Home > Help Needed / General Tech Chat > clutch change (aka spanner sizing thread :D )
wez
Member #: 9271
Stoke on Trent
is it possible to change a verto clutch with the brake servo in place on a standard roundnose with all inner wings etc?
Edited by wez on 5th Feb, 2012.
one day boost will be mine!
On 10th Mar, 2012 Joe C said:
Ben H
Member #: 184
Melton Mowbray, Pie Country
Yes, I have done it several times.
http://www.twin-turbo.co.uk
wez
Member #: 9271
Stoke on Trent
i imagine its a pain in the arse though?
Changing a clutch in place is an arse. But an 11mm flexi head ratchet spanner would be an invaluable tool for removing the bellhousing bolts. I wish i had access to one when i changed one last in car. And undo the o/s mount and all steadies and jack the clutch side up as much as you dare.
wez
Member #: 9271
Stoke on Trent
i know the bolt around the back of the wok is a pig to get out, most people dont put it back in either. i just looked under the bonnet and there just doesnt seem much room at all under the servo, just wanted to make sure i wasnt pissing in the wind before i started. as the new daily ive been to see tonight and am picking up next week has a slipping clutch.
I would check all the hydraulics too mate, happened to me at avon, clutch slippage, thought it was the clutch plate worn, took it all apart and it was fine but glazed over, replaced loads of stuff, put it all together and the clutch was still crap, Ended up changing the master & slave in the end. Worked out that when depressed the clutch was slightly dragging, which glazed the plate over, hence causing slippage. Just something to consider :) I only had the easiest 5 bolts to get to back in, as the bottom section is held in via the weight of the engine pushing against the bellhousing. Not advised on a heavy clutch though.
Edited by Carlzilla on 3rd Feb, 2012.
There are no 11mm headed bolts on a mini engine....
wez
Member #: 9271
Stoke on Trent
I'm thinking I might change the Hose for a new one first and bleed it up. I remember reading the other day about the hose collapsing inside and not letting the fluid return properly.
Ben H
Member #: 184
I don't remember it being that much of a pain. I normally remove all the nuts holding on the servo sto that it can be pushed out of the way, but leave the pipes connected.
jamestar
Member #: 9159
Devon
changing the clutch is not too bad in situe - changing the primary gear and removing the transfer case on the other hand is a right bitch!!
With mine i have braided hoses going from the servo to the brake bias valve thingymabob, so i usually just unbolt the servo from the servo bracket and move it out the way.
and like others have said, removing the wok bolts can be a pain too. If you jack up the engine this will give you some more room
Plenty of people substitute 1/2 for 13mm as and when. And 11mm is pretty much identical to 7/16. So it fits perfectly. I have never ever had a problem with it. The reason i say 11mm, is because nobody sells flexi ratchet spanners that i know to in AF.
Edited by Carlzilla on 4th Feb, 2012.
Close but not exactly the same. You will end up damaging the heads on your bolts...
Granted i only use my 13mm ratchet spanner on bolts i have already cracked off using a 1/2" spanner for that reason.
But if you look up the 7/16 to mm it comes out at 11.1125
So technically an 11mm spanner should not fit. But it fits perfectly, probably due to tolerances in toolmaking (if there are any)
Anton
Member #: 764
Staffordshire
agreed... use the right too for the job... AF tools are easily available
Find me some AF flexi head ratchet spanners?
I'm not being arsy, but for undoing certain things they make life 10000% times easier, rather than taking a spanner off and back on 1/8 turn at a time.
Ben H
Member #: 184
I use metric on imperial all the time. Its fine for anything not tght, but will round heads after a while. Little bt OT now though.
bennyy
Member #: 9037
Doncaster, yorkshire
Wrong thing to say, but I also use metric spanners and sockets, and I have rounded one nut before, but everything else is fine.
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
dev 11
Member #: 9393
stoke on trent
i have a set of snap on flank drive imperial offset ratchet spanners, and set of snap on flank drive metric, and the 1/2 will not fit on a 13mm. vice cersa
tolerance in cheap tools causes damage, iv never had a problem with snap on tools. get the right kit and you can do the job twice as fast.
also, i use braided hoses on the servo wez so that just plonks onto the os wheel.
dev 11
Member #: 9393
stoke on trent
http://www.esedirect.co.uk/p-3132-signet-s...panner-set.aspx
cheap too, and lifetime warranty
Cheers, I'd looked for a while for something like this but gave up.
evolotion
Member #: 83
Glasgow, Scotland
if you do the change, slot the bottom holes in the wok :) so you dont have to undoo the 11mm (*tongue*) bolts fully in future
Denis O'Brien.
Good link. I'm having a set of them. Actually fook that, postage is £10, so makes them £53 with vat. Way too much for me....
Got to change the clutch on Davo's mini with inner wings so no doubt they will be helpful...
Edited by apbellamy on 5th Feb, 2012.
Ben H
Member #: 184
If you 13mm doesn't fit on a 1/2" there is something wrong with you 13m, IMO.
You can get the metrics individually from halfrauds, about £13. 11mm is a perfect fit.
wez
Member #: 9271
Stoke on Trent
I've got a set of Stanley spanners which have a funny open end on which drives off 3 of the flats buy lets you pull the spanner backwards around the head of the nut without taking it off. Not a ratchet spanner but works to the same effect once the nut is cracked as you can't get a good purchase with them, have to use the ring end first.
