| Home > Help Needed / General Tech Chat > Cluch Oil Seal | |||||||
8th Jan, 2012 at 06:13:35pm
Hi Wondered if you could give me some expert advice.
8th Jan, 2012 at 06:20:54pm
What is the bush at the engine side of the primary gear like? That one will allow more movement than the front one (which looks OK to me). On 11th Feb, 2015 robert said:
8th Jan, 2012 at 07:07:50pm
Here is the pic from the other side. I didnt feel and movement on the crank?
Edited by gr4h4m on 8th Jan, 2012. I run a supercharger and I don't care the TB is on the wrong side.
8th Jan, 2012 at 07:13:26pm
8th Jan, 2012 at 07:26:30pm
Opps sorry mate, The seal looks good, i just doesnt seem to be doing its job...
8th Jan, 2012 at 08:04:39pm
They look OK to me. Is the hole in the transfer case OK? On 11th Feb, 2015 robert said:
8th Jan, 2012 at 08:05:53pm
Is the bush worn, allowing the primary gear to move about? On 7th Oct, 2010 5haneJ said:
8th Jan, 2012 at 08:57:07pm
I have been out and measured with a feeler guage between thrust washer and primary.
8th Jan, 2012 at 09:08:05pm
Measure the C clip and it's thrust do dah. We found the one on the van was worn and allowing the primary gear to move about more than is desirable. I should have a couple of 998 ones throwing round I can measure for you if needs be. On 11th Feb, 2015 robert said:
8th Jan, 2012 at 09:17:43pm
the bronze thrust washer measures 0.1155"
8th Jan, 2012 at 09:22:38pm
I need to get another set of feelers as I could only measure with one set which might be getting a false reading.
9th Jan, 2012 at 07:59:39pm
Ok armed with two sets of feelers I measured the float to be 0.004" so that looks within spec.
9th Jan, 2012 at 08:12:53pm
I've got a spare a series 1275 transfer housing (extra breather might be useful) if you want and probably 998 a transfer gear or two. On 11th Feb, 2015 robert said:
9th Jan, 2012 at 09:30:12pm
Good point andy!
9th Jan, 2012 at 09:31:56pm
Thanks Andy, but I cant face stripping the engine. Its been bolted together since about 1969, I have always felt that if I strip it it should be to rebuild as oher wise its not realy worth the hassle? Thanks for the offer, the gear looks ok and I'm nit picking realy.
10th Jan, 2012 at 07:26:57am
The transfer case is just sat in a box in the shed if you change your mind at any point. On 11th Feb, 2015 robert said:
10th Jan, 2012 at 09:17:07am
Thank Andy
114 Posts Member #: 9645 Advanced Member South Wales |
10th Jan, 2012 at 10:41:27am
I have a new primary gear I could measure the bush/outer diameter if that's any use. I only have a vernier that's accurate to 0.05mm though.
10th Jan, 2012 at 01:46:43pm
I think an extra breather at this end could be a fix.
10th Jan, 2012 at 01:53:37pm
sounds plausible. It's only a hand full of bolts and a gasket to change it... On 11th Feb, 2015 robert said:
10th Jan, 2012 at 07:19:21pm
Minivan yes please if you could measure it it would be great.
10th Jan, 2012 at 07:35:00pm
If you've got the clutch out with the engine in, then the transfer case should be a piece of cake. On 11th Feb, 2015 robert said:
10th Jan, 2012 at 08:02:55pm
Andy I can't see you getting it past the crank with the subframe in the way. I'm also worried about what it will find behind it. I imaging springs, cogs, ball bearings and magic wizzardry holding it all in the right place. :) I run a supercharger and I don't care the TB is on the wrong side.
10th Jan, 2012 at 09:14:25pm
Nope, it just lifts away. You'll get it of if you lift that side of the engine as high as possible.
10th Jan, 2012 at 09:55:18pm
I've measured the new and an old primary and there is no difference with the measuring gear I have. Ideally need a micrometer.
