Home > Technical Chat > Head Gasket Compressed Volume
Anyone know a typical volume in cc's for the head gasket when compressed? I am trying to accurately calculate the CR of my engine, I know piston and head volume, will assume pistons flush with block for now until I can measure it.
Std gasket volume? Or volume for the Gp A gasket if anyone knows as that is what I am using?
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
grp A = 4cc
bk450 = 3.8cc
http://www.afracing.com/cr.xls
Alex
AlexF
Sorry Alex, the BK450 is 2,8cc
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Not my figures...
Is the grp A one right?
Alex
AlexF
Nope, the GpA is 3,1cc :)
I've just messed about with these trying to achieve 11,4:1in my Mini, that's why I noticed.
Quoted from the Minispares catalogue.
Edited by Vegard on 7th Apr, 2005.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Arr ok...
I use somelse's figures off the net...
I'll update that spreadsheet at somepoint!
Alex
AlexF
stuart gurr - vmaxscart
Member #: 350
Turboing minis since '89
Supercharging minis since '04
i have one here in front of me - so pull rank and makes me the leader of the gang !-or maybe not!
its used and now measures 0.84 thick and 71 mm bore dia (.88 thick and 73.2 mm bore when new ), pye r squared x hieght gives us the volume :
35.5 x 3.14 x.84 divde by 10 to get cc's =SEE BELOW
-if in doubt check it yourself-
group A should be around 70 mm when compressed and same base thickness so: SEE BELOW
Edited by stuart gurr - vmaxscart on 7th Apr, 2005.
thats thrown all my figures out! I have no idea what my CR is now, 29cc head, 10cc pistons? what do you make it ?
yeah but wont it relax a fair bit when uncompressed even if its not new?
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
nope... or you couldn't measure the gasket thickness full stop!
AlexF
yeah you could *smiley*
just need to measure something static and torque the head down with no gasket, then add a gasket and see the difference is. hence get your compressed gasket in situ size *smiley*
We do it on our parts to calculate stack ups and the gaskets do relieve themselves a fair bit.
Just wondering if anybody had checked thats all.
*smiley*
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
good point iain!
Alex
AlexF
*happy*
Hmmm interesting!!! I always thought that the head gasket volume figures were in the order of magnitude 2.5-5cc's depending on the gasket, those are the kind of figures I have always used.
Calculating for my engine assuming piston crowns flush with deck gives me 8.08:1 using 3.1cc, or 7.24:1 using Stuart's figures.
I think that Iain has got a good point about the gasket material relaxing when un-compressed, thinking about it there must be an area of elastic deformation which the gasket recovers to, and then the plastic deformation which is visible between a new and a used gasket. Surely if all the deformation when torqued down were plastic, there would be little or no sealing effect between the gasket and the block faces?
think your math is wrong Stu!
I use (pi * d^2) / 4 to calculate area - same as pi r^2 mind...
Also, lets keep it in cm to avoid confusion,
Hence 0.84 thick and 71 mm = 0.084cm thick and 7.1cm dia.
So, pi * 7.1^2 = 3.142*50.41 = 158.367
now divide by 4:
158/4 = 39.592 cm^2
Now multiply by thickness:
39.592*0.084 = 3.325cm^3 which = 3.325cc
35.5 x 3.14 x.84 divde by 10 to get cc's = 9.363 cc
You wrote formula correctly, but forgot the ^2
eg
pye * r squared x hieght
(3.142* 35.5^2 ) * 0.84
= (3.142 * 1260.25) *0.84
= 3959.192*0.84
=3325.721
To get from mm^3 to cm^3 you have to divide by 1000, hence
3325.721/1000=3.325cm^3 = 3.325cc
Edited by turbodave16v on 7th Apr, 2005.
Member #: 350
and the prize goes to dave , i posted it , drove up to london thinking doh!!!!!!
but i'm now thinking :
35.5 x 3.14 x 3.14 x 0.84, divideby 100 =
2.940 cc std bk 450 ,and turbo is :2.898cc
i was a cse grade 2 at maths so open to suggestions , and sorry to throw the preverbal spanner in the works !
So now 8.12:1 using Stu's mark 2 figures!!!
Ah well whatever, its around the 8.0:1 mark, thats the kind of region I was aiming for anyway.
Well I'll throw another spanner in the works... The gasket isn't completely round is it (or at least not on the middle two) as I recall?
Stu - You're 'squaring' the pi (3.142) - you need to be squaring the radius... Pi R^2
Easiest thing is to forget that Pi R^2 and remember this one:
Pi * D^2
4
And also, work in cm, not mm, as it saves doing the conversion into cc...
Hugo
Member #: 416
Tiel, the Netherlands
I recently did some CR calcs for my engine, and I measured the gasket thickness by cutting a notch out the side, fitting it and measuring the gap beteen the block and head with a feeler-gauge. Haven't got the figures handy, but it's an easy measurement to do.
Hugo
Hugo
*** 1989 Jet Black body stripped for resto ***
*** 1988 Metro engine undergoing turbo conversion ***
*** 1989 BMW 318iS as daily run-a-wreck ***
good simple aproach Hugo
the shed
Member #: 317
WOW i have used my head gasket 4 times now think its time for a new one *tongue*
slap it together works every time*smiley*
SON, WHATEVER FANCY SHIT YOU'VE GOT UNDER THAT BONNET, SEEN IT A MILLION TIMES
was it new when you had it?
AV-R Technologies
Member #: 345
Guildford Surrey
Standard factory turbo head gasket - average 3.5/3.6 cc
Group A last time we checked was a nominal 4cc
http://www.avonbar.com
So now 7.95:1
Any more offers on head gasket vol!!!!!!!!
Nick
Member #: 154
Midlands
hmmmm, anyone care to work mine out for me? i don't have excel on me comp at home so cant use alex's table thing.
head is 29cc, 1293cc block, 11cc pistons, pistons sit 20 thou down the bore, normal head gasket.
Think karl worked it out to roughly 8:1 for me before but cant remember exactly.
Cheers, Nick.
