| Home > Help Needed / General Tech Chat > Utter Newbie : turbo charge a 998 or a 1275? | |||||||
![]() 321 Posts Member #: 557 Senior Member Ireland |
17th May, 2005 at 12:21:59pm
Hi all, I only just found your site and am glad that I did :) |
195 Posts Member #: 26 Advanced Member Cannock |
17th May, 2005 at 12:46:42pm
1. Depends upon the compression ratio. There is currently one 998 turbo on this site (and a think a few others in the making looking at other posts). Also you don’t need a metro turbo engine if you are planning a rebuild. The reason behind this apart from the pistons a stock 1275 engine is similar to the turbo lump.
Edited by BA_Lordflash on 18th May, 2005. |
17th May, 2005 at 03:30:06pm
Mine is an '89 Mini Racing. As far as I can tell everything appears to be working smoothly although it has done a few miles at this stage.
![]() 264 Posts Member #: 403 Senior Member sydney Australia |
17th May, 2005 at 03:33:22pm
g'day, i only just turn'd 16 and had never had any experience with mini's (never even riden in one) but im building a 998 turbo engine aswell. I'm only halfway through the build but so far it hasnt been "too" dificult, just make sure you do your research (this site is all i'v ever used). Im running a 12G295 head aswell, they are a great flowing head and leave you with a good CR (as stated above). Turbo wise, i went for somthing small, im useing a turbo roughly the same size as a T2, realy dont need anything bigger. Try get an oil cooler, good radiator and if you can an intercooler, should give you a healthier engine (from what i'v read). You'll probably also need a plenum chamber, metro turbo inlet manifold, Hiff44 carb to start with, there are other lil thing's you can do to 998 engines to make them stronger/better but as i dont even have a finished engine i'll leave it up to someone with a bit more knowledge to fill you in! 998 turbo |
17th May, 2005 at 03:37:05pm
im looking for 90hp outa my engine, talk to wil_h he's the man when it come's to 998 turbo's! 998 turbo |
17th May, 2005 at 04:52:03pm
On 17/05/2005 12:46:42 BA_Lordflash said:
So the next question, can I turbocharge my standard Metro 1300cc engine? Well this is more tricky, yes and no. The main point of concern is the pistons. The standard normally-aspirated pistons are not up to the spec of the turbo pistons. Therefore if retaining them for use in a turbo engine, boost levels must strictly be kept down, or else holed pistons are likely. The cylinder head can be reused, although it is prefered to fit the turbo exhaust valves and guides with the larger stems. A number of people also use stainless race exhaust valves to good effect. The other problem is that of Compression Ratio (CR). The CR of the Metro Turbo engine is 9.4:1. Although this is not large in normal terms, for a forced induction engine this is very high. Therefore it is desirable to reduce the CR where possible. Many people run a CR as low as 8.0:1 or less. CR can be lowered effectively by either enlarging the cylinder head chamber volume, or increasing the piston dish size. Of the two options, increasing head volume is easier, and can be done on your existing head. Hang on a minute I recognise that text............. Oh thats right I WROTE IT........... If you're going to rob my words you could at least put a link to the post to let people read the rest of it that they might find useful!!!
17th May, 2005 at 05:11:29pm
Mini1071s I like the numbers you;re quoting :) both price and output (especialy the 110bhp |
17th May, 2005 at 05:34:17pm
If I can find the IHI RHB5 turbo, will I need a manifold like the one from Mirage for the T2? |
17th May, 2005 at 07:04:10pm
I may be considered the 998 turbo expert. But just remember, the faster you go, the quicker you're going when you hit a tree.
Edited by wil_h on 17th May, 2005. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
18th May, 2005 at 10:35:43am
Okay I'm trying to put together a list of all the components I will need to keep my eyes out for - especially as I;d rather get most parts off eBay than buy new :p
Edited by snowfruit on 18th May, 2005. |
![]() 281 Posts Member #: 441 Senior Member |
18th May, 2005 at 10:59:39am
you need to sort a fuel return,turbo carb with plenum (think you can get away with putting a plenum on a non turbo carb but may be wrong) uprated diff pin at least |
18th May, 2005 at 11:01:33am
2 core radiator is best i beleive |
18th May, 2005 at 11:28:07am
On 18/05/2005 10:59:39 1275_dan said:
you need to sort a fuel return,turbo carb with plenum (think you can get away with putting a plenum on a non turbo carb but may be wrong) uprated diff pin at least Suggestions for all of these? Will a carb as used on a metro turbo do the trick? |
18th May, 2005 at 11:29:32am
Mini Spares do a kit to convert a standard fuel tank to an injection model, will this suit as the tank/fuel return? |
18th May, 2005 at 11:44:05am
snow, have you got a part number for this kit? On 15th May, 2009 TurboDave said:
18th May, 2005 at 11:49:21am
mini1071s would it be possible for you to tell me the parts you've bought so far for your £206? and the parts you're still looking for? |
18th May, 2005 at 12:29:56pm
Jimster, I can't get on to the Mini Spares site at the moment, but I'll post it as soon as I can either get on to there, or I get the number from the catalogue I have at home. |
18th May, 2005 at 02:43:11pm
On 18/05/2005 11:44:05 Jimster said:
snow, have you got a part number for this kit? Jimster the part number at Mini Spares is MS83 |
18th May, 2005 at 03:21:30pm
is this any good?
18th May, 2005 at 03:48:15pm
Heh this is starting to feel a little one sided :p
18th May, 2005 at 10:49:43pm
snow, have you got a part number for this kit? Jimster the part number at Mini Spares is MS83 Minispares say: No matching results for "ms83" Your search for "ms83" in "Classic Mini" returned no results. Those dizzies mentioned are (i doubt) turbo dizzies as none of the other stuff he's selling is. He's just full of crap trying to make them worth more than they are (as with his other ads). for £45 that turbo might be ok, but i keep hearing 998 mentioned? You'll struggle to spool this turbo up with that turbine. Even worse is the unit from the nissan and the imprezza. Stick to what peeps reccomend. On 17th Nov, 2014 Tom Fenton said:
19th May, 2005 at 09:52:23am
How about the R5 intercooler, carb and turbo? are they worth it?
Edited by snowfruit on 19th May, 2005. |
19th May, 2005 at 05:56:06pm
What would the efi tank come out of? will a mini injection model do? |
19th May, 2005 at 09:28:46pm
get a complete mpi or spi tank £30-£50
20th May, 2005 at 01:58:05pm
<quote> With the Mirage kit, you do not need to mod any of the body (supposedly). And it is purpose built for the T2. However, since the Mirage kit is dsigned to fit, it doesn't flow nearly as well as an original Metro Turbo system modified to take the T2. </quote>
