| Home > Help Needed / General Tech Chat > electronic oil pressure gauge wiring. - update 24/09/11 | |||||||
9th Aug, 2011 at 08:14:12am
I've got an autogauge electronic oil pressure gauge and I'm having trouble wiring it up correctly, there are 6 wires, 3 short ones; red, black and orange, these are obviously for the backlight for the gauge then I have 3 longer ones, green, black and another red. The instructions are very vague and if I must say very poor, I know the green and black go to the sender and I know which way around they go as its marked wk for ground and G for green, but what's the other red wire for? I cannot seem to get a genuine reading, the only thing I have not tried, which is earthing out on the sandwich plate which is what wintersurferuk had to do as he had a similar problem, but does anybody know where the longer red wire goes?
Edited by bennyy on 24th Sep, 2011. Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
9th Aug, 2011 at 08:25:59am
What's the model number of the gauge? On 7th Nov, 2011 apbellamy said:
9th Aug, 2011 at 08:36:13am
I'm unsure until I get home mate? Audi s4 b5 - 470bhp & 486ft lbs
9th Aug, 2011 at 09:47:05am
3 short
Edited by Brett on 9th Aug, 2011. Yes i moved to the darkside |
9th Aug, 2011 at 10:10:36am
There's always one clever cloggs Audi s4 b5 - 470bhp & 486ft lbs
9th Aug, 2011 at 10:54:58am
I would say yea, but make sure it's an ignition switched feed. On 7th Nov, 2011 apbellamy said:
9th Aug, 2011 at 11:06:13am
Ill give it a go, cheers Audi s4 b5 - 470bhp & 486ft lbs
12th Aug, 2011 at 04:19:55pm
Tried wiring it as above with no luck, still reading 0psi? I'm stuck as I cannot think of any other way it can be wired? Audi s4 b5 - 470bhp & 486ft lbs
1226 Posts Member #: 9271 Post Whore Stoke on Trent |
12th Aug, 2011 at 04:40:48pm
ive got some auto gauge wiring instructions here but it shows different colours than you have, but of the 3 wires it only shows 1 to the sender, 1 to the ignition live and 1 to engine earth point.
Edited by wez on 12th Aug, 2011. one day boost will be mine!
On 10th Mar, 2012 Joe C said:
TBH peple stick it everywhere... and theres merits to each... |
461 Posts Member #: 9229 Senior Member newcastle upon tyne |
12th Aug, 2011 at 07:32:37pm
ive just wired mine the other day & put the 12v on a switch when i turned it on gauge went straight to 100psi so i swaped the earth & sender wires over on the back of the gauge & it doesnt read 100psi any more but as in the middle of a few things cant actualy start car but think it will be ok i wired 12v to a switch one wire to the sender & the other to earth (mine didnt have any wires out the back for that part only the back light) hope this helps the sender should already be earthed through the engine but if not just earth it to a good point |
12th Aug, 2011 at 08:10:07pm
just a thought, i have been trying to earth off the sandwich plate, but since its ally it wont earth, could this be why the sender is not earthing itsself hence not working? Audi s4 b5 - 470bhp & 486ft lbs
12th Aug, 2011 at 08:12:02pm
yes, winter surfer had the same issure recently, put an earth to the block and hey presto. On 28th Aug, 2011 Kean said:
12th Aug, 2011 at 10:22:34pm
give it a go joe cheers mate. Audi s4 b5 - 470bhp & 486ft lbs
20th Sep, 2011 at 08:42:06am
I still have not sorted this, I tried earthing the sender to the block and no different, i must of tried every wiring combination possible and still nothing? Could be faulty gauge or sender? Audi s4 b5 - 470bhp & 486ft lbs
20th Sep, 2011 at 09:12:47am
Is it the sandwich plate that needs earthing or the actual sender body? Edited by bennyy on 20th Sep, 2011. Audi s4 b5 - 470bhp & 486ft lbs
20th Sep, 2011 at 07:47:51pm
What ever lump of metal the sender goes, needs to be earthed. :)
On 19th Jan, 2010 wil_h said:
20th Sep, 2011 at 07:53:51pm
but if it's bolted to the engine, then it is earthed through the engine On 11th Feb, 2015 robert said:
20th Sep, 2011 at 08:02:34pm
It's bolted into a sandwich plate, I just need to solder or weld some wire onto a washer put inbetween the sender and sandwich plate. Audi s4 b5 - 470bhp & 486ft lbs
21st Sep, 2011 at 08:05:10am
Why? The sandwhich plate is bolted to the engine and the engine is earthed to the car body. It already has a path to earth. On 11th Feb, 2015 robert said:
21st Sep, 2011 at 08:29:27am
Who knows then, I know wintersurfer had a problem with it not earthing very well, I think I've tried every wiring combination, just not having it, maybe ny gauge/sender is faulty. Lol Edited by bennyy on 21st Sep, 2011. Audi s4 b5 - 470bhp & 486ft lbs
21st Sep, 2011 at 08:54:04am
the sanwich plates are usually annodised, the anodise layer is a rather good insulator, somtimes washers etc dont bite through the anno layer. On 28th Aug, 2011 Kean said:
21st Sep, 2011 at 06:18:06pm
22nd Sep, 2011 at 12:31:14pm
I'll try a washer invetween the sender and sandwich plate, with a soldered wire going to the block. See if that makes a difference. Audi s4 b5 - 470bhp & 486ft lbs
22nd Sep, 2011 at 12:56:35pm
I'll crime you a terminal tonight On 11th Feb, 2015 robert said:
22nd Sep, 2011 at 12:57:10pm
