Home > Help Needed / General Tech Chat > So, what's my rev limit?
Where should I set the rev limit on my new 998?
The key elements:
Hypatechs:
MED ground, lightened, nitrided and balanced crank:
MED lightened, shot peened and balanced rods, ARP bolts:
Is 8k realistic?
weight of the hypatecs paul?
No less than 7k
No more than 13k
207g for the pistons and 52g for the pins.
What cam !!
rick
On 9th Dec, 2012 cossierick said:
What cam !!
Custom ground, high LSA with a bit of scatter :)
Well I'm intrested to know. Hopefully I'm going to aim for 7k without the rods being worked...
High LSA........... 7k
8K then.lol
Rick
In the grand scheme of things it is not just the cam but the head efficiency too.
The bottom end componets should easilly take 8k rpm. The life span ultimately depends on the end use. If its a road engine with the occassional track day, then I see no issue, but if its a track car or all out race car, the pistons might be the weak point. Having said that The twins seem to do well with the pistons they run.
Edited by Sprocket on 9th Dec, 2012.
I've compensated for that elsewhere :)
Breathing is not an issue according to the model. Just need to have confidence in letting it rev.
Use a crank damper and get the bearing clearancies as tight as you can get to bottom limit. That might be a problem as the crank has already been ground, and probibly to a generic spec of "it'll do"??...
Ben H
Member #: 184
Melton Mowbray, Pie Country
Well my old 998 (+20) regularly saw 8k, with standard bottom end. Eventually it broke the crank after about 30 or 40 thousand miles, plenty of tracks and lots of thrashing around. I just popped a new crank in and its still going. Although now I have detuned it a little going from a 276 cam to an SW5.
I doubt that what you have there, Paul, will be much of a limiting factor.
http://www.twin-turbo.co.uk
Engine has damper:
Crank was prepared the same as used by Mini Sevens and checked with plasti-gauge on build. I'm sure MED do not use an "it'll do" attitude for race engine components.
Ben H, Thanks, that's what I needed to hear.
Edited by Paul S on 10th Dec, 2012.
It all depends on the pistons I'd say. The rest should manage 8000easy as per Se7ens.
Paul what did you paint the engine with?
Edited by gr4h4m on 10th Dec, 2012.
Matt black Hermetite Engine Laquer - good for heat transfer and another 100rpm :)
Turbo This..
Member #: 9165
Previously josh4444
Australia, brisbane
dumb question the Hypatechs are the drilled ones?
Yep, drilled, not slotted.
cool I was reading Des Hamils book who was stating not to use high temp paint, so I will looking for some of thsi stuff. Will have a look in the local Halfords.
I fancy a black engine this time the green is a pain to keep clean...
TurboTom
Member #: 7936
DK-8450 Hammel. Denmark
Come on Paul. *smiley* *smiley*
This shoud be in the "show us yours" section. You know very well where to set the rev limit. You have given this a lot off thoughts, before you started the build.
But nice of you to show us *smiley* Looking forward to see the dyno result
If i have more toys than you when i die, I WIN
You say that, then why did the 'race' crank I bought from MED, a 1275 bladed, wedged, blanced and nitrided crank, not in balance and had 0.003" bearing clearancies on every journal with a fresh set of VP2 bearings? Maybe the guy at the machine shop had on off day?
Do your rods have balancing marks? *wink*
I just thought that it was worth a separate discusion.
I set out with a rev limit of 7500rpm as stated in the OP:
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=383285
However, I've been updating the model with "as built" data and now find that the peak torque has gone up to around 6k and the power curve is still climbing at 7.5k so might as well increase the limit.
