Home > 998cc > Complete noob doing a turbo... Eventually
Craigr91
Member #: 10509
Wigan
A long and slow project from someone without a clue :)
Thinking of trying at a 998 turbo and having no experience at anything to do with an engine other than changing spark plugs I'm relying on you guys for help :)
Been on tmf and I think I've come up with something but still somebits unclear to me.. Here goes :)
So a 1275 +20 thou
Head to suit
pistons to suit
Mg metro camshaft
gt17 turbo
intercooler
mpi tank and fuel pump
metro fuel reg
metro turbo carb
metro turbo inlet manifold
metro plenum chamber
std mini gearbox
with minispares x-pin diff
Orange clutch plate
Megajolt kit
That's its so far ... Advice and missing bits appreciated :)
Many thanks Craig
Edited by Craigr91 on 11th Oct, 2013.
WRLondon
Member #: 8636
Surrey
welcome to tm
heres how Wil did a 998 turbo in 20 hours:
http://www.turbo-mini.com/62147.html
and the rest of the website is full of invaluable info about turbo minis
anything not covered can be found via the search bar
i personally wouldnt rebore the engine or swap out the pistons if it doesnt need it as 998's are strong little engine and can cope with 10psi
(my gf's 998 did 120k before blowing a headgasket and replaced it with a 1275, after looking at it would probably have gone another 50k atleast!)
rest looks good
but will need a sealed carb, plenum chamber
and a mirage manifold if you dont want to cut the bulkhead
or metro turbo manifold with a t2 adapter plate
think thats about it :)
Reading up on RTS Clutches
Craigr91
Member #: 10509
Wigan
I'll get engine out and then get a friend to check the condition, what would I expect power wise from std turbo 998?
Craigr91
Member #: 10509
Wigan
And I totally forgot about the 998 turbo on that site, damn, read n research here I come *wink* thanks
WRLondon
Member #: 8636
Surrey
probably around 80-90 reliably
also quite expensive when you consider a 1275 not being much more £ to do the same spec but get better figures when it comes to your first spec list & get 150+hp
Edited by WRLondon on 20th Jul, 2013.
Craigr91
Member #: 10509
Wigan
May change to a 1275 then if can get one reasonably priced I guess *wink*
Craigr91
Member #: 10509
Wigan
On turbo-mini he's quoting 140bhp max, so nowhere near that then?
WRLondon
Member #: 8636
Surrey
That's for hill-climb competition fully forged monster engines
Can get well over 200hp from an a series but power is nothing without reliability
Especially if it's going in a road car?
Edit:
If it was for a road car I'd personally build what you want to have for a long while as its out of the car
Once you go turbo the want for Moaaarr power is always there haha
Craigr91
Member #: 10509
Wigan
Yeah a road car, so what would you recommend? For a turbo ? Thanks
Craigr91
Member #: 10509
Wigan
That's what I fear, not being enough power in 6-12months time, I found that win motorbikes, power just became normal after few months and needed more power haha
WRLondon
Member #: 8636
Surrey
1275+
1293
Omega cast pistons
T3 cam or phase 2 cam
Modified head / bigger valves
And a t3 turbo or gt17
Good clutch
Straight cut drops & twin pin diff
Run in low boost and if you get bored whack up the boost
That set up should see a reliable 150+ if built & set up well
Craigr91
Member #: 10509
Wigan
Now we're talking, but reckon I should turbo 998 as I've never had a powerful car before? And upgrade all the turbo stuff and build a 1293?
WRLondon
Member #: 8636
Surrey
its not too different you just have to be responsible and not rag it about chasing porsches haha *happy*
there is little to no difference in insurance or cost to build between the two so i'd just go for it
if you can get all the kit in one bundle it'll be alot cheaper too so just keep your eye out
persume you where born in 91 so should be over the
"Check this out babe" stage to an extent
Craigr91
Member #: 10509
Wigan
Haha yeah I'm well over that, I just want a real car now haha *wink* ill keep an eye out for parts now and if funds and the right engine pop up might just go the 1275 route :)
Craigr91
Member #: 10509
Wigan
list of parts to collect :)
So a 998 +20 thou and pocketed to accept 12g940 head
70773 pistons
Mg metro camshaft
gt17 turbo
intercooler
metro fuel reg
metro turbo carb
std mini gearbox
Orange clutch plate
Megajolt kit
If I missed anything let me know and I can add :)
Edited by Craigr91 on 27th Jul, 2013.
get an mg metro cam
Craigr91
Member #: 10509
Wigan
Ah yes, I think I do remember a mg metro cam being mentioned :) thanks
Craigr91
Member #: 10509
Wigan
Seen a 12g940 for sale which but its has 36/29 valves where has standard '940 heads have 33/29, will this head be compatible with my setup?
Thanks
jlay
Member #: 1742
essex
Hiya 12g940's came with two inlet sizes as standard 33mm for lower spec early cars and about 90on and 35mm for mg metro spec engine. For a 998 build i would go for a smaller inlet valve size and ideally a turbo head as the valves are a better grade.
My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901
Ben H
Member #: 184
Melton Mowbray, Pie Country
I would not bother with a turbo head. Just a standard 12G940 will do. With the chambers opened out to lower compression.
I would seriously consider not using a GT17. It looks great as there are 998s out there with them running big power. I am one of them and I would not like to use it on the road. It would be a laugh for a while, but just annoying after a while. Put a T2 or a GT15 on and it will be a better engine. If you really want big power stop pissing around with a 998.
http://www.twin-turbo.co.uk
Craigr91
Member #: 10509
Wigan
I've been told *wink* I will be going 1275 at a alter date possibly, when funds alow and when the insurance finally pay me for my bike, reckon I should just try get a 1275 short block? With big valve head, and a gearbox with a good ratio to suit? And if I do that, still ditch the gt17 turbo?
Yo-Han
Member #: 3228
North of the Netherlands
If you go 1275 then GT17 is perfect.
However with 1275 turbo you will need a box that is in a (very) good condition to cope with the extra power.
Extra power will also mean dropgears need to be looked at; either use straight-cut or MPi ones (have a search).
Dazed and Confused....
Craigr91
Member #: 10509
Wigan
I will do some search, might just go fr this head then, assuming mpi gears are all te same box as any other age a+ engine?
Yo-Han
Member #: 3228
On 31st Jul, 2013 Craigr91 said:
...assuming mpi gears are all te same box as any other age a+ engine?
Nope apparently mpi drops are stronger than others
Chalkie
Member #: 9764
Northamptonshire.
I was under the impression that MPI gear boxes where made of something close to chocolate and cheese gear wise? gather this would include the drop gears?
