| Home > Help Needed / General Tech Chat > Vmaxscart SC on an SPI car - anyone running one? | |||||||
16 Posts Member #: 9438 Member CT, USA |
21st Jun, 2011 at 05:10:18pm
Hey guys
21st Jun, 2011 at 06:00:06pm
Where does the extra fuel come from?
21st Jun, 2011 at 06:27:59pm
Fuel and timing? How will it compensate with a standard spi ecu? I run a supercharger and I don't care the TB is on the wrong side.
21st Jun, 2011 at 06:44:27pm
On 21st Jun, 2011 gr4h4m said:
Fuel and timing? How will it compensate with a standard spi ecu? I think what he is planning on doing is moving the refluctor (advance it) ring in order to retard the ignition - correct? It's a bit caveman but should work - people on here run fixed dizzy's so in fact it probably be a little better than that. Nothing like programmable ignition however. Everything is possible... It just costs a lot. De comp plates are dirty words on this forum, but the reality is it does work, and being 100hp it should be fine, as long as everything is perfectly flat, and you use a GOOD plate. Otherwise you'll be changing gaskets every other week. Taking material out of the head is the better option but is not easily reversible. Turbophil or benross offer this service. I ran a suck through supercharger and it was crap at idling, but it was carb and not injection. It ate fuel. I would guess fueling is going to be your issue if you have one. Edited by almichie on 21st Jun, 2011. On 7th Nov, 2011 apbellamy said:
1226 Posts Member #: 9271 Post Whore Stoke on Trent |
21st Jun, 2011 at 06:51:09pm
i dont see the standard spi fueling enough for the charger though even with the ignition sorted.
one day boost will be mine!
On 10th Mar, 2012 Joe C said:
TBH peple stick it everywhere... and theres merits to each... |
21st Jun, 2011 at 06:53:48pm
The spi pump can deliver upto 1.2 bar pressure, so as long as boost is less than 0.8 bar (13psi) he'll be fine. On 7th Nov, 2011 apbellamy said:
21st Jun, 2011 at 07:01:36pm
what i meant was is the level of air flow that a sc delivers within the set parameters of the standard spi ecu, if not then it wont fuel right. one day boost will be mine!
21st Jun, 2011 at 07:20:58pm
On 21st Jun, 2011 wez said:
what i meant was is the level of air flow that a sc delivers within the set parameters of the standard spi ecu, if not then it wont fuel right. Ah!! Yes that's what I think too, maybe it didnt come out right above! I don't think it'll be too far off though with a standard head. On 7th Nov, 2011 apbellamy said:
21st Jun, 2011 at 07:40:40pm
whoops, sorry guys. I forgot to write that I will use the FPR and a new pump.
21st Jun, 2011 at 08:33:24pm
21st Jun, 2011 at 11:07:11pm
I understand the theory and to a degree, can see it working, but I have yet to actually see one, and see one working at that.
Edited by Sprocket on 21st Jun, 2011. On 26th Oct, 2004 TurboDave16v said:
7 Posts Member #: 9512 Junior Member |
22nd Jun, 2011 at 12:26:59am
hi dma550 iv an omex 500 ecu with my kit been told itl work!!.
744 Posts Member #: 7912 Post Whore Australia oi oi oi! |
22nd Jun, 2011 at 12:46:22pm
Buy a sc 12 kit from Australia they seem to run right ask Graham and you will see some change |
22nd Jun, 2011 at 12:47:04pm
Ps Sc kit looks nice and works with a mpi |
22nd Jun, 2011 at 05:06:07pm
Hey, thanks guys
22nd Jun, 2011 at 05:12:13pm
tell me more Nick, whose is that? |
22nd Jun, 2011 at 06:14:16pm
Rather than re-invent the wheel, I suggest you contact Allen from Long Island - he has done this and spent a lot of time (and money) getting it right.
Edited by turbodave16v on 22nd Jun, 2011. On 17th Nov, 2014 Tom Fenton said:
23rd Jun, 2011 at 03:20:35am
Thanks TurboDave
On 22nd Jun, 2011 TurboDave16V said:
Rather than re-invent the wheel, I suggest you contact Allen from Long Island - he has done this and spent a lot of time (and money) getting it right. Contact him and ask his thoughts. At least he has had direct experience - something few of us on here have (with the vmax supercharger setup). You can contact him through his website in his sig - or I can send you his email if you PM me... http://www.turbominis.co.uk/forums/index.php?p=vt&tid=384078 http://www.turbominis.co.uk/forums/index.php?p=vt&tid=384078 |
23rd Jun, 2011 at 08:52:36am
his name is ben,
Edited by NickG on 23rd Jun, 2011. |
23rd Jun, 2011 at 09:51:08am
I have one of Ben's SC12 kits. Lovelly bit of engineering. I'm putting the specialist components 5 port efi kit on mine. On 11th Feb, 2015 robert said:
23rd Jun, 2011 at 01:06:40pm
there is a good look at a sc12 kit on youtube.
23rd Jun, 2011 at 04:41:15pm
apbellamy, SC 5 port would be perfect for me. Do you run a decomp plate? An SC12 is low boost, right? |
23rd Jun, 2011 at 04:41:48pm
On 23rd Jun, 2011 NickG said:
there is a good look at a sc12 kit on youtube. http://www.youtube.com/watch?v=n74314IRIls Thanks Nick! Looks an interesting alternative. I can get Sc12's very cheaply in the US. |
23rd Jun, 2011 at 04:51:16pm
Have you considered a Megasquirt ECU? You can get one cheap in the US and it would allow you to use the standard reluctor ring to control the ignition (with the distributor) and fueling. That would require an MS2 with MS2/Extra (or MS3 but that would be overkill for that setup).
23rd Jun, 2011 at 05:36:50pm
On 23rd Jun, 2011 dma550 said:
apbellamy, SC 5 port would be perfect for me. Do you run a decomp plate? An SC12 is low boost, right? Nope. I have a set of +.020 11cc cast omega pistons and 28cc chambers in my head. (Done properly, decomp plate is a bodge). Bang on 8:1 Compression ratio. Ben did my crank pulley for 12 psi. I've since had a custom pulley made to replace the one on the charger, I'm thinking about getting it turned down a bit further so that I can get more boost. Luke ran 15psi on his 1100 and had no bother with it. Here's a pic of the 5 port efi stuff fitted. I'm going to have the trumpet extended, but if you went with the sock filter option then it will bolt straight on. The ECU does fuel and ignition, so no messing around with dizzys and reluctor rings etc.
Ignore the threaded bar and tube, it's just just to get accuratish dimensions from. Edited by apbellamy on 23rd Jun, 2011. On 11th Feb, 2015 robert said:
I have not heard of one vmax kit run right at all?
