| Home > Help Needed / General Tech Chat > What is the Direction of rotation on the A series? | |||||||
96 Posts Member #: 7325 Advanced Member |
8th Jul, 2011 at 09:40:08pm
Im just wondering as Im second guessing myself here, I have my ECU running on anti clockwise but im still not convinced. The engine wouldnt start running clockwise. |
337 Posts Member #: 9138 Senior Member wolves |
8th Jul, 2011 at 09:54:53pm
engine ? clockways from the rad end |
![]() 1105 Posts Member #: 1504 Post Whore Westbury, Wiltshire |
8th Jul, 2011 at 09:58:11pm
When you view the side of the engine (or front of the engine if its inline) with the crank pulley facing you, the pulley will turn clockwise with the engine running in its normal configuration.
8th Jul, 2011 at 10:27:39pm
how the hell have I managed to get the engine running with the ECU told its running the wrong way!
8th Jul, 2011 at 11:06:33pm
you haven't, you must also have that wrong, and thus right... if you get my meaning. |
8th Jul, 2011 at 11:23:11pm
When I tried first I had the ECU told its clockwise rotation, car didnt start, just backfired and the likes.
10th Jul, 2011 at 09:35:23pm
plugs the wrong way round?
Yes i moved to the darkside |
11th Jul, 2011 at 08:40:56am
The answer is clockwise as everyone else says but why does the ECU need to know ???
11th Jul, 2011 at 10:57:03am
What Rod said makes perfect sence when you set the trigger wheel up Ciaran did to have the missing tooth 9 teeth befour or after the sensor ? On 17th Feb, 2009 Rob H said:
11th Jul, 2011 at 01:26:44pm
I'm with Rod. I've never had to tell any ECU which way the engine runs. why would this be of any use. the crank sensor is just looking for a missing gap in the trigger wheel. Which way it passes the sensor is not important.
14th Jul, 2011 at 02:24:24pm
got number one to TDC, marked the pulley with some red paint at the 0 degree pointer on the TC, then I counted the teeth from sensor to missing tooth, theres like 50 or 60 degrees between them.
14th Jul, 2011 at 02:31:04pm
The trigger wheel was welded onto the pulley by canems, I just ordered the Kit because I hate farting around, I just wanted to get the whole lot and fit it. Since the pulley can only go on one way if the TW is on arseways I have no Idea, its is something thats possible though but unlikely.
14th Jul, 2011 at 02:40:31pm
errrrrrm????
14th Jul, 2011 at 03:13:10pm
gap is 100% not 9 teeth BTDC at the moment. Edited by ciaran on 14th Jul, 2011. |
14th Jul, 2011 at 03:16:43pm
Yes it is, ignore the timing mark on the pulley.
14th Jul, 2011 at 03:17:11pm
On 14th Jul, 2011 ciaran said:
If its running CW and you say the missing tooth is for arguments sake 9 teeth away, on the mini configuration, the wheel will have to turn 90 degrees to get to the sensor. No, the sensor must be read 90 degrees BEFORE the engine reaches TDC. The ECU needs that 90 degrees of time to calculate spark and fuel. So at TDC, the missing tooth on the wheel will have turned 90 degrees PAST the sensor...... As Canems is (I believe) designed for the A Series (which only runs clockwise) and you say they welded the wheel on, I can't see how it can be wrong if you set it as they say. Schrödinger's cat - so which one am I ??? |
14th Jul, 2011 at 03:32:35pm
So since the pulley is keyed onto the crank, that means it can only go on in the one position. If I line up the pulley with TDC on number 1, the missing tooth should be 90 degrees away from this? i.e missing tooth is 90 deg apart from the mark on the pulley?correct? |
14th Jul, 2011 at 03:44:33pm
The missing tooth should be 90 degrees away, but specifically, 90 degrees PAST the sensor.
14th Jul, 2011 at 03:54:47pm
I will say it once more.
14th Jul, 2011 at 04:26:23pm
Currently with the engine at TDC, the Missing tooth is 50 degrees Before the sensor when you look in the engine bay. |
14th Jul, 2011 at 04:29:37pm
Is that true TDC or TDC according to the pulley?
14th Jul, 2011 at 04:37:40pm
Thats with stick through the hole and pushing the engine in gear.
14th Jul, 2011 at 04:38:40pm
There are some pulleys from other derivatives of the engine (especially the inline ones fitted sideways in Meastros) that had the pulley marks in a completely different position.
14th Jul, 2011 at 04:54:20pm
Surely the engine would not run being so far out?? |
14th Jul, 2011 at 04:59:03pm
The mark on the pulley lines up with TDC, its the TW thats off. In the manual it makes no mention of the missing tooth needing to be 90 degrees before TDC in fact it uses the words "fit where convienient". I reckon the software can be used to tell the ECU where TDC is, by compensating for any mis alignment, altho It would it still mean that in my case the ECU will only have half the time to figure out where in the maps it is> |
