| Home > Help Needed / General Tech Chat > Weld sealer / joint sealant | |||||||
![]() 481 Posts Member #: 7893 Senior Member Portsmouth |
22nd Dec, 2011 at 12:47:42pm
Hey everyone.
22nd Dec, 2011 at 12:57:55pm
Normally called seam sealer - the same as you'll find on all the seams from the factory build.
22nd Dec, 2011 at 01:03:08pm
I used Tiger Seal it makes a right mess
22nd Dec, 2011 at 03:05:17pm
Jesus christ Si, thats not so much a sealant, moreso an adhesive. Fair enough if you had some lying around to use, but i hope you didnt buy it for that purpose lol.
22nd Dec, 2011 at 04:25:04pm
i use the sika cartidge seam sealer and mask off the areas to be treated and then use a cheap brush to finish it all off |
22nd Dec, 2011 at 04:39:13pm
Grey stripe seam sealer its shit hot 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
22nd Dec, 2011 at 05:21:48pm
Haha, no the tube gos a long way mate, I was like a 5 year old at play school when i was done.
22nd Dec, 2011 at 05:32:08pm
I use the brushable stuff. Use a good quality 3/4" brush and load it right up, and apply with a slow single pass, keep loading the brush. This will give you an almost identical appearance to the factory application. If you decide to use the tubes, as Rod suggests, apply it from the tube, with a nice thick bead, don't scrimp on it, and then, again with a good quality brush with a slow single pass, smooth the bead of sealer out into a ~1" wide strip.
22nd Dec, 2011 at 05:41:38pm
Primer before application? On 11th Feb, 2015 robert said:
22nd Dec, 2011 at 06:35:05pm
No reason why and no reason why not. One thought though, I used some industrial Red oxide on the underside, and the solvent in the seam sealer disolved the paint, so if anything the red oxide and the seam sealer are now well bonded to each other On 26th Oct, 2004 TurboDave16v said:
22nd Dec, 2011 at 06:59:53pm
Trying to decide if I do that myself or let Rick do it when he paints it... On 11th Feb, 2015 robert said:
22nd Dec, 2011 at 07:11:56pm
I do the same as Sprocket.
22nd Dec, 2011 at 07:38:24pm
I used tiger seal on the mk1 and the finish was brilliant. You need to apply it like you would a bathroom silicon sealant, then just finish it with your finger. Have a damp clotch to wipe your hands on and it doesn't go everywhere. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
22nd Dec, 2011 at 09:03:21pm
I also used tiger seal, I always wear rubber gloves, if it dries on your hand its a nightmare to get off. Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
23rd Dec, 2011 at 12:08:20am
Hey all,
23rd Dec, 2011 at 04:17:31pm
You can tape off areas so the seam sealer is applied neatly.
Edited by stevieturbo on 23rd Dec, 2011. 9.85 @ 145mph
27th Dec, 2011 at 08:13:37pm
Thanks fella,
27th Dec, 2011 at 09:01:08pm
Tiger seal is alot harder to get hold of than it used to be. I went to my local paint supplier that used to sell it, and they sell another sealant now, made in the same factory but just wasn't called tiger seal...exactly the same stuff but half the price! lol
27th Dec, 2011 at 09:21:05pm
Ok thanks, will try local paint shops.
Edited by Wile E. Coyote on 27th Dec, 2011. My 79 Clubman Build Thread - http://www.turbominis.co.uk/forums/index.php?p=vt&tid=451008
27th Dec, 2011 at 09:28:34pm
My shell had rust underneath the sealant, and where the sealant finished the rust finished.
Edited by matty on 27th Dec, 2011. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
27th Dec, 2011 at 10:07:44pm
Not using it to bond panels, 100% just for sealing the welds.
27th Dec, 2011 at 11:04:43pm
I used U-pol etch primer, then the sealant, then another coat of etch primer over the sealant, then 2k filler primer. If you get a good quality primer, it will have rust inhibitors in it so there should be no need for red oxide in any case.
28th Dec, 2011 at 08:15:36pm
sikaflex and another no name polyurethane sealer where pretty hopeless holding my door skins on ,this may have something to do with the sun heating the ally sheet up though . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
28th Dec, 2011 at 08:31:48pm
Edited by Wile E. Coyote on 28th Dec, 2011. My 79 Clubman Build Thread - http://www.turbominis.co.uk/forums/index.php?p=vt&tid=451008
7th Feb, 2012 at 05:42:42pm
Just about to start this in about half hour, my plan is to literally cover every joint, seam, weld on the underside.
