Home > Help Needed / General Tech Chat > Explosion/popping sound comming from carb?
Craigie-B
Member #: 9468
Wootton Bassett
Hey guys,
my housemate Tom bought a 1275 mini today with a stage 1 kit (he will be joining us on this club in the next couple of days) it ahs a cone filter on it so sounds quite loud, however it makes this exploding type sound and its deffinatly comming from the carb area - it only does it when the cars driving and has been getting worse.
Its a really loud bang - makes me jump everytime
Any ideas would be really good :)
Craig
Sounds like timings out.
Craigie-B
Member #: 9468
Wootton Bassett
I've just noticed it has a hs4 carb as well - being a 1275 shouldnt it have a hs6??
Craigie-B
Member #: 9468
Wootton Bassett
umm, forgot to mention the car was running fine earlier - we drove it 150 miles before this started to happen, would that still indicate timing??
sounds advanced i think, if its still on points when they wear out the timing advances, i dont know if its enough to cause this though
[edit] it could also be very very lean at the point where it does it and also check valve clearances could have a valve not shutting when hot
Edited by Brett on 25th Apr, 2012.
jamie@thefatgarage
Member #: 9345
Sheffield
Lean mixture is my guess, maybe an air leak.
wng691s clubby
Member #: 9252
Cleethorpes
if its on a dizzy and the clamps not tight they can move just have a check with a timing light
Done now needs redoing lol
nala56
Member #: 9661
Sheffield South Yorkshire GB.
Could the car have developt an air leek some where?..
Main Build
Upgrade to Turbo
Craigie-B
Member #: 9468
Wootton Bassett
here guys:
http://s454.photobucket.com/albums/qq263/C...nt=9b5ed4cd.mp4
give it half a turn more fuel and see what differance it makes
Edit-- dashpot oil?
check the vac advance hose is connected and not split
Edited by apbellamy on 25th Apr, 2012.
wez
Member #: 9271
Stoke on Trent
Oil in the dashpot?
one day boost will be mine!
On 10th Mar, 2012 Joe C said:
Craigie-B
Member #: 9468
Wootton Bassett
we adjusted the nut on the bottom (its a hs4 carb)
where about is the vac advance hose mate?
wng691s clubby
Member #: 9252
Cleethorpes
little hose from carb to dizzy
Craigie-B
Member #: 9468
Wootton Bassett
there is some oil in the dashpot - how would we know if its that?
wng691s clubby
Member #: 9252
Cleethorpes
is the dash pot full?
Craigie-B
Member #: 9468
Wootton Bassett
not sure, there was this dip stick thing in it? I didnt even know it needed oil till tonight! How much should it have
wez
Member #: 9271
Stoke on Trent
Fill it till its about half inch from the top and slowly put the damper back in.
Craigie-B
Member #: 9468
Wootton Bassett
okay thanks guys,
tomorrow we will be checking/doing:
dashpot oil
vac hose
turn the mixture nut on the bottom (again)
dizzy being on tight
all else fails ill ring up SMMC and see if it needs a tune as its a stage1 kit and might not have proper needle
Craigie-B
Member #: 9468
Wootton Bassett
which way do we need to turn the nut (facing the engine with bonnett up)
wng691s clubby
Member #: 9252
Cleethorpes
can use dashpot oil but engine oil will do, check it with a timing light if you have one. Itl show if dizzys moved
Edited by wng691s clubby on 25th Apr, 2012.
wez
Member #: 9271
Stoke on Trent
I used some general purpose oil I found in the out house as I had nothing else to put in, and it's still in there now. Lol must remember to change it.
Craigie-B
Member #: 9468
Wootton Bassett
I dont have a timing light =[
wng691s clubby
Member #: 9252
Cleethorpes
iv heard 3in1 oil is quite good
tom130691
Member #: 9910
coventry
after checking the above (didnt top up the dashpot)
played with the nut on the bottom of the carb got it to stop popping when reving on the drive, to it for a quick drive all went well,
then 2-3 miles later it started all over again,
looking at getting it set up and needles changed by SMMC on the rolling road on monday if i cant sort it by then,
adjusting the nut at the bottom doesnt make much difference as i turned it back a few flats, because it began to bog down i presumed it was now over fueling.
also cleaned up the dizzy contacts didnt make much difference realy
Users viewing this thread: none. (+ 2 Guests)   Next ->
