| Home > Help Needed / General Tech Chat > O/T Drying out a dampish cellar | |||||||
15th Dec, 2011 at 01:39:57pm
Making an effort to clear the cellar out and get it organised enough to put a pool table down there (and the obligatory beer fridge).
272 Posts Member #: 9125 Senior Member Sheffield, South Yorkshire |
15th Dec, 2011 at 01:48:10pm
Get your self a nice big industrial heater and leave it running, along with the dehumidifyer. Should do the trick. The turbo build has finally started |
15th Dec, 2011 at 01:48:42pm
Your gunna build a lambo down there arent ya 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
![]() 233 Posts Member #: 863 Senior Member Lathom, lancs |
15th Dec, 2011 at 01:48:56pm
Well cat litter absorbs moisture in damp cars... lol
Edited by MINIMON on 15th Dec, 2011. |
15th Dec, 2011 at 01:49:39pm
Thanks Liam.
15th Dec, 2011 at 01:49:46pm
all well and good but what about the source of the damp?
15th Dec, 2011 at 01:53:46pm
It wasn't bad when we moved in 3 1/2 years ago.
15th Dec, 2011 at 01:53:51pm
My thoughts exactly.
On 15th Dec, 2011 wolfie said:
all well and good but what about the source of the damp? Fastest 998 mini in the world? 13.05 1/4 mile 106mph
15th Dec, 2011 at 01:59:26pm
Have you got solid concrete floors above or are they timber? If they are gimber you need to check for rot on the ends of the joists where they tie into the wall. The turbo build has finally started |
15th Dec, 2011 at 02:12:20pm
yeah, dehumidifier, they do pull the water out of the air well,
15th Dec, 2011 at 02:16:27pm
Concrete floors.
15th Dec, 2011 at 02:21:39pm
I've got the next model up from you. Prob won't need it when I move if you want to borrow it for a while. If something is worth doing, it's worth doing half of. |
15th Dec, 2011 at 02:47:02pm
finding the source of ingress/ moisture would be a huge help although basements can be inherently damp. There are systems you can get to line the place but i'm not keen on them |
15th Dec, 2011 at 03:19:26pm
On 15th Dec, 2011 John said:
I've got the next model up from you. Prob won't need it when I move if you want to borrow it for a while. That would be good
Rob - I think it's just a hangover from Lisa's little accident. A lot of it has been trapped in the carpets etc that have been left down there. They are all languishing at the tip now. It doesn't feel particularly damp any more, but there is over an inch of water the dehumidifier's bucket collected in the last 4 hours. I think some of it is more psychological with the cracking paint and a couple of bricks where the faces have blown slightly. EDIT: It's split into 3 rooms, the two smaller ones are dry (one has half my mini, the other has all of wifey's wine...). It's just the main room that got flooded that's the problem. Edited by apbellamy on 15th Dec, 2011. On 11th Feb, 2015 robert said:
15th Dec, 2011 at 03:55:21pm
Perhaps something like a paint that seals against water would help stop the water ingress?
15th Dec, 2011 at 04:01:17pm
Damp proof paints are really only any good if you have solved the problem with water ingress before you apply it. Otherwise the water just ends up stuck in the brick work... On 11th Feb, 2015 robert said:
15th Dec, 2011 at 04:10:11pm
True, but the brickwork is never truly dry underground, nor is concrete. The stuff may set but its only ever as dry as the soil/ground around it. Eventually it will all drain away from the house, Just a suggestion to get the cellar dry a bit quicker On 26th Jan, 2012 Tom Fenton said:
15th Dec, 2011 at 05:14:39pm
if that is the case then air circulation is what you want as well
Rob - I think it's just a hangover from Lisa's little accident. A lot of it has been trapped in the carpets etc that have been left down there. They are all languishing at the tip now. It doesn't feel particularly damp any more, but there is over an inch of water the dehumidifier's bucket collected in the last 4 hours. I think some of it is more psychological with the cracking paint and a couple of bricks where the faces have blown slightly. EDIT: It's split into 3 rooms, the two smaller ones are dry (one has half my mini, the other has all of wifey's wine...). It's just the main room that got flooded that's the problem. |
15th Dec, 2011 at 06:30:36pm
There's a vent brick in one corner. Would an extractor on that be a good plan? On 11th Feb, 2015 robert said:
15th Dec, 2011 at 06:41:01pm
That wont solve the Problem of the brick work being damp as the brick work is set into ground which is damp and are solid walls. If there was a cavity then you wouldnt have as much cold/damp in there. You could once fully dried out look at having the room tanked. That way it will stop the damp coming into the room and also help to keep it warm. If there is an airbrick in there gow high off the ground is it? You may find that in heavy rain it lets water in. If so you can block the bottom row of holes up. The turbo build has finally started |
15th Dec, 2011 at 06:45:11pm
get some duct tape over the air brick and any other air outlets for a few daysand keep the dehumidifier running, get it properly dry then you should be able to see if there anre any problem area's where damp is getting in. On 28th Aug, 2011 Kean said:
15th Dec, 2011 at 06:54:42pm
There is a cavity, but it's not big - less than 50mm in places so no room for cavity insulation On 11th Feb, 2015 robert said:
15th Dec, 2011 at 06:58:21pm
You want air circulation. Think about trying to dry the wall out first, and keep the dehumidifier running, and ideally if you have one of those blow heaters, just set it to cold to save electricity and let it blow across the wall/floor. On 26th Jan, 2012 Tom Fenton said:
15th Dec, 2011 at 06:58:49pm
Ye the new regs say a min of 50mm i think which is 2 courses. So try blocking the bottom run off. If you can i would avise tanking it especially as you are wanting to use it. I will get an estimated m2 rate for you tommor if you like? Could then work out how much it would cost. Or send me a measure and il have a look for an estimate. The turbo build has finally started |
15th Dec, 2011 at 07:12:57pm
TBH I'm not going to spend any money on it. Just want to get it a bit drier.
