| Home > Help Needed / General Tech Chat > Urgent help needed; rattling noise | |||||||
![]() 882 Posts Member #: 9774 Post Whore Buckinghamshire |
21st Mar, 2012 at 04:18:48pm
Ive just finished fitting the rest of my megajolt bits, and it started up great, was all working nicely, then took ignition coil off and dizzy out, and it worked fine for a few seconds then a rattling noise, so I switched it off, had a look around, nothing had come loose, so i tried it again and the same thing happened.
http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
21st Mar, 2012 at 04:21:08pm
Did you remeber to remove the dizzy drive shaft?
In the 13's at last!.. Just |
21st Mar, 2012 at 04:23:46pm
Thanks for the quick reply,
![]() 580 Posts Member #: 9580 Post Whore Surrey |
21st Mar, 2012 at 04:30:33pm
I think it has a threaded hole in it. 5/16 unf iirc Edited by shellspeed on 21st Mar, 2012. |
21st Mar, 2012 at 04:35:39pm
Hopefully it'll come out in one piece :/
21st Mar, 2012 at 04:35:42pm
Sorry, in what?
21st Mar, 2012 at 04:37:42pm
5/16" UNF (use one of the long rocker cover studs or left hand radiator to mounting bracket bolts) but if it has run enough to have jumped out of its lower bearing you are f**ked - you will need to separate the engine/gearbox to recover the bits and assess the damage. Schrödinger's cat - so which one am I ??? |
21st Mar, 2012 at 04:40:55pm
It's where the dizzy was (or maybe not any more....)
21st Mar, 2012 at 04:46:13pm
This is for an A+ engine?
21st Mar, 2012 at 04:53:49pm
Take the blanking plug off - you should be able to see the drive at the bottom of opening. The centre of the drive has a threaded hole the othere note to aid removal.
21st Mar, 2012 at 05:08:01pm
Thanks a lot guys, once again the people of turbo inks save the day http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
21st Mar, 2012 at 06:06:33pm
Lucky fucker Yes i moved to the darkside |
21st Mar, 2012 at 06:32:22pm
On 21st Mar, 2012 Brett said:
Lucky fucker VERY lucky
21st Mar, 2012 at 07:22:47pm
Megajolt to megalucky |
319 Posts Member #: 1742 Senior Member essex |
21st Mar, 2012 at 07:31:03pm
i thought on the a+ it was impossible to drop it into the gearbox? im always carfull when i remove it anyway. glad itworked out ok though My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901 |
21st Mar, 2012 at 08:33:08pm
Yes, massive sigh of relief when i saw the drive still in the hole..
21st Mar, 2012 at 08:36:03pm
Note to self: if engine makes a rattling metallic noise, find problem before attempting to start the again again. In the 13's at last!.. Just |
21st Mar, 2012 at 09:16:28pm
And the drive was complete? Not teeth missing?
21st Mar, 2012 at 09:21:16pm
The teeth were a bit mashed, but no huge chunks or anything. http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
21st Mar, 2012 at 09:27:46pm
Got Pics?
21st Mar, 2012 at 09:30:12pm
No sorry, left all the bits i took off today in the parents garage, i'll see if i can get some tomorrow http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
22nd Mar, 2012 at 08:04:39am
Here's mine from a while back...
On 15th Mar, 2012 wil_h said:
22nd Mar, 2012 at 08:07:16am
Good job bennyy!!! Mine wasn't that bad but left bits in the bottom of the box - I used a magnet to fish out most throug the oil sump plug hole!! On 7th Nov, 2011 apbellamy said:
22nd Mar, 2012 at 08:15:06am
Ouch.
22nd Mar, 2012 at 08:57:01am
Understatement of the year.
On 21st Mar, 2012 Mike-998 said:
The teeth were a bit mashed, but no huge chunks or anything. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
