Home > General Chat > Parts Washer Use - HOT Water ?
Wile E. Coyote
Member #: 7893
Portsmouth
Hey all,
I Haven't posted for a while but have been plodding on with the GT Clubman, basically I have had this parts washer http://www.machinemart.co.uk/shop/product/...=1&TC=SRC-parts since i started the strip down and rebuild and i am yet to use it, I have the cleaning fluid that I have to add water with, My question is should I add in cold water ? warm water ? boiling water with the cleaning fluid ? Surely warm water would be best ? help remove the grease/dirt and grime a bit better, I am going to be cleaning up the Radius arms tomorrow so was just curious?
Thanks All,
Jamie. *happy*
Edited by Wile E. Coyote on 18th Nov, 2011.
Jamie.
dig-mini
Member #: 9269
Rotherham
Try paraffin in it I used that fluid from m/mart and its no good
Craig
Craig
Wile E. Coyote
Member #: 7893
Portsmouth
Not got any parafin handy :0/ just 25 Litres of the stuff to mix with water which come with it .
Jamie.
don't add water it'll dilute the solution and make it all but useless, you need to use need degreaser,
carl
dig-mini
Member #: 9269
Rotherham
that stuff that comes with it is about the same as running it under the cold water tap lol
Craig
Craig
Wile E. Coyote
Member #: 7893
Portsmouth
Hey Carl, the solution I have says it is meant to have water added with it, even if I empty the whole container of solution into the parts washer it isn't enough to reach the pump to circulate the fluid :0/
Jamie.
Wile E. Coyote
Member #: 7893
Portsmouth
Oh god is it really that bad Craig ? Haha ! :0/ i have managed this far with out it :) I just want to use it though as I bought it to clean haha.
Jamie.
minidan
Member #: 7107
essex
Id buy some jizer to put in there
almichie
Member #: 2065
I've tried the water based stuff from machine mart. It does clean but it take a lot of effort. They do a solvent based cleaner which I should have bought but it'll make the garage stink and everything in it. I've tried other water based cleaners and they are all as bad. Use it neat, it's cheap so go buy some more!!
Shaft seems nice and snug
The thing with the water based degreasers is that they need to be pretty much boiling hot all the time, and there needs to be plenty agitation for them to work properly. Both of these you will find hard to acheive with those type of machines. The industrial machines I have used with water based degreasers have all worked amazingly well.
http://www.partswash.com/hercules.html
Scruffy
Member #: 328
Seaford Rise, South Australia
I tried adding water it f*cked it. If you add water it wouldn't wash a bogey off your finger! I ended up using it neat and even then was shite
On 5th Sep, 2011 Vegard said:
Mr Joshua
Member #: 1954
Luton Bedfordshire
What's wrong with a dish washer put my block head and rods in it last week they all came out astonishingly clean
Own the day
Wile E. Coyote
Member #: 7893
Portsmouth
Hey all, thanks for your comments, now that is what I call a parts washer Sprocket :) to be honest though the radius arms seem to be cleaning up ok with it :)
Jamie.
The water diluted cleaner from M/Mart is rubbish. I bought the solvent stuff they do, this is quite good.
Flame Red
Member #: 6267
These are all reasons why my parts washer has become a surface to put stuff on, I now wash everything in the sink with really hot water. I do intend to buy a heated parts washer, I would be interested to know how much they cost.
almichie
Member #: 2065
Parts washer + heater element!
How about this.
http://www.ebay.co.uk/itm/bosch-classixx-d...=item4ab0c6d6df
almichie
Member #: 2065
You could fill it with cleaner and block the drain off and hey presto a proper cleaner!!
I am sure jim has one.
Wile E. Coyote
Member #: 7893
Portsmouth
Hey all, thanks for your comments, My Parts Washer does say do not use Flamable Cleaners with it, especially PARAFFIN, Has anyone else got the same type of Clarke Patrts washer ? basically can i use Paraffin with it, even though it tells me not too *smiley*
Jamie.
Wile E. Coyote
Member #: 7893
Portsmouth
LOL ! Enough said...... *smiley*
Jamie.
Wile E. Coyote
Member #: 7893
Portsmouth
And well said at that!
Jamie.
On 18th Nov, 2011 Wile E. Coyote said:
Hey all,
Thanks All,
Jamie. *happy*
You do not put any water at all in there !! Use a proper degreaser only.
Afterwards you can use water to final clean outside the tank and wash the degreaser off. But only proper degreaser is used in the tank.
Alex
Member #: 1851
Woolavington, Zummerzet
I've got both that model and the small bench top version, and they work fine with Jizer in.
A friend used the waterbased stuff, and while it worked okay to start with, it ended up going disgustingly mouldy.
