| Home > General Chat > How do you get the power down off the line?? | |||||||
28th Jul, 2011 at 10:23:04pm
In the 13's at last!.. Just |
28th Jul, 2011 at 10:27:39pm
g ready boost controller is good if you have the cash
28th Jul, 2011 at 10:40:28pm
Clutch control. |
28th Jul, 2011 at 10:42:36pm
You have all the launch control youll ever need in your left and right foot, just keep practicing :) On 26th Jan, 2012 Tom Fenton said:
28th Jul, 2011 at 10:58:47pm
At one point in the development of the TT we ended up with an engine that did exactly what you say. No matter what you did you never got it right.
28th Jul, 2011 at 11:30:59pm
I think that I'll plumb in a primitive boost control system to limit the boost using a button controlled solenoid perhaps.
133 Posts Member #: 9277 Advanced Member Nottingham |
29th Jul, 2011 at 03:32:12am
emergancy starts, love it |
29th Jul, 2011 at 08:09:52am
When I had a fibre clutch could do perfect launches. However with a paddle it is either depressed or the wheels are spinning under such conditions! On 5th Sep, 2011 Vegard said:
29th Jul, 2011 at 08:55:12am
Also drop the tyre pressure a bit, On 28th Aug, 2011 Kean said:
29th Jul, 2011 at 09:16:00am
Had a similar experience with the van. You just have to be more granular with the clutch pedal.
29th Jul, 2011 at 12:13:29pm
I thought about tyre pressure this morning. I'll dump a but if air out and try again.
29th Jul, 2011 at 12:18:56pm
There is no right or wrong advice its just get used to the car and practice practice practice Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
703 Posts Member #: 105 1st to provide proof of a running Bimmy Conversion! Brisbane ,Australia |
29th Jul, 2011 at 02:49:09pm
ah,,, make it 4-wheel drive www.miniman.com.au
29th Jul, 2011 at 02:55:03pm
My favourite launch method is:-
744 Posts Member #: 7912 Post Whore Australia oi oi oi! |
29th Jul, 2011 at 03:30:06pm
Take off in 2nd gear? |
![]() 825 Posts Member #: 2208 Post Whore Essex |
29th Jul, 2011 at 03:56:46pm
thats how you do it! On 29th Jul, 2011 John said:
My favourite launch method is:- Left foot down select 1st right foot down slide left foot sideways off clutch. This is usually followed by getting out of the car and phoning the RAC. |
29th Jul, 2011 at 04:28:03pm
If you have a solenoid valve on the bleed valve. either before or after, then you can modulate your launch by only switching to high boost after you change to second, as you have already said.
1713 Posts Member #: 8480 MS Paint flat cap champion & Morris Ital Lover From Sheffield now live in York tha noz |
29th Jul, 2011 at 05:25:08pm
On 29th Jul, 2011 tadge44 said:
If you have a solenoid valve on the bleed valve. either before or after, then you can modulate your launch by only switching to high boost after you change to second, as you have already said. I find that its a very interesting process trying to drive one handed on full throttle while juggling clutch gear lever and the boost switch. Unless you can practice on the sort of surface they have on the start line it will always be a bit different to anything you do on the road. On 18th Oct, 2013 apbellamy said:
I am feeling particularly BACish today. On 5th Oct, 2014 Shauna said:
What that's crazy, you go commando hahaha! How heavy is your helmet ? The Morris Ital assassin! |
29th Jul, 2011 at 11:37:44pm
its that crap clutch your running mate lol
30th Jul, 2011 at 12:00:30am
Bollocks. I've got breakdown cover you know!
30th Jul, 2011 at 12:14:41am
if i had a gt17 fitted, i'll bet the brakes on it i'll beat ya!
On 30th Jul, 2011 theoneeyedlizard said:
Bollocks. I've got breakdown cover you know! Don't worry, no matter how much of a shit start I get, I'll make up for it with extra boost on the rest of the run. Besides I won't be using bald tyres like you! |
30th Jul, 2011 at 12:37:37am
On 30th Jul, 2011 wintersurferuk said:
as for the boost, i may up it to 15psi just to give you a run for your money. even if i melt down just means i'll rebuild with my pistions in your garage!. i'll wager a pint of good ale, three runs, best run wins! fighting talk :) Yes i moved to the darkside |
30th Jul, 2011 at 11:32:46am
You're on. But the rules are, best overall time wins.
30th Jul, 2011 at 11:39:31am
You do have to do 3 runs miniumum though!! On 28th Aug, 2011 Kean said:
30th Jul, 2011 at 12:35:08pm
Shit. I've not got a chance!
