Home > Help Needed / General Tech Chat > Windscreen Removal
Jason G
Member #: 1459
En-suite user
Braintree, Essex
I know theres many ways to remove a windscreen....but I'm shite at most I've tried, resulting in breakage. Like to keep the window and rubber in tact..........any thoughts?
On 19th Jan, 2010 wil_h said:
Jason G
Member #: 1459
En-suite user
Braintree, Essex
That really wasn't the kind of answer I was hoping for.....
wng691s clubby
Member #: 9252
Cleethorpes
two people one inside using feet on screen and other on outside to catch works every time for me never broken it so far oh yea remove chrome strip first
Edited by wng691s clubby on 16th Aug, 2011.
Done now needs redoing lol
dazibee
Member #: 1356
TRURO, CORNWALL
At a push you can do it alone with the feet method from inside. Screen should gently pop out at one corner then you can get at it from the front
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Foot technique never worked for me...too scared
998-city-rat
Member #: 9421
Bardwell, suffolk
Sorry to hijack but does the same skill work for fixed rear quater windows?
they bounce when dropped as well which is a result!
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Neh worries, I assume it does. But not fussed with those.....going to polycarb :)
Jason , windows are a pice of piss, make sure the rubber is warm (makes it softer) and allways use lube.lol
rick
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Trying to keep the convo on a professional level!
rick
A brick works for most windows really..
Although fixed rubber windows really are easy to remove. Getting that bastard chrome bit back in when refitting isnt though !!
Frost sell a little tool for it I think. Buy it.
I never had one when I did mine, and it took hours to get it back in.
Treat all rubbers equally, only use them once.
Just cut around the glass behind the beading strip with a knife and it all comes out nicely. Cheaper to replace the rubber than the glass if it all goes tits up :)
wng691s clubby
Member #: 9252
Cleethorpes
tool works well on insert it is a tenner tho
are we talking mini or metro here?
NickG
Member #: 7912
Australia oi oi oi!
i just cut mine out, they are cheap as just buy some new ones.
i got mine out with no problems & did not cut them just wiggled from each corner my self.
take your time, like making love to a women.
Edited by NickG on 17th Aug, 2011.
Good point.... I've never had any problems with Mini ones but broke a Metro one taking it out (usuall foot method), bought a brand new seal because I thought the old one had gone hard so caused the failure, then cracked my £10 scrappy replacement putting it in with the new seal....
The Metro seals don't have the removable filler strip so are less flexible - well that's my excuse....
Lmao.
On 17th Aug, 2011 wng691s clubby said:
tool works well on insertion it is a tenner tho
Edited by Carlzilla on 17th Aug, 2011.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Metro. The screen is heated type too :)
Could cut the rubber, if replacements are still available. Fitting a windscreen I've never had issues with. A length of wire and hey presto! *happy*
New seals are few and far between
Jason G
Member #: 1459
En-suite user
Braintree, Essex
I was assuming K series engined metro are the same and are available?
They are the same, but availability is still poor.
I got mine of the internet (NOT eBay) a couple of years ago - ( I'll see if I can find the supplier). It was over £30 though, just for a bit of rubber.
That said, these chaps allegedly do them for about £20
http://www.coh-baines.co.uk/
EDIT: Ignore me, they've since sold out
Edited by apbellamy on 17th Aug, 2011.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Just googled it, quite a few coming up. As the car is a toy, hasn't got to be perfect.
