| Home > Help Needed / General Tech Chat > Blown another spark plug same cylinder as before | |||||||
1492 Posts Member #: 9468 Post Whore Wootton Bassett |
23rd Nov, 2012 at 08:31:03pm
Guys I have a problem On 10th Mar, 2012 theoneeyedlizard said:
Hypothetically speaking, where would you stick your nozzle? On 22nd Jun, 2012 apbellamy said:
my wife doesn't know what.head is never mind compression ratio. |
23rd Nov, 2012 at 08:46:06pm
Maths would suggest a 25% chance of pure coincidence, so it's not exactly ruled out.. |
23rd Nov, 2012 at 08:50:09pm
Megajolt needs a resistor plug. and 8's are way too cold. 6's should be fine and 7's if you really really want to, but 8's are just a bit too much.
23rd Nov, 2012 at 08:55:11pm
And what exactly is blowing a plug ?
23rd Nov, 2012 at 08:56:13pm
Ill see if my dad has a compression tester, the car isnt setup properly its running quite rich in the 10 - 13's afr at all times and sometimes it will lean out off the scale
23rd Nov, 2012 at 08:56:16pm
Blown a plug - it just stops working
Edited by Craigie-B on 23rd Nov, 2012. On 10th Mar, 2012 theoneeyedlizard said:
23rd Nov, 2012 at 08:56:19pm
Triple post fail Edited by Craigie-B on 23rd Nov, 2012. On 10th Mar, 2012 theoneeyedlizard said:
23rd Nov, 2012 at 08:58:36pm
I've been running non resistive 8's for 2 year with megajolt without fault for reference. On 7th Oct, 2010 5haneJ said:
23rd Nov, 2012 at 09:08:10pm
On 23rd Nov, 2012 Craigie-B said:
Ill see if my dad has a compression tester, the car isnt setup properly its running quite rich in the 10 - 13's afr at all times and sometimes it will lean out off the scale Do I just take 4 off of all the numbers on the map? Slark told me to get it run in and take it back to get it setup properly More relevant info here what value is lean out off scale? This could be a rich missfire. Below 10 to 9 afr could likely see rich missfire. All that extra fuel is maybe what is shorting the plugs. I'm surprised at Slark suggesting you run in an engine that is so far from ideal settings. often, you'll never get to the dyno, and even when you do, the engine is fucked with either detonation or bore wash On 26th Oct, 2004 TurboDave16v said:
23rd Nov, 2012 at 09:13:14pm
Im using an aem afr guage it only goes between 10 and 18 some times itll just display 10 and others it goes --- after the 17's
23rd Nov, 2012 at 09:15:12pm
23rd Nov, 2012 at 09:16:49pm
There very black and nothings visually wring with them, not at home so will get a pic tomorrow morn On 10th Mar, 2012 theoneeyedlizard said:
23rd Nov, 2012 at 09:46:18pm
try ngkbpr6es... fine over 20psi boost,
Yes i moved to the darkside |
23rd Nov, 2012 at 09:48:02pm
also, try some denso's or champions in there,
23rd Nov, 2012 at 09:51:03pm
Ill get some bpr6es tomorrow and see how it goes ill look at champions after that
614 Posts Member #: 2153 Post Whore kings langley |
23rd Nov, 2012 at 10:17:19pm
what gaps are you running on the plugs? Speeding is like masturbating, everyone does it, but not all of us film it and put it on the internet
23rd Nov, 2012 at 10:36:58pm
We had similar problems early on with the tt. It was all sorted when the fueling was sorted. Going too rich can kill plugs, no matter who makes them. http://www.twin-turbo.co.uk
23rd Nov, 2012 at 11:04:28pm
There very black and nothings visually wring with them, not at home so will get a pic tomorrow morn If they are very black, then there is absolutely something visually wrong....they're very black ! And as others have said, you are risking causing lots of damaged to your engine by running very rich. You should never be running richer than 10.0:1, even more so when your gauge doesnt read there. For all you know it could be 6:1, 7:1 etc But even richer than 10:1 can and will cause bore and piston/ring problems. And if it's damaging plugs, it could be even richer than that. Plugs do not like being soaked in fuel. Something is very badly wrong. 9.85 @ 145mph
24th Nov, 2012 at 09:40:05am
Craig you puff, you've put unknown used plugs in and they have died. Hardly surprising. Stop being a tight arse student and put some new ones in! On 11th Feb, 2015 robert said:
24th Nov, 2012 at 10:39:28am
Craigh can you post a pic of your megajolt map for us?
24th Nov, 2012 at 11:18:02am
Craig i can meet you and get them with my trade card if you want Crystal Sound Audio said:
24th Nov, 2012 at 04:08:18pm
I already got some :( was 2.20 each, thanks anyway wolfie would be good to meet up at some point anyway :)
Edited by Craigie-B on 24th Nov, 2012. On 10th Mar, 2012 theoneeyedlizard said:
24th Nov, 2012 at 04:12:22pm
cheap chinese knock off plugs may be part of the issue,
24th Nov, 2012 at 04:39:18pm
yeah, it doesnt run at 11.1 for long its mainly in 12 and 13
24th Nov, 2012 at 07:06:23pm
Even 12/13 during normal off boost driving is quite rich. You should be looking to see high 13's at least for normal driving.
