| Home > General Chat > Snapped ARP Conrod Bolt | |||||||
![]() 736 Posts Member #: 1865 Post Whore Norwich, Norfolk |
30th Apr, 2012 at 08:09:45pm
I've managed to snap one of my ARP bolts, first question is does anyone have a spare knocking about as I would prefer not to spend £112 on a full set just to use one bolt.
30th Apr, 2012 at 08:15:50pm
I assume it has been snapped while fitting? If so, how?
In the 13's at last!.. Just |
30th Apr, 2012 at 08:18:21pm
yes while fitting. torquing it up and the torque wrench wasnt clicking so continued to tighten and then it broke. all the others torqued up just fine.
30th Apr, 2012 at 08:20:13pm
On 30th Apr, 2012 Simon said:
I've managed to snap one of my ARP bolts, first question is does anyone have a spare knocking about as I would prefer not to spend £112 on a full set just to use one bolt. mine cost about half that where are you looking? On 30th Apr, 2012 Simon said:
OR What are peoples opinions on buying a single standard bolt for around 4 quid to replace it? or perhaps 2 standard bolts to replace the 2 bolts on one rod. could buy 2 standard and have them both in one rod BUT, the whole bottom end is as strong as the weakest link, if you do this treat the whole lot as if it had no arp rod bolts as this one rod would become the weakest line just how strong the std bolts are is another question, it seems ( and same for my self) most people fit them because its too cheap to refuse ( centre main strap is another for instance ) Yes i moved to the darkside |
30th Apr, 2012 at 08:24:14pm
Well it is slightly different if you've tourqued it to 3,000,000,000 ft/lbs.
30th Apr, 2012 at 08:24:43pm
If the torque wrench wasn't working, how many of the others have been overtightened ???
30th Apr, 2012 at 09:46:34pm
There's nothing wrong with the torque wrench it's pefectly decent! It wasn't clicking because the bolt was obviously twisting and not tightening, the bolt is at fault not the wrench.
30th Apr, 2012 at 09:56:44pm
Could it have been overtightened in the past? Do you know who built the engine? On 7th Oct, 2010 5haneJ said:
30th Apr, 2012 at 10:40:38pm
This is very unusual. ?!
30th Apr, 2012 at 10:53:59pm
With a failure like this (providing it was torqued properly as op states) are these any better than the original rover items? I was going to use arp on my next build, though i usually use second hand rover ones with no problems at all.... |
248 Posts Member #: 7936 Senior Member DK-8450 Hammel. Denmark |
1st May, 2012 at 07:13:35am
Anyone who has tried to break a con-rod bolt a high RPM, newer saves money at them again.
If i have more toys than you when i die, I WIN |
1st May, 2012 at 07:14:58am
Until I joined this forum I ALWAYS re-used rod bolts and never had a failure.
1st May, 2012 at 07:23:23am
was this originally a morspeed built engine? On 11th Feb, 2015 robert said:
1st May, 2012 at 08:17:26am
I'd send the faulty bolt to ARP to examine. On 13th Jul, 2012 Ben H said:
1st May, 2012 at 08:59:11am
I had a moment a few years ago where I over tightened a rod bolt.
1st May, 2012 at 09:28:51am
On 1st May, 2012 apbellamy said:
was this originally a morspeed built engine? It was yes. I am in contact with ARP via email, all they have suggested so far is to replace the whole set, |
1st May, 2012 at 09:34:53am
Use a stretch gauge rather than a torque wrench! On 5th Sep, 2011 Vegard said:
2nd May, 2012 at 09:01:52pm
I have had this with standard rod studs. The odd stud would start to neck and thus not torque and my torque wrenches are calibrated. Own the day
4th May, 2012 at 12:27:17pm
stretch gauge? like a dial indicator? |
756 Posts Member #: 1355 Post Whore Leicester |
4th May, 2012 at 12:35:49pm
what did you torque them to? |
4th May, 2012 at 01:34:03pm
On 4th May, 2012 jameswildcooper said:
what did you torque them to? 35ft lbs. I now have a new set of bolts and ARP are sending me a strech gauge on loan to fit them next week. They were unable to offer any sort of support/discount on replacing the bolts as they have no factual figures to backup my claim such as bolt length which is really the only thing they can go on. For all they know I could have torqued them to 100ft lbs, there is just no way of telling. |
4th May, 2012 at 06:37:01pm
Not many companies go lending out tools, that good of them. On 7th Oct, 2010 5haneJ said:
4th May, 2012 at 07:16:58pm
They have 3 sets of stretch gauges for loan, all FOC unless you try keeping them and they'll fine you £110. |
6th May, 2012 at 11:11:17pm
ive had a brand new ARP head stud break on my Mini years ago.
9th May, 2012 at 05:26:32pm
waiting for me when I got home.
