| Home > General Chat > hand brake cables and KAD cast rear arms | |||||||
9th Aug, 2012 at 05:15:41pm
How much would you expect a new cable to stretch by?
Edited by apbellamy on 10th Aug, 2012. On 11th Feb, 2015 robert said:
9th Aug, 2012 at 05:19:19pm
have you got the quadrants on the right way round? On 26th Oct, 2004 TurboDave16v said:
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
9th Aug, 2012 at 05:25:41pm
my cable is as old as my car and im only just at the end of adjustment. Sounds like somethings not right andy Done now needs redoing lol |
9th Aug, 2012 at 05:25:47pm
I've got the shorter end towards the centre of the car, but I'm going to go and turn one round...
![]() 847 Posts Member #: 6673 Post Whore Worral Sheffield |
9th Aug, 2012 at 05:34:28pm
could they be on correct way up but wrong side of the car? not sure if they are left and right handed? can't imaging the cable has stretched that much. |
9th Aug, 2012 at 05:34:56pm
They are on the right way round. It looks like it would catch the standard arms too. I reckon the cable has stretched. On 11th Feb, 2015 robert said:
9th Aug, 2012 at 06:00:09pm
Does it matter which way up the handbrake levers go in? I have them with the bit sticking out the back at the bottom. They are quite slack in the shoes....
9th Aug, 2012 at 06:02:37pm
have you got the shoes in the right way round? and the hand brake cantilever in the right way up?
9th Aug, 2012 at 06:03:39pm
I think the shoes are in the right way up, see my post above about the levers On 11th Feb, 2015 robert said:
9th Aug, 2012 at 06:04:56pm
On 9th Aug, 2012 apbellamy said:
Does it matter which way up the handbrake levers go in? I have them with the bit sticking out the back at the bottom. They are quite slack in the shoes.... Half tempted to stick the old ones in and see if it's any better. I have the KAD quadrants on standard arms with cheap copy cantilevers, nothing fouls, but I did notice a bit more 'slack' in the take up of the cantilevers on the shoes which I adjusted out On 26th Oct, 2004 TurboDave16v said:
9th Aug, 2012 at 06:08:28pm
I think the shoes are in the right way up, see my post above about the levers I don't recall off the top of my head and I don't have the car here to have a look, but I did spend a fair bit of time messing with it to work out which way uop they go, I think the lever the runs to the 'front' shoe is above the other. I don't think they fit the other way as it fouls the wheel cylinder? not sure. its been nearly a year since I built them up lol On 26th Oct, 2004 TurboDave16v said:
9th Aug, 2012 at 06:09:46pm
Do the levers go into the slots in the shoes or the vaguely round bit? I think I may have the shoes upside down now that you mention it... On 11th Feb, 2015 robert said:
9th Aug, 2012 at 06:10:42pm
im sure the long side of the quadrants point towards the center of the car On 26th Oct, 2004 TurboDave16v said:
9th Aug, 2012 at 06:14:31pm
check the haynes manual for the correct orientation of the shoes, but don't make the same mistake as many do and fit the shoes the same on each side. check which side of the car the picture is taken on, and then do the opposite on the other side. On 26th Oct, 2004 TurboDave16v said:
9th Aug, 2012 at 06:17:16pm
hmm... Think I've found where I'm going wrong...
9th Aug, 2012 at 06:42:27pm
Right shoes stuck on as per the book of lies, had to run the adjusters out a touch to get the drums back on. It's made no noticeable difference. 2 clicks and rock solid against the rear arms. I have the front cable adjusted pretty much all the way up the threaded section, so I think the cable is cheep shite and has stretched a lot. It did all get noticeably worse as the car has been sat over the years. On 11th Feb, 2015 robert said:
![]() 825 Posts Member #: 9661 Post Whore Sheffield South Yorkshire GB. |
9th Aug, 2012 at 08:11:28pm
Will try to get a picture for you Andy Edited by nala56 on 9th Aug, 2012. Main Build
9th Aug, 2012 at 08:42:32pm
Hope this helps, Andy..
Main Build
![]() 1434 Posts Member #: 8466 Post Whore Mansfield |
9th Aug, 2012 at 09:58:20pm
I have the exact same problem with new cable, with dsn quadrants and Kad Alloy arms. Class C 3rd Place Avon 2011 14.18 @101mph |
10th Aug, 2012 at 06:59:09am
Thanks Alan, that confirms I have everything fitted properly in the drum.
10th Aug, 2012 at 07:20:46am
Found the answer. cable ends need modifying.
10th Aug, 2012 at 07:09:41pm
Fixed. On 11th Feb, 2015 robert said:
![]() 580 Posts Member #: 9580 Post Whore Surrey |
10th Aug, 2012 at 08:41:49pm
Glad for that advice. Fitting mine Sunday along with my force rear beam. Advice will save me some head scratching. Love it |
10th Aug, 2012 at 08:46:32pm
You'd better post me a 4 pack then On 11th Feb, 2015 robert said:
2nd Sep, 2012 at 04:20:05pm
Right, Ive just been playing with this too,
