| Home > Help Needed / General Tech Chat > Clutch Drag | |||||||
![]() 207 Posts Member #: 9045 Senior Member Wolverhampton, West Midlands |
3rd Aug, 2011 at 05:40:20pm
Hi folks me again :).
3rd Aug, 2011 at 05:43:01pm
have you set the throw out up correctly? AlexF |
3rd Aug, 2011 at 06:38:28pm
On accounts ive just redone all mine, if you need any help dude give us a shout :)
3rd Aug, 2011 at 06:40:03pm
Oh and i also have a std diaphragm you can try if you don't have one kicking about :) On 26th Jan, 2012 Tom Fenton said:
3rd Aug, 2011 at 10:15:58pm
been round to pauls for a quick look tonight, we tried the extended slave rod out of my car and it still grinds trying to get into gear.
3rd Aug, 2011 at 10:30:33pm
Primary gear seized? If something is worth doing, it's worth doing half of. |
3rd Aug, 2011 at 10:41:15pm
good call John, ,
4th Aug, 2011 at 12:05:43am
Primary gear is all good spinning free and has 6 thou float, Paul's had the entire clutch assembly off again today to double check for anything out of the ordinary. It was all working fine a month or so back when the gearbox grenaded.
4th Aug, 2011 at 08:42:33am
Cheers for the replies guys, Nicks just echoed my replies as I wasn't able to get to a pc last night.
4th Aug, 2011 at 10:29:25am
Right, had a quick measure of the carrier and it seems to be going in by about 2.5mm? |
4th Aug, 2011 at 03:24:41pm
Just to add to the list of things done, ive rebuilt the clutch master today and its no better. I removed the starter and looked to see if the back plate is moving away from the friction plate and it seems to be, there is movment in the friction plate anyway, not a lot though. |
4th Aug, 2011 at 03:42:41pm
Poncy left leg? |
4th Aug, 2011 at 03:58:32pm
Im beginning to put it down to paul being a pansy. On 26th Jan, 2012 Tom Fenton said:
4th Aug, 2011 at 04:04:00pm
I knew I could rely on you to give me sound advice dude On 4th Aug, 2011 Kean said:
Poncy left leg? |
5th Aug, 2011 at 03:58:36pm
Just a little update, seemed to have solved the problem. After having a chat with Kean the other night with a simular issue he had.
5th Aug, 2011 at 04:30:44pm
17th Sep, 2011 at 12:10:16pm
I'm having the same problem i think
17th Sep, 2011 at 03:22:52pm
had a problem on a freinds car once ,the flywheel was pushing the c clip into the primary gear .the clearance for the c clip on the ultralight was wrong.ground it out and all fixed .. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
17th Sep, 2011 at 07:22:41pm
On 17th Sep, 2011 robert said:
had a problem on a freinds car once ,the flywheel was pushing the c clip into the primary gear .the clearance for the c clip on the ultralight was wrong.ground it out and all fixed .. MED flywheel per chance? |
17th Sep, 2011 at 07:49:09pm
See I didn't have that problem with mine, because when I fitted it first time round it was ok. Mines been fine ever since though. |
18th Sep, 2011 at 09:12:17am
Pop quiz what is this item?
18th Sep, 2011 at 03:10:48pm
^ what causes this? If something is worth doing, it's worth doing half of. |
18th Sep, 2011 at 03:21:47pm
Something isn't right there, the wear is off centre on the plate, so the bearing can't be running true to the flywheel.
Edited by apbellamy on 18th Sep, 2011. On 11th Feb, 2015 robert said:
18th Sep, 2011 at 03:59:44pm
We have done one off centre before too. If something is worth doing, it's worth doing half of. |
18th Sep, 2011 at 07:51:36pm
I think what causes this is a shagged bearing that is loose on the plunger,
. I think I will check what carls advised then fetch it all off again if no luck.
