Home > Help Needed / General Tech Chat > Misfire on idle and low revs but fine on boost
Tonywells
Member #: 343
Hi
I drove my metro turbo last nite and after about half an hour it started sounding like an Subaru at low revs but seems fine at higher revs and on boost.
It struggled to idle.
The engine has been freshly built to standard specs and there was no smoke while driving it.
Im thinking it feel like an ignition problem but has anyone got any other ideas?
almichie
Member #: 2065
I've had the opposite recently and it turned out to be fouled plugs - have you fitted new plugs? What are they?
Have you got an afr gauge fitted? Could be fueling
Shaft seems nice and snug
Tonywells
Member #: 343
Plugs are NGK bpr7es and are only about 100 miles old.
The car has only just been rolling roaded so I would guess the fuelling should be fine.
I will check the plugs when I get to my garage. I think I have a spare set.
I don't have an afr gauge.
Rocker come loose?
Mr Joshua
Member #: 1954
Luton Bedfordshire
Sticky valve syndrome.
Own the day
ngk's dont like having fuel on them IMO.
deffo give them a change
Tonywells
Member #: 343
Just done a compression test and number one is low.
Put some oil in and it didn't change.
Once everything is cool I will check the valve clearances.
scott the joiner
Member #: 9229
newcastle upon tyne
Valve not seating correctly was the head rebuilt?
Tonywells
Member #: 343
Just check the valve clearances and it made no difference.
I checked the compression again and now it raised with oil in the bore so I think it a piston or ring?
The head was not rebuilt, its the original 37k head.
How would I check for a sticky valve? Head off??
scott the joiner
Member #: 9229
newcastle upon tyne
What has exactly been done to the engine on the build? It could still be a valve not seating correct regardless of the milage
Edited by scott the joiner on 17th Mar, 2012.
are we sure its not just dropping a plug?
Mr Joshua
Member #: 1954
Luton Bedfordshire
When aster you doing the compression test. Hot or cold.
Own the day
Tonywells
Member #: 343
The bottom end was honed with new rings and bottom end bearings.
The head was kept original as it all seemed ok.
The plugs are only about 100 miles old.
The engine was warm when the compression was tested.
Kean
Member #: 341
aka T2clubby
South Staffs
Doesnt matter how old the plugs are, they can get fouled in a few minutes, I'd change them first before you look at anything else.
almichie
Member #: 2065
Exactly - I have had that very thing happen. I tried everything - plug gap, tappets, timing earthing, fuel etc etc last thing I tried was plugs and now it's the first thing I try.
Edit - I should have seen the low compression ratio bit.
6 bar and 12 bar it a bit far out.
Edited by almichie on 18th Mar, 2012.
scott the joiner
Member #: 9229
newcastle upon tyne
How much lower was cylinder1 compared to the other 3 results?
Tonywells
Member #: 343
Number 1 has 6bar and 2,3,4 have 12bar.
I think it went upto about 8 with oil in.
I understand that plugs can go after a short time but that doesn't explain the lack of compression.
I'm going to ring the engine builder tomorrow as I've only done 1300 miles.
Tonywells
Member #: 343
Dp
Edited by Tonywells on 18th Mar, 2012.
there seemes to be a bit of a trend for cars to be dyno tested and than go bang soon after , is it possible its blown a head gasket or ring lands due to the rr trying too much boost ,or advance, or running lean .. or all three ?
who's dyno was it ,and what was the max boost and ignition advance , on what compression ratio ?
Tonywells
Member #: 343
The engine is all standard.
It was setup at track and road.
I was there when it was setup and it was setup to be safe and not for out and out power.
The operator was carefull and it was only taken upto 8psi.
I trust the rolling road operator 100%
I'm guessing I'm going to have to take the head off and have a look.
Also I've been very carefull with every part of the build and I've not even given it any real stick. Bloody a series!!
Mr Joshua
Member #: 1954
Luton Bedfordshire
Back the hell up! Did I read right! Number 1 is only making 6 bar on compression!? Sorry but I just had to go into the workshop to check that on the gauge. Number 1 is in real trouble.
You have either forgotten to fit your rings or you have a bigger hole somewhere! If it were me I would be praying that it is sticky valve or poorly adjusted rocker. Either way off with its head.
Own the day
what were the afr and the advance at max torque and max bhp as setup on the dyno tony ?
Tonywells
Member #: 343
Here is the rolling road print out.
Not sure about advance but it's a standard dizzy.
imo thats a low power for 8psi boost
