Home > General Chat > engine failure
phillips934079
Member #: 10703
newcastle
hi I was just wondering how many or you hav experienced a catastrophic engine failure. heres one of mine. feel free to add your own pics.
phill
Edited by phillips934079 on 16th Jan, 2014.
Or some precision brutality
Good effort.
phillips934079
Member #: 10703
newcastle
that's why you don't weld pistons this happened after around 200 miles after it was built
weld pistons??
Say what?
phillips934079
Member #: 10703
newcastle
haha yip a sill idea from my brother (hes a coded tig welder) thy worked for a short time
who welded what?
good effort btw!!
Edited by Brett on 16th Jan, 2014.
phillips934079
Member #: 10703
newcastle
welding pistons is just as mad as welding crankshafts and people do that all the time
wng691s clubby
Member #: 9252
Cleethorpes
nicely done
Done now needs redoing lol
If he's a coded welder he should of known better. Lol
I've heard of cam shafts being welded successfully before though.
Now that's a big hole!
Why did the piston 'need' to be welded in the first place?
phillips934079
Member #: 10703
newcastle
yes the piston had a hole in it in the beginning. welded it up then machined it flat. also these are bmw pistons not mini pistons
also please note all 4 pistons are welded
welshdan
Member #: 1111
s wales
What pistons are they? Got any more details?
phillips934079
Member #: 10703
newcastle
now that would be telling
Which is the general response to an inquisitive question.
phillips934079
Member #: 10703
newcastle
thy are bmw k100 pistons they are perfect in a 998 or 850 as they don't need skimming but a was running them in a 1098 so thy required skimming
phillips934079
Member #: 10703
newcastle
in a 850 they give you 963cc
998=1075cc
1098=1181cc
jonny f
Member #: 9894
Dorking
998=1075cc
1098=1181cc
I'm confused.
So you bored it out to fit them?
Where did the "welding" happen? Why?
phillips934079
Member #: 10703
newcastle
yes offset bored to 67mm
phillips934079
Member #: 10703
newcastle
I machined the piston crowns to a could use them with a 1098 crank built the engine up and ran it did 396 miles then put a 10 mm hole in one of the pistons so I pulled the engine out striped it my brother welded the hole up and built the inside of the crowns up on all the pistons with weld re assembled it thn a did about 200 miles and fucked up as u see now
steve w
Member #: 1917
AKA chargedzetec
So this isn't an 'engine failure' it's a 'brain failure'????
theres your answer! above ........... plus a shade of deonation and too much CR maybe and trying too much!*frown*
Something must have been wrong in the first place to have gotten a hole in one of the pistons surely?
