| Home > Help Needed / General Tech Chat > Sc injection kit & Return line T piece question.. | |||||||
744 Posts Member #: 7912 Post Whore Australia oi oi oi! |
1st Jul, 2011 at 10:25:59am
so im going to buy the sc kit in good time, just saving up my pennies and im very close.
Edited by NickG on 1st Jul, 2011. |
1st Jul, 2011 at 11:11:44am
You need a fuel injection style fuel pressure regulator for the SC kit (they can supply a suitable one). The T piece trick is only used to help the fuel pressure in the carb stay consant with the boost pressure. Not relevant in your setup On 11th Feb, 2015 robert said:
1st Jul, 2011 at 11:30:00am
I think what is meant here is a T piece on the feed from the tank and put the return in there? |
1st Jul, 2011 at 11:41:07am
yes i'm a bit of a novice on this but for the return of the fuel line, instead of welding a bung in my van tank, maybe i could T that back into the pump again? it would be lower pressure so could work?
1st Jul, 2011 at 12:17:38pm
Worked fine on my turbo like many others. |
1st Jul, 2011 at 12:43:00pm
Ah.... That's what we've done on the van and has been fine
1st Jul, 2011 at 12:55:24pm
I think the easiest solution is to fit an MPi tank. Why re-invent the wheel?
![]() 453 Posts Member #: 6449 Senior Member Brisbane, Australia |
1st Jul, 2011 at 12:58:09pm
Hes got a traveller/estate/van, can never remember the proper word.
In boost we trust |
1st Jul, 2011 at 01:06:19pm
In which case you definately need to fit a swirl pot and 2 pumps, or be clever with the tank.
1st Jul, 2011 at 01:06:20pm
Personally I wouldn't do it on injection because the pressure in the regulator is an awful lot higher so when it spills back through the regulator it is much more likely to produce vapour bubbles in the return line - not a problem spilling back to the tank as the vapour will simply layer out over the fuel, but if you feed back fuel with vapour bubbles to the pump, it will cavitate more easily and have a reduced lifespan (and an irregular output pressure like Wil says). Schrödinger's cat - so which one am I ??? |
1st Jul, 2011 at 01:19:40pm
What if the return was t-eed back after the pump with a valve? In boost we trust |
1st Jul, 2011 at 01:25:43pm
The 't-piece trick' was an external by-pass for the carbs, when (for whatever reason) the air-volume above the fuel in the float chamber was not being properly pressurised by the higher pressure in the plendiniumium chamebrer.
Edited by turbodave16v on 1st Jul, 2011. On 17th Nov, 2014 Tom Fenton said:
1st Jul, 2011 at 01:32:32pm
1st Jul, 2011 at 04:12:55pm
Righto so bung it is, my next question would be where do I get the bung welded on the tank?
1st Jul, 2011 at 05:10:56pm
If you are using an estate tank, the return is not the problem. Getting fuel out is. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
1st Jul, 2011 at 06:25:09pm
I have modified two long wheel base Mini tanks for a fuel return, easy to do, and yes, you certainly need a swirl pot and lift pump, otherwise you will have to ensure the tank never drops bellow half full, and then drive it like your Gran, which pretty much defeats the whole point. On 26th Oct, 2004 TurboDave16v said:
1st Jul, 2011 at 09:17:40pm
Ok, I was going to use a external high pressure fuel pump. So I still need the swirl pot? And lift pump? I was hoping it was going to be easy! :) |
1st Jul, 2011 at 10:25:13pm
Read what sprox says....
2nd Jul, 2011 at 04:31:27am
so something like this? I originally was gOing to buy this but jon felt
Edited by NickG on 2nd Jul, 2011. |
2nd Jul, 2011 at 08:45:43am
Have a read of this Nick,might give you food for thought...
2nd Jul, 2011 at 11:49:02am
Thanks mate few options
2nd Jul, 2011 at 12:06:42pm
I suggest as Sprox and dave say,
2nd Jul, 2011 at 12:07:00pm
somthing like this,
84 Posts Member #: 2404 Advanced Member Braintree, Essex |
2nd Jul, 2011 at 12:10:25pm
You could use a VW GTI fuel pump which has an integral reservoir. Geoff |
2nd Jul, 2011 at 12:24:35pm
also if you were to stick the pump in the tank like in the link below I'd sugest slicing the tank in half and adding baffles.
On 2nd Jul, 2011 apbellamy said:
Have a read of this Nick,might give you food for thought... http://www.stallard-engineering.co.uk/stor...ubmanestate.htm On 28th Aug, 2011 Kean said:
