Home > General Chat > To buy or not buy, that is the question?
kappa
Member #: 9854
Hounslow, Middlesex
Hi all,
I have been reading the thread about the supercharged and turbocharged engine advertised for sale on ebay by WRLondon provisionally sold by Rubicon.
I am a newbie to forced induction and would love to get some advise please.
Does anyone think this is a worthwhile engine to buy or should I just wait for another complete unit to come up for sale and go down that route.
Please Help
Thank You
Bobby
Its a complex setup and will take a lot of work to get it running well.
For your first go at forced induction, I would go for something more standard.
If it's the right money it's worth a buy. You'll be able to flog the SC stuff for good money.
Not sure about the issues stated with Rubicon selling it though.
kappa
Member #: 9854
Hounslow, Middlesex
Yeah was think to do that, but not sure what route to take, rebuild my engine to a turbo spec and then get all the gubbins to go with it or just buy a complete unit and drop that in my car?
More than likely the cheaper option would be the route I will take.
Build your own unless you know the history of what you are getting.
kappa
Member #: 9854
Hounslow, Middlesex
That may be the best option, atleast I know what I will working with, but still will keep a eye on the engine, as I still may get a good bargain, as worst case scenario I can rebuild it, and this way I will get all the turbo gubbins needed, hopefully!!!!
Build it yourself. I'd never buy a ready built engine now.
It's good fun too.
t@z
Member #: 452
Chester, UK
It's good fun too.
define fun; money leaving wallet = no fun :) that being said cant spend it when your dead
+1 also for build it yourself.
www.twitter.com/lilpinkiy
Chalkie
Member #: 9764
Northamptonshire.
+1 Build it yourself! you can go I built that ;]
kappa
Member #: 9854
Hounslow, Middlesex
That is very true, so if I am running a 1330cc engine at the moment, that has a stage 3 head, a 276 cam, 1.5 full rockers and a hiff44 carb, what is the best parts to buy to go turbo?
kappa
Member #: 9854
Hounslow, Middlesex
Sorry to bother you all again, but can some explain this dished piston thing with what cc I need, as thats where I get confused?
kappa
Member #: 9854
Hounslow, Middlesex
Sorry to sound like a novice in all this
Search, read, find out for yourself.
t@z
Member #: 452
Chester, UK
if you search compression ratio mate you'll probably find out rough graphs to help you out. Also dish pistons are used to lower compression so that you can use more boost. Bit like having the head chambers enlarged.
If you know what cc the engine is and the size of the chambers in the head, you can then work out what size dished pistons will get you closest to your desired compression ratio. *wink*
kappa
Member #: 9854
Hounslow, Middlesex
Oh ok,
thank you for info on this, that is very helpful, cheers
Simon
Member #: 1865
Norwich, Norfolk
Kappa you keep asking the same questions, you need to start believing the answers. I have previously sent you a PM with all the parts on, I wasn't making it up! From my PM for people to agree / disagree so you have a definitive answer, this was just off the top of my head too, there are likely to be more parts than less:
Carb rebuild
Turbo
Elbow & Ex Manifold
Plenum
Downpipe
Turbo Oil feed
Fuel pump
Fuel regulator
Fuel return line
Probable fuel tank change/mod
Intercooler (you've mentioned 150bhp elsewhere on the forum)
AFR Gauge
Boost controller of some description
Dump valve
Uprated radiator
Turbo air feed & filter
Different head gasket & manifold gasket
Standard crank and rods will be fine
Centre main strap
Turbo oil pump
Dished pistons to get the compression ratio down
You might want to change your cam depending on what you have
t@z
Member #: 452
Chester, UK
i would beg to differ on some of those items
AFR Gauge not require unless self mapping
Boost controller of some description again really not needed unless you want road & pod set up
Dump valve not required, +10bhp i read somewhere though
Centre main strap if your getting the work done may as well but i wouldnt say its necessary
Turbo oil pump i read this is more advised than a requirement as i dont run a turbo one
and yes best source of info is the search function
Edited by t@z on 2nd Oct, 2012.
kappa
Member #: 9854
Hounslow, Middlesex
Cheers for the info guys.
t@z did you get my PM
Simon
Member #: 1865
Norwich, Norfolk
AFR Gauge should always be use IMO, early indication of any problems, issues can and do arise after being mapped.
Boost controller, you need something to up the boost if you want it higher than the actuator no? especially to hit 150bhp.
Dump valve, your going to need more than 10psi for him wanting 150bhp
Centre main strap, could save a lot more money than it costs so why omit it.
Turbo oil pump, if your rebuilding the engine your going to want a new pump so might as well fit a turbo one for the £15 price differance.
Edited by Simon on 2nd Oct, 2012.
kappa
Member #: 9854
Hounslow, Middlesex
Simon cheers for all that info, now I just need to start buying all the parts.
Cheers again
t@z
Member #: 452
Chester, UK
personally you can get an a series running ok to get to the rr where they will mess with the afr details there. im not saying they are wasted money as if i could have one i would but they are £££ and really unless your going down a DIY road and playing with boost not necessary.
maybe you mean a bleed nipple; in my mind they are different slightly. boost controller just screams money to me :)
i still dont think dump valves are needed; im sure they serve a purpose at massive boost.
my main point wasnt really to get onto the debate as we all do things differently it was just to make the list less daunting :)
The problem with setting it on the rolling road is that the car is static at the same atmospheric pressure with a big fan blowing through it. That is far from representative of all the factors you will find out on the road. Varying air temperatures and atmospheric pressures will effect the density of the air going in your engine, altering the amount of ignition advance you can run and the amount of fuel you need. If you don't have an AFR gauge, you don't know how that little lot is effecting your engine and how close you are to blowing it up. For what they cost, it's a no brainer.
The dump valve is there to help prevent compressor stall and help it spool up more quickly after gear changes etc. They greatly increase the life of your turbo.
t@z
Member #: 452
Chester, UK
different folks, different strokes
btw im not saying afr gauge isnt a good idea as im going to be getting one for when my car goes back on the road. but i was just adding some more detail to "what you need to get a tm running" as without being to anal you can get a turbo mini running ok to a rr; that was more my point.
whether a rr is realistic conditions; well thats a different topic
ps i love my compressor stall :)
You can probably get a turboed car to a RR, but an inexperienced person may not have such luck. Think back to Shane, he went through 3 engines trying to get to the rolling road...
