| Home > General Chat > nippon denso alternator | |||||||
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
11th May, 2012 at 11:04:13am
so i ordered one from a link brett posted and its arrived today it was advertised as a 40amp but it has some papper work with it wich says its a 60amp (i think unless im reading it wrong) so for £50 total it was a bargin, anyone else recieved theres as i know a couple more people ordered them Done now needs redoing lol |
11th May, 2012 at 11:09:26am
yeh i ordered one, brett posted a picture of that graph. At 6k it produces 60amps i think. 40amps is around the 3k mark. |
11th May, 2012 at 11:14:19am
ah i see Done now needs redoing lol |
11th May, 2012 at 01:48:00pm
Yeah i think they are rated for the average rpm sort of thing i couldnt beleive it was new i was expecting a scrubbed up scrappy one bargain Yes i moved to the darkside |
![]() 4641 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
11th May, 2012 at 06:18:05pm
Mine came today, not opened it yet though. |
![]() 489 Posts Member #: 9159 Senior Member Devon |
11th May, 2012 at 08:01:00pm
Got mine today, very impressed! |
11th May, 2012 at 08:49:01pm
Who got the last one? Was only one when i looked from my phone and when i went to buy they had all gone! |
11th May, 2012 at 08:49:03pm
Double post... Edited by jonny f on 11th May, 2012. |
11th May, 2012 at 09:50:46pm
Mine is ready to bolt on now just need a long bolt for it i had to modify it slightly as the case seems different to a few build threads i looked up. First attempt was a mount/adapter bracket cut out of 2x1x7 inch ally it was rather flexible so i bodified the alt to fit the normal mini mounts
11th May, 2012 at 10:38:05pm
i got the last one sorry, any more of those adaptor plates going brett? Edited by wng691s clubby on 11th May, 2012. Done now needs redoing lol |
![]() 1342 Posts Member #: 2292 Tool Herne Bay, kent |
12th May, 2012 at 05:37:20pm
yep i collected mine in person as local and it says 60amp at 6k or something. On 27th Apr, 2010 Rick.SPI said:
cant beat a good blowout. |
Forum Mod ![]() 1927 Posts Member #: 1761 Stalker Bristol |
14th May, 2012 at 09:29:19pm
I've also found this auction for some denso alternators, which look like they might fit the mini mounts a little better as well. It's the same 40amp alternator but with different mounts:
Edited by Carl S on 14th May, 2012. |
14th May, 2012 at 11:17:25pm
On 11th May, 2012 wng691s clubby said:
i got the last one sorry, any more of those adaptor plates going brett? its just a bit of aluminium of cut mate with 3 holes drilled in it, i would make you one but i have no more ally Yes i moved to the darkside |
15th May, 2012 at 06:28:29am
I may be interested in one of those Carl, I will let you know if I decide to get one. Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
15th May, 2012 at 07:26:55am
I like what you've done there Brett. I'll probably be pinching that idea.
In the 13's at last!.. Just |
15th May, 2012 at 08:17:33am
i'd be after one carl please |
15th May, 2012 at 10:18:07am
Just fitting it now i ran a tap through the water pump this should stop the bolt coming out again lol
On 15th May, 2012 theoneeyedlizard said:
I like what you've done there Brett. I'll probably be pinching that idea. For a long bolt, a head stud fits nicely. Yes i moved to the darkside |
15th May, 2012 at 12:56:21pm
PM's replied to.
15th May, 2012 at 05:11:35pm
Well my alternator has turned up, the one from the auction I linked to in a previous post on this thread, and the connector is completely different to the alternator model listed in the auction! Hurray! |
15th May, 2012 at 05:27:36pm
The one that's turned up has a 3 pin plug with a round socket, which I think is a little more common. Fingers crossed. So I will have another T type 2 pin connector available. First come first serve once again, send me a PM if interested. is the 2 pin for the one like brett has bought? |
15th May, 2012 at 05:46:53pm
No idea buddy, show me a picture of the connectors it has. |
17th May, 2012 at 09:27:47pm
I've got both types of alternator at the moment, so i've taken a photo of them for a comparison to show which type of connector i've bought:
18th May, 2012 at 05:50:44am
mine is like neither but it has a 2 wire T style plug similar to the one on the right but i would call rthe one on he right a cross type Yes i moved to the darkside |
18th May, 2012 at 06:23:11am
mine is like the one on the right. one of the pins is offset so a standard T connector won't fit On 11th Feb, 2015 robert said:
18th May, 2012 at 09:10:20am
On 18th May, 2012 Brett said:
mine is like neither but it has a 2 wire T style plug similar to the one on the right but i would call rthe one on he right a cross type Thanks for pointing that out Brett. I've gone back to the catalogue I bought the connectors from and there is another similar one with an offset pin on the 'T', so when the pack that I have bought turns up, I shall check if it fits. If it doesn't fit, I'll buy a pack of these other connectors I've found and try again. |
