| Home > Help Needed / General Tech Chat > Short Stroke k1100 turbo spec and a couple of questions. | |||||||
15th Oct, 2013 at 07:19:25pm
So, having obtained a crank I am now trying to finalise the spec and seeking a little advice.
Edited by minimole23 on 15th Oct, 2013. On 7th Oct, 2010 5haneJ said:
15th Oct, 2013 at 08:30:23pm
To be honest in a mini engine bay it's always a bit of a compromise. I kept mine near enough equal length and just tried to keep the bends and shallow as possible not to restrict flow too much. On the other side, you don't want to make it overly long and start losing too much heat. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
15th Oct, 2013 at 08:48:46pm
carefull with the K1100 head and 9.7k rpm. The max permissable engine speed for the K1100 is 8900rpm, and max continuous speed is 8500rpm
15th Oct, 2013 at 08:52:54pm
Better use my k1200 head then with the lt cams fitted. didn't realise the spring rates were different On 7th Oct, 2010 5haneJ said:
15th Oct, 2013 at 09:26:15pm
On 15th Oct, 2013 minimole23 said:
Better use my k1200 head then with the lt cams fitted. didn't realise the spring rates were different Maybe the springs aren't different, but the valves are
You might be able to reduce the cam LSA increasing the overlap to push the power up the rev range, but ultimately the lower duration will tend to hold it low Edited by Sprocket on 15th Oct, 2013. On 26th Oct, 2004 TurboDave16v said:
15th Oct, 2013 at 09:52:47pm
sounds like an awesome build
15th Oct, 2013 at 10:01:17pm
If I use both rs cams it probably wont wake up till 5k.
15th Oct, 2013 at 10:15:06pm
The K1200 valves are lighter, this is possibly the reason higher RPM's can be used if the springs remain the same.
16th Oct, 2013 at 06:11:59am
You can always shim the springs to increase the range as long as there is room at full lift |
16th Oct, 2013 at 06:27:36pm
On 15th Oct, 2013 Sprocket said:
You might be able to reduce the cam LSA increasing the overlap to push the power up the rev range, but ultimately the lower duration will tend to hold it low Well I will definately use the k1200 head and set the limiter at say 9300, so as to keep the head happy. Lets say I want the engine to pull hard to 9k rpm, as that last few rpm will serve only the soft and hard limiter. Are the LT cams, even with some revised timing likely to be able to deliver this? On 7th Oct, 2010 5haneJ said:
16th Oct, 2013 at 06:39:50pm
What about the gtb2256vnt or what ever it is on the ivecos? Ball bearing and vnt, still big enough for power too. Drives
17th Oct, 2013 at 07:08:59pm
I will keep things simple for the moment. The 2056 should deliver the goods, and If I'm sure there will be some scope to tweek cams, as I have all combinations. Its a light car, so even with the hot cams shouldn't be aweful at low speed.
19th Jan, 2014 at 09:02:01pm
A tip off a crank was going spare resulted in a trip to Brett Sims Motorsport today to pick this up.
19th Jan, 2014 at 09:04:44pm
Just realised this in still in the help needed section. Will start a show us yours thread once progress really gets underway. On 7th Oct, 2010 5haneJ said:
![]() 243 Posts Member #: 1261 Senior Member Droitwich |
21st Jan, 2014 at 10:00:01pm
Just something to consider which I've learned from having an s2000... A turbo will completely change the characteristics of a revy engine.. An s2000 will go to 9000rpm easy, but after a turbo is fitted there's no need to go over 7000, you've got peak boost by something like 3000 with a sensible sized turbo and quite a flat torque curv. So if you hold it in till 9000 rpm you land on the wrong side of the torque curv in the next gear, so it feels like power is dropping off. Basically what I'm trying to say is there's really not much point in doing this with a short stroke crank.. Unless u use a giant turbo maybe, which boosts late, making a million bananas at 9000rpm but needs a push start to get going lol |
![]() 834 Posts Member #: 2017 Post Whore Warwick. |
21st Jan, 2014 at 11:39:19pm
![]() Is it Brett doing your engine for you? He once told me about his 1st venture into building a K headed A-series with supprisingly good results. He should be more than up to building you a screamer. David. |
22nd Jan, 2014 at 07:51:19am
That's interesting. Did you keep the same cam profiles when turboing?
On 21st Jan, 2014 JetBLICK said:
Just something to consider which I've learned from having an s2000... A turbo will completely change the characteristics of a revy engine.. An s2000 will go to 9000rpm easy, but after a turbo is fitted there's no need to go over 7000, you've got peak boost by something like 3000 with a sensible sized turbo and quite a flat torque curv. So if you hold it in till 9000 rpm you land on the wrong side of the torque curv in the next gear, so it feels like power is dropping off. Basically what I'm trying to say is there's really not much point in doing this with a short stroke crank.. Unless u use a giant turbo maybe, which boosts late, making a million bananas at 9000rpm but needs a push start to get going lol Fastest 998 mini in the world? 13.05 1/4 mile 106mph
22nd Jan, 2014 at 08:07:23pm
The Don is one reason I decided to do this engine, great inspiration. For me an 8k rpm engine is not enough. If theres not point revving over 8.5 etc then so be it, but with the right combination of parts 9 shouldn't be a problem. I will start off with the LT cams and change them for RS items if the power band is not sufficient.
614 Posts Member #: 2153 Post Whore kings langley |
22nd Jan, 2014 at 08:25:14pm
doesnt the gt2056 have a really retrictive wastegate? making it spike a bit? i would think you could use a bigger turbo than the gt20 if your using 9000rpm+? my friend ran a gt25 (not sure on the wheel sizes) on a 1.3 8v peugeot rallye engine to 9000 rpm Speeding is like masturbating, everyone does it, but not all of us film it and put it on the internet
22nd Jan, 2014 at 09:02:00pm
Its easy enough to open the wastegate hole out if boost does creep.
23rd Jan, 2014 at 12:59:47am
Generally speaking at that stage yea, they use the same cams. I was after I was taken out in one that I learned all this.. I wanted to turbo mine so I arranged to speak to a guy that had done it and go for a drive. If power is the only concern then like u say a bigger turbo would make use of the engines abilities.. It was suggested to me that if I wanted to retain the character but just have more power then a supercharger would be better.
On 22nd Jan, 2014 wil_h said:
That's interesting. Did you keep the same cam profiles when turboing? It also sounds like your turbo is a little small, becoming a restriction after 7k. Like any engine, turbo engines have a power band, on NA engines this is usually defined by the cam profile. The cam profile is still relevant in a turbo engine, but the turbo spec is what really counts. To make the most of the S2000 engine I'd be looking at a turbo to make the most of the rpm available (at the expense of lower down power). you'll make 30% more power lb for lb at 9k compared to 7k. It seems you went the sensible route, rather than the power route. Having driven the don, I can confirm that high revving 16v turbo engines work very well! On 21st Jan, 2014 JetBLICK said: Just something to consider which I've learned from having an s2000... A turbo will completely change the characteristics of a revy engine.. An s2000 will go to 9000rpm easy, but after a turbo is fitted there's no need to go over 7000, you've got peak boost by something like 3000 with a sensible sized turbo and quite a flat torque curv. So if you hold it in till 9000 rpm you land on the wrong side of the torque curv in the next gear, so it feels like power is dropping off. Basically what I'm trying to say is there's really not much point in doing this with a short stroke crank.. Unless u use a giant turbo maybe, which boosts late, making a million bananas at 9000rpm but needs a push start to get going lol |
3rd Apr, 2015 at 08:08:26am
I've been having some second thoughts about this now, especially having trawled through some of the rolling road graphs. I idea of 9k or 10k is long gone as an aspiration. Getting power still climbing at 7k seems to be more of a consideration.
307 Posts Member #: 11231 Senior Member |
2nd Jan, 2017 at 12:47:46pm
Hi guys, first of all Happy New Year.
2nd Jan, 2017 at 03:04:07pm
you need a set of 6" rods basically, the easiest solution is get a set from SC as they had some made for the SA cranks, ( presume they still have some)
2nd Jan, 2017 at 05:04:48pm
Hmm... do you guys think it would become much more expensive to build a short stroke k1100 engine rather than a standard 1275cc k1100 engine ?
