Home > Help Needed / General Tech Chat > Getting your engine painted like this...
jamesfawcett
Member #: 218
Bingley, West Yorkshire
this picture has amazed me!
How the hell do you get your engine painted aswell as that, mine always flakes no matter how clean and degreased i get it, and thats with the expensive halfrauds engine paint!
Also the silver bits like the thermostat housing are really shiney, are they new or are they old ones that you have just polished for ages???
I want my engine to look like this!
Edited by iain on 29th Mar, 2005.
b16_b
Member #: 429
newcastle upon tyne
call me thick but it looks powdercoated....
love my engine to be clean and tidy like that!
read wot dave said...iam thick!lol
Edited by b16_b on 29th Mar, 2005.
looks like the block and head have been acid dipped given the cleanliness around the plug holes and various bosses...
If you do this, decent paint WILL stick - assuming you wash off all chemicals with acetone, celly thinners or something similar of course!
'stat housing is just polished. My dashpot and stat has a similar shine... Lots of elbow grease and AutoSol metal polish!
Nothing I hate more than silver dahspot covers! Get it polished you lazy turd!
Mine always sticks, used hammerite last time. first it went soft but it had only been on about 12hrs. after that it went rock solid and stayed there all the time the engine was in.
engines now in the states *smiley*
pot_dan
Member #: 326
bradford, west yorks
i do love the look of that rocker cover, i thought powder coted when i saw it aswell, is this megga expensive i see the clutch cover is done like that as well and looks great.
Edited by pot_dan on 29th Mar, 2005.
The paint on my head/block always used to bubble/flake. I found it was moisture in the block from cleaning it.
The moisture would try to escape when the engine was run and became hot. I found heating the block and heat gently with a blowtorch would remove this, then paint your engine.
Phil. *smiley*
say what you want guys but......................*wink*
for donkys years i have been painting engine blocks with NORMAL household paint dulux...
jelly paint seems to work, flow better
i clean the block thoroughly and apply a thin coat,
let this dry for 24 hrs say in the summer time and in winter 48hrs then apply a further light coat
hey presto DONE!
as long as the blockand all parts have been cleaned properly this method works DAM FINE!
its resistant to OIL,HEAT and thats all whats under the bonet!
when you paint your household radiators,
it stands that heat OK and these get to simlar temps to engine blocks
I HAVE HAD NO PROBLEMS!
as long as its two light coats and drying time between
why? pay for expensive so called engine paints which you
DONT need
OR HAVE i LET THE CAT OUT OF THE BAG!
with some so called Professional Engine building companys,Builders?*happy**wink**wink**wink*
Edited by BENROSS on 30th Mar, 2005.
mikemph
Member #: 449
Oxford
My enigine look almost identical, except the rocker cover is different and a vernier cam belt drive!
Nice job :cool:
I have used normal hammerite before seemed to work just as well as any other so called engine paint or High temp paint.
i think benross has hit the nail on the head there
*tongue*
pot_dan
Member #: 326
how od i clean it properly? so far i have used petrol ina spray bottle and it has got verry thick grease off but its still got the old paint on wich is in suprising good condition for 15 year old motor but its just not red enough for me lol or should i just paint over the paint thats left?
cheers, Dan
Petrol leaves a residue when it evaporates. You need to get some of that degreaser that sprayers use before the first coat to get rid of greases and the like...
Or acetone also works...
Best thing though is plug ALL the holes, and get a wire brush attachment on your drill to remove anything that might fall off - ie surface rust/loose paint.
Then use the degreaser wipe
Then paint (or put in the oven like phil does then paint)
antman
Member #: 358
Snetterton, Norfolk
wot i did with my motor was when it was in bits i used a wire brush grindign wheel in a grinder (of course!!) and it went back to bare metal before i repainted it in a nice shade of blue.
Antman
clubman_dan
Member #: 142
Winchester
mmm acetone, i was cleaning some stuff in the garage with it the other night and i came in as high as a kite
b16_b
Member #: 429
newcastle upon tyne
the owner would be gutted if sprung an oil leak or the thing didnt work when built it up...
looks nice! how to get that done? i will need my engine rebuilt and cleaned up...prob not tweak with out as just started so run it standard for a while til get used to it....
jamesfawcett
Member #: 218
Hamerite degreasent - ?2.20 on offer at Halfords at the moment *wink* Big spray bottle lasts ages
mikemph
Member #: 449
Oxford
or free from stores at work and the supply last forever lol *wink*
'five finger discount'
Love it!
b16_b
Member #: 429
newcastle upon tyne
mike mph not gonna spread the joy....sharing is caring!!!!lol
pot_dan
Member #: 326
right then will get some degreaser stuff from halfords cheers dave:)
the last 'red' paint i got was pink so i better go get some more lololol
cheers! Dan
mikemph
Member #: 449
Oxford
Thats the best type of discount I think *wink*
Hammerite is my choice, used it on a number of different A series engines and its never come off and lasted well.
yeah hammertite is good if you give it cure time, if not, just dont touch your engine first time it gets hot then leave it to cool. Seems to bake it on well.
hammertite! good but
dulux never had a problem
having said that!
the best paint is epoxi 2 pack brushed on, available from most auto paint dealers
if you dont want to spray it and play hell with your lungs
brush it on
only mix what you need for the job at hand and 1/2 litre with hardner goes a long way...........;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;.......
no thinners reqd.
two coats would give an EXCELLENT finish
thats if you are after the ultimate dogs nuts job!
but the old dulux i have used for years still does the trick as described above..........
just a thought
most (all?) degreasers leaves a residue BTW...
You need to find some cellulose thinners to finish it off with.
turboestate
Member #: 362
durham area
even better get some pannel wipe its alcohol bassed and dries in seconds so much still left on even after the thinners has evaporated *laughing*
love that straight cut scream!!!
______
/___|_____
_ (@)___(@)
here is my engine, washed down with thinners, then used normal car spray paint on
I'll let you know if it all ends up on the floor in a few weeks!
Edited by Jimster on 2nd Apr, 2005.
Disk full (/tmp/#sql_c9d4b_0.MAI); waiting for someone to free some space... (errno: 28 "No space left on device")
