Home > General Chat > De-seamed and smoothed
1994alex
Member #: 9757
Solihull
I was wondering if anyone had any pictures of a de-seamed or smoothed or even both minis
Alex
jamie@thefatgarage
Member #: 9345
Sheffield
http://photobucket.com/jamiesminibuild
1994alex
Member #: 9757
Solihull
Thats exactly what i was looking for and its a clubman BONUS!
What did you use to de seam it?
still has the roof gutter.,.
1994alex
Member #: 9757
Solihull
That looks great *happy* how did you do it?
Alex
that clubby looks very nice james!!
Alex, its had 78mm cut out of the body, then deseamed,
ntm1275
Member #: 9395
Below are some diagrams of each stage of de-seaming
All this is done in 6 inch sections - do not cut of the whole seam in one go
Also, do 6 inches, them miss 6 inches, then do the next 6 inches - then return to the start and do the missed sections
If doing the roof, do 6 inches in one place then move to a different part of the roof and do another 6 inches, working your way around until all is done, this is to stop too much heat from distorting the roof panel
1. Seam after seam strip removed
2. Cut off the seam leaving about 2 millimeters proud of the surface - this is so that you have something more substantial to weld to - if you cut it flush, you will not get the penetration, and you'll burn holes through
3. weld the 2 millimeters of metal with the highest setting before you blow holes through the metal - if you have access to any sections of the back of the seam, you can weld from the inside as well for greater strength
4. Using a hammer, tap the weld so that the metal starts to folder in on itself - keep tapping until the weld is below the surface of the original position
5. Fill over the top
Edited by ntm1275 on 8th Feb, 2012.
for the rear vertical seams, weld them up the inside first. looked dead easy when nic did it
if i build another shell it shall be deseamed
t@z
Member #: 452
Chester, UK
dont remove the roof gutter, my first clubby was deseemed (piccy maybe on here somewhere) and it was a cunt in the rain leaking through
Edited by t@z on 8th Feb, 2012.
www.twitter.com/lilpinkiy
1994alex
Member #: 9757
Solihull
Has anyone else had this problem?
t@z
Member #: 452
Chester, UK
i think its a common problem as water runs down between the door and if your door seals are rubbish its coming in sadly.
also the door frames crack at the point where the window meets the door skin and there is naff all clamping pressure against the door seals
wez
Member #: 9271
Stoke on Trent
When ever I've read up about deseaming it's always been advised to leave the roof gutter on.
one day boost will be mine!
On 10th Mar, 2012 Joe C said:
1994alex
Member #: 9757
Solihull
Ah right "/ thats that plan out the window if its a bad idea to de seam the roof
Advantage
Member #: 1450
Near Paris - France
Maybe do the deseaming only on the front and rear of the roof ?
Renault 4L springs to mind, there was a gutter only along the sides, the front and rear were flush.
This setup shall help with aerodynamics too ...
Rusty by nature
They just look shit if you touch the roof gutter
Like a metro....
5portsrock
Member #: 2023
nr Portsmouth ,Hampshire
Hi, i deseamed the sides and the roof , I removed the seam from an early metro and adapted that so it went partly down the front edge of the door and above the top of the door to stop the leaks. using the metro seam loked alot smoother than just leaving part of the mini seam
5portsrock
Member #: 2023
oops double post
Edited by 5portsrock on 8th Feb, 2012.
1994alex
Member #: 9757
Solihull
any pictures?
jamie@thefatgarage
Member #: 9345
Sheffield
I've had a jet wash round mine and it doesn't leak. Doors are in good nick and the seals are new. Had to bend the tops of the door to make sure they were straight. Not that it will get much use in the winter.
1994alex
Member #: 9757
Solihull
What technique did you use?
I know that some people have done lead loading....
jamie@thefatgarage
Member #: 9345
Sheffield
You only use lead loading if you have a beard and take you car to shows on a trailer to keep the tyres clean, or are american. It's plated and welded on the inside where accessible and smoothed off on the outside. Bit of filler to finish. It's easy really, just very time consuming. After you've done a couple of feet you wish you'd never started!
1994alex
Member #: 9757
Solihull
Any pictures of the process?
