Home > Beginners Tech > Engine issue (possibly fuel related)
stephen112
Member #: 10490
The Isle of Wight
After picking up the new 1380 turbo that I was lucky enough to be given, after a small tweak with the leaky fuel pump (now working) it fired, momentarily then died. Left it for a few minutes, ran up the the pump again for a few seconds and gave it another go, fired then gave up again.
Reckon anyone could shed some light on the vague possibilities of what this might be? Fairly sure it's fuel delivery related but i'm new to the whole turbo and hif scene as the other minis are standard with HS4s.
Thanks,
Stephen.
1980 Austin Mini City - Avonbar 1380 T3 Turbo
1989 Rover Mini City E - 998
1964 Austin Mini Mk1 - 998
wolfie1
Member #: 9575
Nr a shithole (Wolverhampton)
Have u got a fuel pressure guage? If so connect it after the pressure regulator and check the fuel pressure is correct. Check fuel's comin thru properly disconnect fuel line from carb and turn the engine over to see if any fuel is comin thru (put fuel line in empty bottle or container. If nothings coming out that end, disconnect fuel pump from line to check the pump is healthy
What pump and is it running (can you hear it?). Is it fitted the correct way round?
Was it running properly prior to this?
stephen112
Member #: 10490
The Isle of Wight
The fuel is definitely passing through the pump and you can hear it, the car from what i've been told was running. It'll run it just doesn't seem to be getting the volume of fuel. I'll have a root around when i get home from work.
What pump is it?
stephen112
Member #: 10490
The Isle of Wight
I'm not sure what the pump is however I've taken some pictures for you.
Update today: After being left overnight and throughout today, put the key in ran up the pump and had the engine running for about 4-5 seconds before it stopped, then tried again and it ran for about 2 seconds and it progressively got less and less until it was just turning over with no sign of life.
stephen112
Member #: 10490
The Isle of Wight
Edited by stephen112 on 24th Jun, 2013.
Are you sucking through that filter or pushing?
stephen112
Member #: 10490
The Isle of Wight
Pushing, however I'd say the problem is at the front, seen a few cases of this. Could it be overfuelling or not, what sort of symptoms could I expect for either over/under?
stephen112
Member #: 10490
The Isle of Wight
The fuel pump is working, really running out of options. Took the carb off today and gave it a clean, wondering whether it could be overfueling due to the symptoms mentioned earlier. What can cause this, how can we diagnose it properly?
wolfie1
Member #: 9575
check the carbs float level and check how much fuel is coming out of the fuel regulators return tail.
Kean
Member #: 341
aka T2clubby
South Staffs
Have you checked the condition of the plugs? It could be the float valve sticking open and flooding the carb, common problem.
Really you need to check the pressure level.
stephen112
Member #: 10490
The Isle of Wight
The float valve is working correctly, we're wondering if it's an electrical issue related to the pump cutting out when the key is turned to start.
Does anyone know at what key position the pump should cut in and out and the wiring system for the fuel pump on ignition?
since this is a carbed engine, the pump could be switched off for a minute at least on an idling engine without causing any issues
how did you check the float valve?
stephen112
Member #: 10490
The Isle of Wight
Carb was taken off and everything was checked and crap cleaned out. Do you think we may have missed that issue then?
It's so odd because if you leave it over night it'll run for about 5 seconds (less if gas applied) then you leave it for 5 minutes and it'll run for progressively less and less every time you do so.
What ignition are you using? Sounds just like fooked points etc to me.
stephen112
Member #: 10490
The Isle of Wight
I'll investigate when I get home, from the small amount of info I got from the previous owner I don't think there are points.
sounds like it could be massively over fueling and wetting the plugs, and drying out overnight
an easy and fast way to check the float valve is not sticking is taking the piston / damper assembly off and turning the fuel pump on, one of 2 thigs will happen with the pump on either fuel will leak / squirt out the jet or it wont, ( you can also visually chech the hight of the jet, ( it should be a couple mm down at most)
if it doesnt i would then turn up the fuel pressure untill it does then back down untill it doesnt,
if it already does i would turn down the fuel pressure untill it doesnt anymore
its not a recommended method as you still dont know what the fuel pressure is but its often enough to get it started
nala56
Member #: 9661
Sheffield South Yorkshire GB.
Is that filter partly blocked bypass it and see if that helps. Alan
Main Build
Upgrade to Turbo
stephen112
Member #: 10490
The Isle of Wight
Made a bit of progress over the weekend, after fiddling with the fuel regulator we managed to get it started and running. It seems very temperamental, as we currently have no way of tapping into the fuel pressure to tell if we're getting the rec'd 3-4psi it's proving very difficult to actually get anywhere.
It's idling way too high and if you press your foot down it'll rev then immediately dip to <500rpm then build back up to idle again, fuel deprivation? If you adjust the reg even slightly it'll overfuel and you're back to square one again. Bit of a forwards and backwards weekend.
Had the regulator apart and nothing seems out of the ordinary however we've ordered a new diaphragm to see if the problem does lie within.
I know it was suggested to remove the dashpot assembly then bring up the fuel pressure until you can see it flowing through the carb then back it off until you can't? Well no matter how far we backed off the pressure when the pump is running there is always fuel running in, is this normal?
Thanks for all the help so far, at least we've had it running!
Stephen.
WRLondon
Member #: 8636
Surrey
couple of things to keep you busy;
get a longer fuel & return pipes from the carb to your regulator
& tap the fuel pressure in going to the carb making sure youve got the 3-4psi
check whether youve got the right spark plugs
then wind down the tickover with the crosshead screw on the right hand side of the carb
thats what i did when i was having issues with mine
Reading up on RTS Clutches
pandymagic
Member #: 10492
Hi all,
I am working with Stephen on this 1380 Tubo still having problems.
We have now set up fuel pressure, set it to 3.5 psi. It would seem the only way you can get this to run is to wind the pressure right up, nearly as far as it will go (over 6psi when i checked) and then it seems to run. It runs very fast, but for the longest we have found. It actually got upto temp and then when tweaking the lean screw, it died on us. Now cant get it going again?
We have replace the regulator membrane, changed the carb float needle valve, checked all the things you guys have mentioned above. Running out of ideas now. when it runs it seems to run nicely, but fast. (2000rpm)
Please put your thinking caps on, we just want this thing running.
Thanks
Kean
Member #: 341
aka T2clubby
South Staffs
Stephen.
If there is always fuel running in then that is the problem, the needle valve should stop the fuel passing into the engine under pump pressure.
Set the regulator pressure to 3.5/4psi then leave it alone.
Have you set the float level up correctly in the float chamber?
pandymagic
Member #: 10492
Yes, we have set the float height, 1mm down from the centre of the float. As per book.
pandymagic
Member #: 10492
Ok.. Fuel pressure set to 3.5psi all back together, set mixture screw to 2 turns clockwise from level. (checked needle today, its a BDD) switched on and it dies after about 5 seconds again *frown*
