer just 2" straight through and its not that loud, the sccr box is much louder 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
31st May, 2011 at 06:29:25pm
Call me daft, but imo a 1.75" rc40 will do for any N/A application, because thats pretty much all that goes into the engine, so the exhaust should be capable of taking it away. I can see why a 2" bore is suggested for turbo use though. On 26th Jan, 2012 Tom Fenton said:
31st May, 2011 at 07:36:17pm
Fit a rotary muffler :)
In the 13's at last!.. Just |
1st Jun, 2011 at 12:34:50am
Sorry if the question sounded out of sorts. Just an honest question.
Why would you choose to run a cat Colin..? Question being after reading Dave Walkers column in this months Track Driver Mag. He claims that they are the work of the devil.. So hence the question..? Si Since you don't really know the context in which Dave meant his comment, it is easy to make assumptions. Consider that BTTC and WRC all have to have a cat fitted, and while yes, they might release an amount more power, I don't see them being 'The devils work'. Its vehicle construction and use legislation. One thing I recon Walker might be spouting off about is the that his tailpipe lambda readings will be all to cock. I don't agree with those who remove a cat from a car that should have one, and then find a 'friendly' MOT man. Its not the MOT man these people should worry about, its the VOSA man. Fit a quality sports cat (£200+), not a £60 ebay special. My car should have a cat, so a cat will go back on. Simples You live your life by values. For me, if refitting the cat means I'm doing a little bit for the better, however minute it may be, I'll be happy knowing that its right ![]() Edited by Si P on 1st Jun, 2011. I drill holes in everything..! |
1st Jun, 2011 at 08:23:27am
You are all missing quite an important fact here.
On 30th May, 2011 gr4h4m said:
Why are they so loud? Everything apart from the pea shooter is very loud and boomy, is this nessasary for the power they produce? I was thinking there might be merit in the miglia style of setup with a twin rear scilencer? I mean dont get me wrong I like a good exhaust note but at certain speeds they seem too noisy? What does everyone else think? Fastest 998 mini in the world? 13.05 1/4 mile 106mph
1st Jun, 2011 at 12:06:06pm
On 1st Jun, 2011 wil_h said:
On the subject of Cats, there is no point fitting one IMO. You're never going to save the world fitting one to a car you hardly use. And when you come to sort the fuelling, it'll always be a compronise between power and not destroying the Cat. Ok. I'm not after saving the world since the world does not need saving! This planet will be here long after we are gone
I don't see how you could destroy a cat, fueling for power, since it is pig rich that kills the cat. the cat will cope well with a max torque fueling of 12.5:1. If you don't want to fit a cat to your car, thats up to you. If your car does not have a requirement for a cat, there's no problem. And yes they get out clause for the later minis lies with the engine number. But, if you have a car that has had a computerised MOT emissions test done on the cat test, you try and get the monkey operating the machine to tell it that it needs to do a Basic emissions test. Not impossible, but for a monkey, it might as well be. On 26th Oct, 2004 TurboDave16v said:
1st Jun, 2011 at 12:27:20pm
On 1st Jun, 2011 Sprocket said:
I don't see how you could destroy a cat, fueling for power, since it is pig rich that kills the cat. the cat will cope well with a max torque fueling of 12.5:1. If you don't want to fit a cat to your car, thats up to you. If your car does not have a requirement for a cat, there's no problem. And yes they get out clause for the later minis lies with the engine number. But, if you have a car that has had a computerised MOT emissions test done on the cat test, you try and get the monkey operating the machine to tell it that it needs to do a Basic emissions test. Not impossible, but for a monkey, it might as well be. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
288 Posts Member #: 6267 Senior Member Bristol |
1st Jun, 2011 at 01:04:23pm
I have a single DTM silencer on my car, the rest of the system is 2". It was really loud when the car was NA but I thought it sounded fantastic. I did twice get asked when I was going to get my car fixed by people at work, I guess a cammy engine with a loud exhaust sounds broken to some people! The other issue with it was that it would set car alarms off, including the same Transit on my road everyday. I was also told by one of my neighbours that they didn't need an alarm as they got woken up at 7:20 everyday by my car.
1st Jun, 2011 at 01:23:34pm
And what car do you know runs under load at 14.7:1AFR?
1st Jun, 2011 at 01:26:46pm
And what car do you know runs under load at 14.7:1AFR? Fastest 998 mini in the world? 13.05 1/4 mile 106mph
1st Jun, 2011 at 07:25:25pm
You are all missing quite an important fact here. Pea-shooters are quiet as they are restrictive, and cars with them fitted have low power, and low revs, meaning less exhaust gasses and a quieter drive. Once you start modifing to get more power, you are expecting any scilence to do more work (bigger bang, more nosie). I would think that sound proofing on the boot floor would be a good start, the only other way is to fit a bigger scilencer, not easy in the space available, but you could be imaginative! On the subject of Cats, there is no point fitting one IMO. You're never going to save the world fitting one to a car you hardly use. And when you come to sort the fuelling, it'll always be a compronise between power and not destroying the Cat. On 30th May, 2011 gr4h4m said: Why are they so loud? Everything apart from the pea shooter is very loud and boomy, is this nessasary for the power they produce? I was thinking there might be merit in the miglia style of setup with a twin rear scilencer? I mean dont get me wrong I like a good exhaust note but at certain speeds they seem too noisy? What does everyone else think? I run a supercharger and I don't care the TB is on the wrong side.
1st Jun, 2011 at 07:36:22pm
I guess it all boils down to the fact that if Maniflow sold quiet exhausts, they wouldn't sell any exhausts; if you see what I mean. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
1st Jun, 2011 at 07:58:37pm
Mm see what you mean, so too many chavs buy minis :) I run a supercharger and I don't care the TB is on the wrong side.
1st Jun, 2011 at 08:26:52pm
I think Wil is spot on, demand drives the product.
