| Home > Help Needed / General Tech Chat > Help working out how much boost I can run... | |||||||
23rd Jun, 2011 at 06:23:35pm
I've got TM disease and I've got it bad.
![]() 6753 Posts Member #: 828 Post Whore uranus |
23rd Jun, 2011 at 06:31:29pm
70mm. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
23rd Jun, 2011 at 06:46:53pm
By my calcs using an MG metro cam, at 1:1 it'll be running 12 psi (not accounting for losses owing to bends and heat etc.)
23rd Jun, 2011 at 06:57:37pm
Air flow and pressure ratio go hand in hand. the pressure ratio will depend on how much air flow the charger produces compared to how much the engine consumes.
23rd Jun, 2011 at 06:58:53pm
Interesting...
Edited by apbellamy on 23rd Jun, 2011. On 11th Feb, 2015 robert said:
23rd Jun, 2011 at 07:23:21pm
The MAX pressure ratio determins the max boost. Pressure ratio is an absolute value. Taking the example of the 1.8 max pressure ratio, an absolute charger inlet pressure of 14.5psi (atmospheric pressure) will discharge at 26.1psi absolute, which is a max permissable 12.1psi 'boost' (disccharge minus inlet pressure) the charger is capeble of achieving. It will most certainly not achieve 28psi boost if you go by the manufacturers specs
23rd Jun, 2011 at 07:26:22pm
1293 - yes
23rd Jun, 2011 at 07:37:26pm
http://www.superchargerperformance.com/sup...r-modifications
23rd Jun, 2011 at 07:55:52pm
Estimate of peak power at 5500rpm
23rd Jun, 2011 at 07:57:01pm
You should also account for the fact that you are not using an intercooler and the adiabatic efficiency of the blower.
23rd Jun, 2011 at 08:02:20pm
oh and the charge temps will be around 90 to 100 degrees C On 26th Oct, 2004 TurboDave16v said:
23rd Jun, 2011 at 08:04:49pm
On 23rd Jun, 2011 Paul S said:
You should also account for the fact that you are not using an intercooler and the adiabatic efficiency of the blower. If, for example, the air temperature after the blower is 100 Deg C rather than 25 Deg C, then the boost pressure will be higher as the air is trying to take up approx. 25% more space. The calculator I used takes into consideration the charge temps, and the intercooler efficiency was set to zero with a compressor efficiency of 75% To be honest, I dont think those figures look far out, especially if you take the first two results and average them On 26th Oct, 2004 TurboDave16v said:
23rd Jun, 2011 at 08:08:36pm
On 23rd Jun, 2011 Sprocket said:
The calculator I used takes into consideration the charge temps, and the intercooler efficiency was set to zero with a compressor efficiency of 75% I suggest that, as a sensitivity test, you consider the affects of a blower efficiency of 60% for the extremes of the operating range. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
23rd Jun, 2011 at 08:11:26pm
The calculator I used takes into consideration the charge temps, and the intercooler efficiency was set to zero with a compressor efficiency of 75% I suggest that, as a sensitivity test, you consider the affects of a blower efficiency of 60% for the extremes of the operating range. 5hp drop using an avarage VE of 88% On 26th Oct, 2004 TurboDave16v said:
23rd Jun, 2011 at 08:13:28pm
Interesting...
23rd Jun, 2011 at 08:14:00pm
Andy, i have read a post from Ben which stated that the coating on the rotors comes off when you start running 14 psi...
23rd Jun, 2011 at 08:22:22pm
On 23rd Jun, 2011 apbellamy said:
Interesting... So 12psi is a good road spec (based on 6k revs). So if I go do some calculations and find that more boost is possible, I could have two fuel/ignition maps and just swap the pulleys over for more power... If you wish to ignore the manufactures recomendations on max pressure ratio, then you will have to accept the responsability when the charger decides to break up and take the engine with it. How long before that happens is any mans guess, but im sure the manufacturers set the max PR at 1.8 for durabilty and reliability, so why not abide by it, unless you don't care and want the short lived glory and expence? 12psi is the max, beyond that you are in no mans land, some come back, more than often most don't. On 26th Oct, 2004 TurboDave16v said:
23rd Jun, 2011 at 08:25:11pm
Ah right, I misunderstood/misread your post. Stick with what I've got ad add N2o for more power On 11th Feb, 2015 robert said:
23rd Jun, 2011 at 08:31:38pm
Stick with what I've got ad add N2o for more power ![]() On a road car?
Not that you can't, its just a ball ache
23rd Jun, 2011 at 08:35:17pm
Realistically, if I can get 140 bananas out of it I will be happy. Should make a fairly fast road mini, especially if my my diet ideas work... On 11th Feb, 2015 robert said:
23rd Jun, 2011 at 08:45:17pm
Should make a fairly fast road mini, especially if my my diet ideas work... slimfast? weightwatchers? On 26th Oct, 2004 TurboDave16v said:
447 Posts Member #: 668 Senior Member newton aycliffe (near durham) |
23rd Jun, 2011 at 09:22:56pm
Should make a fairly fast road mini, especially if my my diet ideas work... slimfast? weightwatchers? No Dulcolax!
23rd Jun, 2011 at 09:26:03pm
Aluminum, fiberglass and lots of holes On 11th Feb, 2015 robert said:
744 Posts Member #: 7912 Post Whore Australia oi oi oi! |
23rd Jun, 2011 at 11:51:42pm
Ben reckons 14 psi max, the coasting inside was stripping, this was after 1 year of racing. When he pulled it down to check. |
24th Jun, 2011 at 07:29:29am
with an airflow somewhere between 231 and 338 m3/h at 5500 to 6000 engine rpm.
