| Home > Help Needed / General Tech Chat > water feed for turbo? | |||||||
1492 Posts Member #: 9468 Post Whore Wootton Bassett |
23rd Oct, 2011 at 04:47:40pm
Has anyone drawn a diagram of how to connect a water fed turbo to the standard cooling system? If so I would like some help with how you guys have set yours up please :) On 10th Mar, 2012 theoneeyedlizard said:
Hypothetically speaking, where would you stick your nozzle? On 22nd Jun, 2012 apbellamy said:
my wife doesn't know what.head is never mind compression ratio. |
23rd Oct, 2011 at 08:29:18pm
Beachgrove Engineering 01525382968 Speak to Alan.
Own the day
23rd Oct, 2011 at 08:46:58pm
23rd Oct, 2011 at 08:52:19pm
what I am doing is taking a feed from the drain plug on the bottom of the block near the "OIL" pump, feeding that through the turbo, and then back into a brass union I have soldered to the rad near the filler.
Edited by Joe C on 23rd Oct, 2011. On 28th Aug, 2011 Kean said:
23rd Oct, 2011 at 09:06:26pm
On 23rd Oct, 2011 Joe C said:
what I am doing is taking a feed from the drain plug on the bottom of the block near the water pump Have you got a picture of one of those? ![]()
![]() 489 Posts Member #: 9159 Senior Member Devon |
23rd Oct, 2011 at 09:33:43pm
I've drilled out the coolant bung/plug to accept an 8mm straight brass union>then to the turbo>then returning into a metro thermostat housing [without the sandwich plate]
23rd Oct, 2011 at 09:46:06pm
is the water feed to the turbo gravity fed or will it be forced through?
Edited by Craigie-B on 23rd Oct, 2011. On 10th Mar, 2012 theoneeyedlizard said:
23rd Oct, 2011 at 09:47:25pm
forced, otherwise it'll boil in the turbo. On 28th Aug, 2011 Kean said:
23rd Oct, 2011 at 11:13:41pm
On 23rd Oct, 2011 Craigie-B said:
is the water feed to the turbo gravity fed or will it be forced through? Cheers for replies so far guys :) edit: by the 'coolant bung/plug' do you mean one of the core plugs? Cheers What Joe really means, is the drain plug fitted to some (but not all) blocks, down the back of the near the oil pump. The blocks without the plug still have a protruding boss that can be drilled and tapped. In doing so, you are tapping into high pressure cool water. To ensure this water flows through the turbo, you need to drain the turbo coolant outlet into a low pressure part of the cooling system, and the top of the rad is as good a place as any. On 26th Oct, 2004 TurboDave16v said:
23rd Oct, 2011 at 11:23:52pm
bingo!
![]() 384 Posts Member #: 4215 Senior Member |
25th Oct, 2011 at 06:49:05pm
i think i have it wrong then...
25th Oct, 2011 at 06:56:11pm
You are still taking high pressure coolant from the heater circuit and putting it back into a low pressure area of the cooling system. The coolant might not be as cool as it would be if taken from the block, but it's hardly going to be a problem. One thing I wouldn't be too sure about though is if the thermo syphon effect would still work in this set up on heat soak, but there is a slim chance it will. On 26th Oct, 2004 TurboDave16v said:
25th Oct, 2011 at 07:12:20pm
On 25th Oct, 2011 Sprocket said:
One thing I wouldn't be too sure about though is if the thermo syphon effect would still work in this set up on heat soak, but there is a slim chance it will. this went striaght over my head mate...lol anychance you could explain this... |
25th Oct, 2011 at 08:09:24pm
When you turn off the engine, the heat from the combustion chamber, the exhaust manifold, for example, drains into the rest of the engine. The common term for this is heat soak.
25th Oct, 2011 at 08:44:39pm
i see what you mean mate... thanks for the info |
53 Posts Member #: 9238 Advanced Member |
25th Oct, 2011 at 10:39:38pm
Can you post pictures? |
26th Oct, 2011 at 05:38:18am
On 25th Oct, 2011 gttalpine said:
Can you post pictures? me? |
26th Oct, 2011 at 04:57:54pm
All good but the system advised for mine is a separate water system with it's own rad and pump this is to minimise the potential for the returning water to rerun as steam. Own the day
26th Oct, 2011 at 11:19:11pm
On 26th Oct, 2011 Mr Joshua said:
All good but the system advised for mine is a separate water system with it's own rad and pump this is to minimise the potential for the returning water to rerun as steam. So Car manufacturers are doing it all wrong? Me personally, I don't think so :) On 26th Oct, 2004 TurboDave16v said:
28th Oct, 2011 at 04:48:25am
Like I said it was advised for mine. Own the day
28th Oct, 2011 at 06:51:33am
well whoever advised is wrong :) turbo 16v k-series 11.9@118.9 :)
28th Oct, 2011 at 09:14:48am
The system described ( drain plug in block to turbo and return from turbo to rad header tank) works fine for me and I have no cooling issues or water loss - ever. |
22 Posts Member #: 9412 Member Austria |
28th Oct, 2011 at 03:58:47pm
In other words, could I simply replace my current heater with the turbo? So the heater take off goes straight into the turbo and the water outlet of the turbo connects to the hose which would lead the cooled water from the heater back into the engine? |
28th Oct, 2011 at 04:57:59pm
On 28th Oct, 2011 carred said:
In other words, could I simply replace my current heater with the turbo? So the heater take off goes straight into the turbo and the water outlet of the turbo connects to the hose which would lead the cooled water from the heater back into the engine? thats how i have mine... but read sprockets posts above so your properly informed |
16th Nov, 2011 at 09:27:43am
Sorry for thread ressurection,
Edited by Craigie-B on 16th Nov, 2011. On 10th Mar, 2012 theoneeyedlizard said:
