| Home > Help Needed / General Tech Chat > Just about to order some pistons are these the right ones | |||||||
![]() 279 Posts Member #: 10230 Senior Member |
13th Oct, 2013 at 08:08:58am
Hi I'm just about to order some pistons for my engine that I'm building. Just want to get your opinions on these and if there the right ones.
13th Oct, 2013 at 08:52:30am
They did me well I was running alot of boost on those (+20s ) make sure you order the correct cc dish for your settup ( id guess at 10cc ?) Yes i moved to the darkside |
13th Oct, 2013 at 08:52:41am
Lots more factors to consider here. Deck height, gasket thickness, boost levels (and efficiency of your charger at this boost) If something is worth doing, it's worth doing half of. |
13th Oct, 2013 at 09:10:23am
Advice I was given was stick to about 8-10psi run a bk450 head gasket with 10cc dish should be about 8.5.1. Does that sound about right ( think that's what they said ) |
13th Oct, 2013 at 09:16:52am
Also going to get arp bolt sets for the caps and head nearly £200 for the bolts though :/ |
13th Oct, 2013 at 10:22:52am
Do tenors bolts. Don't bother with the main caps.
13th Oct, 2013 at 10:48:35am
What are tenors bolts? |
![]() 1425 Posts Member #: 9199 Post Whore Lancashire |
13th Oct, 2013 at 11:00:07am
send us your email and i'll send you the afracing excel calculator.
13th Oct, 2013 at 11:04:52am
Cheers it's clive_beattie@hotmail.com |
13th Oct, 2013 at 01:32:03pm
At a glance 8.5cr does not look right with 26cc chambers unless you run massive deck height
Edited by Brett on 13th Oct, 2013. Yes i moved to the darkside |
13th Oct, 2013 at 01:43:04pm
How can I work it out |
13th Oct, 2013 at 08:04:03pm
Rod bolts! Lol FFS auto correct! If something is worth doing, it's worth doing half of. |
![]() 1751 Posts Member #: 10190 Post Whore belgium |
13th Oct, 2013 at 08:20:11pm
On 13th Oct, 2013 lee.pb said:
send us your email and i'll send you the afracing excel calculator. i've ordered the 10cc
1 this sounds intresting... do you send these to evereone?
2 i am also building a blow trough charger set up running 10 psi but wil keep pressure at 9psi... should be safe i guess you can do anything if you set your mind to it...
13th Oct, 2013 at 08:27:49pm
Based on a 1293cc
On 13th Oct, 2013 Clive1330 said:
How can I work it out What the mind can conceive the mini can achieve
14th Oct, 2013 at 07:03:06am
Thanks for the info |
14th Oct, 2013 at 07:21:04am
On 14th Oct, 2013 Clive1330 said:
Thanks for the info What the mind can conceive the mini can achieve
14th Oct, 2013 at 07:24:29am
Yes I did thanks on my phone at the moment so will check it out on the laptop later. Thanks very much for your help should be ordering the pistons tonight hopefully before the med offer expires |
14th Oct, 2013 at 07:35:04am
Yes I did thanks on my phone at the moment so will check it out on the laptop later. Thanks very much for your help should be ordering the pistons tonight hopefully before the med offer expires What the mind can conceive the mini can achieve
14th Oct, 2013 at 08:24:34am
Think that's what ones I will be going for |
14th Oct, 2013 at 09:20:59am
Think that's what ones I will be going for What the mind can conceive the mini can achieve
14th Oct, 2013 at 11:49:29am
last time I saw the AFracing spreadsheet it had an error in the way it did one of the calcs (I forget which). Hopefully you have a later version LOL On 17th Nov, 2014 Tom Fenton said:
14th Oct, 2013 at 12:50:37pm
no there's a point best check the calculations.
On 14th Oct, 2013 TurboDave16V said:
last time I saw the AFracing spreadsheet it had an error in the way it did one of the calcs (I forget which). Hopefully you have a later version LOL What the mind can conceive the mini can achieve
14th Oct, 2013 at 12:53:15pm
I will be going +40 |
14th Oct, 2013 at 01:31:05pm
larger the bore, higher the compression ratio. I think in vizards book hi has an approximate guide for each bore size, how many cc equate to real time deck height. though you will need to measure your deck height, as there may be variations from factory, or the block may have been skimmed before... |
14th Oct, 2013 at 06:07:04pm
Tried ordering pistons but doesn't recognise code :( |
