| Home > Help Needed / General Tech Chat > windage trays | |||||||
756 Posts Member #: 1355 Post Whore Leicester |
13th Apr, 2012 at 05:37:44pm
as above whats the beiefits from having one?
265 Posts Member #: 368 Senior Member Roseville, CA (USA) |
13th Apr, 2012 at 06:59:52pm
It's been a while, but I recall that you could run less oil because you don't have as much flinging about between the tranny and crank, and helps prevent frothing of the oil.
13th Apr, 2012 at 07:06:27pm
well my thoughts were theres going to be less oil drag.
13th Apr, 2012 at 07:13:35pm
oil drag on the crank and rod's is the main reason. On 11th Feb, 2015 robert said:
13th Apr, 2012 at 07:16:46pm
The idea of the windage tray is to stop oil flinging off the gearset onto the crank and slowing it down.
I seriously doubt it! |
13th Apr, 2012 at 07:19:18pm
so do you think there a good thing to fit?
13th Apr, 2012 at 07:22:09pm
Personally I will always have one. Some people notice the difference and some dont - it is small. Even if it did nothing though it wont hurt to have it in there I seriously doubt it! |
13th Apr, 2012 at 07:24:10pm
ok awsome. thats all i needed to hear |
13th Apr, 2012 at 07:26:45pm
Make sure before you bolt the engine and box together that it clears the gears and rotating crank n rods I seriously doubt it! |
13th Apr, 2012 at 07:27:56pm
i will do!
432 Posts Member #: 2726 Senior Member wakefield |
13th Apr, 2012 at 08:02:07pm
What type of fastenings are best to use to fix it in place?
13th Apr, 2012 at 08:16:21pm
I use 4 M5 screws drilled and tapped into the casing. It should have marker pen dots where I suggest the screws should be I seriously doubt it! |
13th Apr, 2012 at 08:27:46pm
Yep mate it does, many thanks. |
13th Apr, 2012 at 08:34:23pm
Dont forget under crown cooling jets (please correct me if im wrong) because i think you need to use them with a windage tray Drives
13th Apr, 2012 at 09:36:43pm
what are "under crown cooling jets"? |
13th Apr, 2012 at 10:42:13pm
http://turbo-mini.com/44648/23109.html
![]() 684 Posts Member #: 9590 Post Whore Derby |
13th Apr, 2012 at 11:02:24pm
Why would you need to use cooling jets with a wind age tray?
Matt W
On 14th Mar, 2012 mw3 said:
Got a nice big delivery from Carl at Force Racing today. |
![]() 1137 Posts Member #: 1450 Post Whore Near Paris - France |
14th Apr, 2012 at 01:46:53am
more un filtered oil though ... Rusty by nature
They said "That sounds rough mate." I said "Cheers it cost me a fortune to make it sound like that!" |
14th Apr, 2012 at 07:41:34pm
On 13th Apr, 2012 Paul R said:
Dont forget under crown cooling jets (please correct me if im wrong) because i think you need to use them with a windage tray No you don't need piston crown cooling jets if you use a windage tray. Do remember there is still oil being slung everywhere as it bleeds from the big ends and main bearings without the gearbox. Inline A series engine work fine without the need for a gearbox to lubricate the cam or cool the pistons On 26th Oct, 2004 TurboDave16v said:
14th Apr, 2012 at 08:20:40pm
yep as above,
30th Nov, 2012 at 07:30:53am
These looked very nice as a matter of fact.
![]() 362 Posts Member #: 114 Senior Member Porto/Portugal |
30th Nov, 2012 at 01:25:06pm
With the windage tray, how the camshaft/cam follower get lubrification? Pedro Silva
30th Nov, 2012 at 01:39:14pm
Cross drilled cam? If something is worth doing, it's worth doing half of. |
30th Nov, 2012 at 02:30:57pm
Down the holes from the oil galleries onto the bearings and down the push rod holes from the rocker cover. On 11th Feb, 2015 robert said:
30th Nov, 2012 at 06:00:26pm
thats been cnc machined? why not lazer cut it? |
