| Home > General Chat > which gauges | |||||||
16th Feb, 2012 at 11:51:27am
I am after a set of gauges, boost oil temp oil pressure and possibly water temp, I currently have cheapo shit electronic autogauge ones, to be Frank, there shit, but that's why they are £20 odd each. These have put me off electric gauges to be honest, could not seem to wire them in properly. I would prefer mechanical, but let's see what you have to say. I thought about getting all aem gauges, no real wiring, just plug and play, but there just a bit too expensive
Edited by bennyy on 16th Feb, 2012. Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
16th Feb, 2012 at 12:14:42pm
I've got a mix of Tim, SW and AEM.
In the 13's at last!.. Just |
461 Posts Member #: 9229 Senior Member newcastle upon tyne |
16th Feb, 2012 at 12:21:21pm
I've got auto gauges & had no problems with mine all work fine for me |
16th Feb, 2012 at 12:28:08pm
TIM = SHITE!
![]() 2054 Posts Member #: 452 Post Whore Chester, UK |
16th Feb, 2012 at 12:31:57pm
i've got smiths, centre clock and dual oil pres/water temp gauge and a superchips (oh yeh!!!) boost gauge off ebay for cheap chips :) all looks snazzy |
![]() 730 Posts Member #: 1791 Post Whore Cranleigh, surrey |
16th Feb, 2012 at 01:03:59pm
I had autometer from the states, if you buy all of them there worth it, I had speedo, tach, boost, oil pressure, water temp, so after the import tax and shipping it worked ot fairly cheap still, got them from summit racing. "Cars are a lifetime of pain" |
16th Feb, 2012 at 01:10:16pm
I've got racetech from merlin for my oil/coolant gauges and am analogue for.my boost/afr On 11th Feb, 2015 robert said:
16th Feb, 2012 at 01:14:29pm
i have autometer direct from the states all mechanical bar the tacho
16th Feb, 2012 at 01:14:59pm
I was looking at the stack ones, the cheaper range seem to go from £35-£50 each, don't seem too bad. Audi s4 b5 - 470bhp & 486ft lbs
16th Feb, 2012 at 01:36:53pm
my cheapo ones are unplugged Yes i moved to the darkside |
16th Feb, 2012 at 01:51:46pm
I like the sound of that, just had a browse and the autometer boost gauge only goes upto 20psi?
On 16th Feb, 2012 wolfie said:
i have autometer direct from the states all mechanical bar the tacho Audi s4 b5 - 470bhp & 486ft lbs
16th Feb, 2012 at 02:21:58pm
30psi
16th Feb, 2012 at 02:22:31pm
30 psi
16th Feb, 2012 at 02:40:05pm
Thanks both of you, my bad.
16th Feb, 2012 at 02:41:21pm
Where's your AEM going? If something is worth doing, it's worth doing half of. |
16th Feb, 2012 at 02:53:46pm
My aem is in a pod on the dash, right in front of me, much better position for glancing and you can see the colours in the corner of your eye so you know what's happening
![]() 1434 Posts Member #: 8466 Post Whore Mansfield |
16th Feb, 2012 at 02:57:58pm
Why dont you get the matching AEM ones? Class C 3rd Place Avon 2011 14.18 @101mph |
16th Feb, 2012 at 03:00:27pm
you may struggle with senders for the race tech oil/coolant temp sensors as they are 3/8 bsp. I have the coolant in the sandwich plate under the thermostat and the oil in the extra sensor hole on my mph block.
16th Feb, 2012 at 03:04:54pm
Says in his first post matt that the AEM's are too dear. If something is worth doing, it's worth doing half of. |
16th Feb, 2012 at 03:37:07pm
The aem ones are great, nit sure I can justify spending £400+ on 3 gauges
16th Feb, 2012 at 04:57:40pm
How thick is your oil sandwich plate? might be able to drill/tap it out to 3/8 bsp as the sensor needs to be in the flow of oil.
16th Feb, 2012 at 05:09:19pm
if the sensor is npt i can run a die down it for you to make it bsp
16th Feb, 2012 at 05:45:17pm
How about ETB gauges? ive got the digidash and the quality is excellent. The aux gauges look good too!
16th Feb, 2012 at 06:35:29pm
https://www.europaspares.com/6/GAUGES.html
17th Feb, 2012 at 06:11:33am
Had a browse on eBay and there are 3/8bsp>m12, dsn sell one in m12 also so that's water temp sorted.
Edited by bennyy on 17th Feb, 2012. Audi s4 b5 - 470bhp & 486ft lbs
