Home > Beginners Tech > what clutch
matt-atude
Member #: 8913
seaford, east sussex
going to build a powerful a series engine hope to see 160hp in early planning stages wanting to pick brains, are people using verto or pre verto clutches. looking at med lightened verto flywheel and a vmax 220lb verto clutch, just want to know what others are using?
matt
RTS.
Search for "clutch thoughts"
matt-atude
Member #: 8913
ok will do
yes you don't need the med one.
matt-atude
Member #: 8913
right been reading through the posts on the rts clutch seems like its proven to work and seems like a few of the the guys on here are using them. so I'm going to build one just a few questions. what pressure plates are people using one on clutch thoughts was a 1275 and a 998 one. seems to be mixed views on how hard the clutch pedal is? also do you get lots of wear on the thrust plates? any other things to consider when building one of these clutches? bolts, spacers washers ect? also what flywheels are people using? standard or lightened, i was thinking of using the MED ultralight steel flywheel?
any input appreciated
cheers matt
im on lightened minispares flywheel
ap racing plate
turbo spring + 1275 spring
not had an ounce of slip yet
matt-atude
Member #: 8913
how do you find the pedal? is rock hard or a little bit harder than normal? also have you had any problems with thrust washers or gearbox issues?
im aiming for 160bhp and 160pounds of torque
cheers matt
Edited by matt-atude on 1st Feb, 2012.
jamie@thefatgarage
Member #: 9345
Sheffield
Due to the way it operates, Verto only puts 1/3 of the clamping pressure on the thrusts, which is why RTS or a strong spring verto is better for bearings than pre verto. Pedal is light on mine which is not RTS, but a very heavy duty verto spring.
Jack2eaton
Member #: 9772
Sheffield
I have been advised to switch my verto clutch for a pre verto mechanism. Switching the whole thing seems like a pricey way to go around it. But as the one I have is standard from an mpi. Would it be a cheaper option to go down this route than to switch to a pre verto system?
probably advised by someone not up to date with modern techniques + rts can be had for cheap if you can get the parts cheap ( eg ive had complete flywheels, cluch mech, ring gear the lot of ebay for 20quid posted) and 5er for parts at auto jumbles
with the mpi unit you already have thats half the parts there..
my peddle in my opinion is not heavy but then i am not small either however my brother cant press it though ( good anti theft devise *happy* )
one thing i can say it is alot lighter on the foot compared to the equivalent clamping force of a pre-verto system
if peddle force is a concern verto is the only answer to holding decent power
there is also the thrusts issue that a heavy pre-verto munches the thrust washeres
bennyy
Member #: 9037
Doncaster, yorkshire
Rts cost me £30 for 2 clutches, £5 for bolts, £60 for the ap racing clutch plate, and a tenner for Brett to build it :p and I have a minispares lightened flywheel too, about £130-£140 IIRC.
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
my wife could have driven the metro van with the rts on it. we used 2 998 springs and it was fine with 20+ psi
hazpalmer
Member #: 9038
Carlisle, Cumbria
And will he going into my engine this winter
bennyy
Member #: 9037
I used two 1275 springs, fairly heavy but still useable no problems.
if the pedal is a problem then the arm on the wok can be lengthened to lighten it.
roberts domne this and it fee'ls like a std 998!
mine feels about the same as an orage plate.
I can recommend the MED lightened verto flywheel. The latest one I got from Minispares was very poor machining quality.
If you are usig MPi then you need a special flywheel.
http://www.med-engineering.co.uk/catalogue...ion-ultra-light
bennyy
Member #: 9037
When did you get this Paul? I remember a thread a while ago about the machining on them, but I thought they had sorted it as mine was fine?
Jack2eaton
Member #: 9772
Sheffield
Forgive me for lack if knowledge but what is the rts?
search for "clutch thoughts"
bennyy
Member #: 9037
Robert twin spring, basically its a clutch built up using 2 spring plates.
Here's the link, saves John writing clutch thoughts over and over.
Edit: link would help .. http://www.turbominis.co.uk/forums/index.php?p=vt&tid=10207
Edited by bennyy on 2nd Feb, 2012.
A few months ago. August 2011.
mine was perfect, the only part of my rotating assembly that did not need a fettle
Im using 2 turbo springs in mine and the pedal still feels lighter than a pre verto on a grey diaphragm.
Just make sure you don't use the friction plate with springs in the centre, mine last an 1/8th of a mile driven in anger. lol
ntm1275
Member #: 9395
If I got all the parts, would someone build one for me - I'd pay them obviously
Edited by ntm1275 on 2nd Feb, 2012.
matt-atude
Member #: 8913
cheers guys, ordered a steel lightened verto flywheel from MED today goin to make a start on the rts this weekend. i got a turbo clutch in at the moment and has been fine with 130bhp and 135ftlb torque so will be adding a 1275 spring to that. iv seen some people using just bolts and some using nut and bolts? I'm guess a good quality thread lock is a must. also what type of bolts are people using?
many thanks
matt
