Home > Help Needed / General Tech Chat > duplex with a tensioner?
Ben H
Member #: 184
Melton Mowbray, Pie Country
Having never run a duplex it looks odd to me without a tensioner. Do people put a tensioner on or not bother? All other cars I have are simolex or belt.
Ben
http://www.twin-turbo.co.uk
Mine has a tensioner on a duplex.
It seems weird not to.
dig-mini
Member #: 9269
Rotherham
So does mine
Craig
IMO any timing drive should have a tensioner.
jamestar
Member #: 9159
Devon
mine does also!
duplex no tensioner.
Duplex with tensioner
Ben H
Member #: 184
I think I'll stick a tensioner on then.
and me.
None of the major engine builders fit them, neither do I. They arent wide enough to support all 3 rows of links so it just puts pressure on the inner one which strains the pins, though Ive never heard anything bad happening because of fitting them
i broke my tensioner trying to fit it, and the chain felt tight enough
alas i never fitted one
bennyy
Member #: 9037
Doncaster, yorkshire
I do not have one, benross said there was no need.
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
Ben H
Member #: 184
Well now I'm thinking I won't bother. It would be easier without and the engine is so noisy anyway I doubt I will hear a little rattle. Decisions, decisions.....
I've fitted one and it was wide enough to cover all three rows of links (but only just).
tadge44
Member #: 2500
Buckinghamshire
I,ve been fitting tensioner/duplex for years with no problems.
(Other than when one of the countersunk screws came loose and broke the chain !)
Don't bother Ben. Think of the weight. If it rattles and is annoying, fit one later. It's an easy job with no front bodywork and a front rad.
johnK
Member #: 690
Norfolk
I always run them, I'd rather have accurate control over the cam timing, than random scatter, running without a tensioner is to cam timing what a dizzy with worn spindle bearings is to ignition scatter - not desirable!
If Carling made Mini engines
JTBush
Member #: 1120
Durham
With tensioner. Without your cam timing can be affected as the chain whips about about at different engine speeds on the tensioner side. Dont know why you wouldnt fit one really, seems silly not to.
Theres a video somewhere of a K20a type r Chain (longer chain I know) with the tensioner fitted and you wouldnt believe how much the chain jumps about, and thats dampened.
Ben H
Member #: 184
I wonder just how much it would affect cam timing. Concidering the load on the cam, the short chain and I can't see it being much. Has anybody measured it or is it all just speculation?
I can see the unloaded side of the chain flapping about, but that won't change the cam timing so who cares?
Still undecided.
The Kent timing set that Swifty sells are designed to eliminate chain whip. Mine has no movement in it at all still after 2 years of use so no affect on timing.
Seems ridiculous to me to fit a tensioner that doesnt fit the chain properly
Ben H
Member #: 184
Mine does have a little movement. I think I will try without and see how it goes. Also I don't hae a tensioner in the garage so that biased the decision a little.
my thoughts are the same as pauls
if a duplex tensioner were available i would consider fitting them, but no bother at all with out one one
welshdan
Member #: 1111
s wales
i use one on my engines. the timing chain just seems too slack without. though many people run without, as shown in this post, i think its a matter of personal preferance
Ben H
Member #: 184
It should not be a matter of personal preference. There is a better way, but we have no data. Choosing a colour is a personal preference.
If you have the Backplate and Cover to suite the Tensioner then fit it.
Its like carrying condoms. Better to have them and not need them than need them and not have them.
