| Home > Help Needed / General Tech Chat > 2.76 / 2.95 diff for motorway usage -whos got one? | |||||||
1170 Posts Member #: 8636 Post Whore Surrey |
6th Mar, 2013 at 04:52:42pm
building up my turbo motor/ mini and its going great!
Edited by WRLondon on 6th Mar, 2013. Reading up on RTS Clutches On 21st Sep, 2006 Paul S said: Go on, be brave, put it in the car and tell us how it works. Pity your bollocks are in line with the flywheel! On 27th May, 2013 robert said:
putting my testicles on the line for turbo mini owners everywhere ,and they still work ! |
6th Mar, 2013 at 05:04:06pm
i have a 2.95 in mine and it was only a dog to get moving due to the low CR and lack of torque (inc SCCR box) however it wasnt much of a problem, except for on hills. |
6th Mar, 2013 at 05:13:35pm
well say im doing 1200 miles over the space of a week
6th Mar, 2013 at 05:15:44pm
guess the obvious question is do i want to be cruising in 4th at 75 say
![]() 263 Posts Member #: 8923 Senior Member North Wales |
6th Mar, 2013 at 05:48:22pm
will the facet pump be up to turbo? |
6th Mar, 2013 at 05:57:42pm
On 6th Mar, 2013 WRLondon said:
well say im doing 1200 miles over the space of a week what do you think would be the best compromise A modern turbo diesel.
6th Mar, 2013 at 05:58:58pm
yeah
6th Mar, 2013 at 06:26:17pm
i would definately run the 2.75 for long distance cruising .
6th Mar, 2013 at 06:54:45pm
I run a 2.95 and its great. Gd off the line and itle cruse at 90 all day long 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
104 Posts Member #: 10210 Advanced Member Durban, South Africa |
6th Mar, 2013 at 07:04:33pm
I'm running a modified 1293 hi comp NA motor with a 3.1 on 12's, awesome for blasting around town as well as along country roads and fairly decent on the open road too. I've tried both the 2.76 & 2.95 diff on this same motor and only really noticed a change in top end, pull away was painstakingly slow on both but once rolling a lovely drive.
Edited by Miniac on 6th Mar, 2013. Life is always a matter of opinion and quite frankly, no ones opinion really matters. |
6th Mar, 2013 at 07:26:18pm
i drove to germany and back with my 2.95:1 and it got 40mpg. i was cruising at 60mph and had 5psi of boost as this was my running in period |
6th Mar, 2013 at 07:40:31pm
mostly weekend warrior tbh
6th Mar, 2013 at 07:41:38pm
ooo not too bad then mpg there mate
6th Mar, 2013 at 07:43:59pm
i think you should stick with the 2.95
6th Mar, 2013 at 08:27:32pm
looks like the way forward
![]() 1137 Posts Member #: 1450 Post Whore Near Paris - France |
6th Mar, 2013 at 08:27:47pm
pardon the thread hijack :
Rusty by nature
They said "That sounds rough mate." I said "Cheers it cost me a fortune to make it sound like that!" |
6th Mar, 2013 at 08:33:08pm
same stuff
6th Mar, 2013 at 10:08:40pm
are 3.4 fine for cursing? I wanna know cause may do a few trips too Ace Cafe & maybe few far shows
6th Mar, 2013 at 10:10:25pm
On 6th Mar, 2013 Chalkie said:
are 3.4 fine for cursing? I wanna know cause may do a few trips too Ace Cafe & maybe few far shows From northamptonshire sorry jacking Cruising I assume you mean. Not really. 80 is not much short of 5k rpm so pretty loud. A mate described a long run in my car as like being kicked down a hill in an oil drum! Edited by minimole23 on 6th Mar, 2013. On 7th Oct, 2010 5haneJ said:
6th Mar, 2013 at 10:31:08pm
higher the number the better for acceleration and slower top speed and worse mpg
7th Mar, 2013 at 08:10:58am
I have a 2.9 in a 998 turbo. Used daily in city traffic and fast A roads, perfect for everything.
7th Mar, 2013 at 12:17:52pm
cool
7th Mar, 2013 at 01:33:16pm
4th gear is direct drive through the main shaft, hence its 1:1 and cannot be changed.
7th Mar, 2013 at 01:42:21pm
ahh ok, how do they do it on the 5 speed boxes? Reading up on RTS Clutches On 21st Sep, 2006 Paul S said: Go on, be brave, put it in the car and tell us how it works. Pity your bollocks are in line with the flywheel! On 27th May, 2013 robert said:
7th Mar, 2013 at 01:47:58pm
With an overdrive. however some 5 speed boxes have a direct drive 5th and a different spread of ratio's If something is worth doing, it's worth doing half of. |
haha
