| Home > Help Needed / General Tech Chat > fly wheel stuck on | |||||||
87 Posts Member #: 10248 Advanced Member Hertfordshire |
21st Apr, 2014 at 09:38:40pm
Hi guys
![]() 644 Posts Member #: 9371 Post Whore East Yorkshire |
21st Apr, 2014 at 09:46:59pm
Try not to put silly amounts of pressure on, I broke mine this week doing that. You can either leave it overnight and tap it with a hammer. Or what worked for me was slacken it off and re do the whole procedure. After my puller broke i got another one, as soon as it went on he flywheel came off easy. BHP sells engines, but Torque wins races! |
21st Apr, 2014 at 09:47:54pm
Heat heat heat heat. Did I mention heat? On 13th Jul, 2012 Ben H said:
21st Apr, 2014 at 10:01:19pm
make sure the puller is dead square with the flywheel. The cast pullers are not always that well made.
22nd Apr, 2014 at 06:47:45am
Minispares flywheel puller, heat and an impact driver doing up the puller, helps to shock the flywheel off. On 26th Jan, 2012 Tom Fenton said:
22nd Apr, 2014 at 09:07:29am
madonminis have redoen the procedure 8 or nine times now and it is still stuck and have soaked in wd 40 for a couple of days and still nothing
510 Posts Member #: 1592 Smart Guy! mainland europe near ze germans |
22nd Apr, 2014 at 09:49:08am
I think it is time to apply serious heat.. get a bigger (or two or three) torch (es) so you can heat the flywheel up quicker without it soaking out to the rest. It needs to be ridiculously hot as fast as possible .
Edited by Sir Yun on 22nd Apr, 2014. That sir, is not rust, it is the progressive mass reduction system
22nd Apr, 2014 at 10:49:07am
no one has said it yet, as its an obvious mistake, so I will......
22nd Apr, 2014 at 11:27:16am
There is also a technique using a ring of weld. Not done it myself so can't comment. Found it on another popular mini forum last week though. BHP sells engines, but Torque wins races! |
22nd Apr, 2014 at 11:50:36am
does it look like the flywheel has ever been off?
On 22nd Apr, 2014 Sprocket said:
no one has said it yet, as its an obvious mistake, so I will...... you have removed the key washer from the end of the crank? was going to say it! |
22nd Apr, 2014 at 12:22:30pm
Once you have it wound up with the impact gun and lots of heat, get someone to stand on the engine on it's side (if it's out) and then get a long breaker bar and just keep applying pressure to the puller, with lots of heat. Have had to do this before with a mates 998, no matter what he tried nothing would budge it. In the end getting two people pinning the engine down and one person cranking round a breaker bar finally got it off. Brute force won in the end, but make sure that keyway washer is off as colin said, as otherwise it will never ever come off. (I've had an engine before with a domed key washer, god knows how much force was put into that before they realised what they did.) On 26th Jan, 2012 Tom Fenton said:
174 Posts Member #: 9128 Advanced Member |
22nd Apr, 2014 at 01:50:38pm
Find someone with a sykes pickervant hydraulic puller, no flywheel has ever defeated mine. |
22nd Apr, 2014 at 05:01:05pm
yes teh lock key washer is out no it doesnt seem to ever have been off
22nd Apr, 2014 at 06:23:11pm
On 22nd Apr, 2014 DILLIGAF said:
Find someone with a sykes pickervant hydraulic puller, no flywheel has ever defeated mine. Someone at bingley was making a new version of the hydraulic puller. About £100 can't remember who? Sprocket might remember I run a supercharger and I don't care the TB is on the wrong side.
22nd Apr, 2014 at 06:47:24pm
http://www.kentautodevelopments.com/shop/p...flywheel-puller On 13th Jul, 2012 Ben H said:
22nd Apr, 2014 at 06:59:43pm
Is the engine out of the car?
22nd Apr, 2014 at 08:08:47pm
Find someone with a sykes pickervant hydraulic puller, no flywheel has ever defeated mine. Someone at bingley was making a new version of the hydraulic puller. About £100 can't remember who? Sprocket might remember I'm pretty sure it was Guessworks. On 26th Oct, 2004 TurboDave16v said:
22nd Apr, 2014 at 08:14:59pm
Also, some flywheels were never destined to come off as they have completely welded themselves to the crank. When they do eventually part in one way or the other, huge chunks of metal have been exchanged between the two parts.
![]() 324 Posts Member #: 9441 Senior Member South Devon |
22nd Apr, 2014 at 08:35:36pm
This is what remains of the last flywheel I removed. After multiple attempts to heat it, pull it and hit it it was going no where so it had to sacrificed.
22nd Apr, 2014 at 08:35:48pm
This shows how far they can jump
22nd Apr, 2014 at 09:22:16pm
I bought a short engine from a bloke that had taken the cut off saw and cut through the tail of the crank behind the flywheel and everything else in its path. The block still has the remains of the studs in their holes. I weighed the crank in. A bit drastic if you ask me. It was the tool they had, it was the tool they used. Edited by Sprocket on 22nd Apr, 2014. On 26th Oct, 2004 TurboDave16v said:
22nd Apr, 2014 at 11:25:40pm
This is the set you want Edited by DILLIGAF on 22nd Apr, 2014. |
13 Posts Member #: 10774 Member seaford australia |
23rd Apr, 2014 at 10:27:35am
Leave the flywheel bolt in and turn it 1& 1/2 turns out so the flywheel doesn't break your legs. you can also give the flywheel a good hit with a heavy mallet through the starter hole with tension still on the puller. rotate it to a few different spots to hit. be careful not to break the transfer case. Have seen them welded on though!! Good luck. Ben |
24th Apr, 2014 at 11:49:39am
cheers guys i have will ahve a go when i get a chance but i think i have done pretty much everything u have suggested apart from put a lot of heat into it
24th Apr, 2014 at 03:02:37pm
On 24th Apr, 2014 MattyC113 said:
cheers guys i have will ahve a go when i get a chance but i think i have done pretty much everything u have suggested apart from put a lot of heat into it so will have a go at the weekend btw sprocket i have had me my dad and my brother with an of cut of scaffold tube with a breaker bar on the main puller bolt all tightning it up so i doubt the reason it aint coming of is coz we are being pussys with it :) nothing to add really without repeating all the above, ive had 1 do this to me and the end result was crank and flywheel centre in the bin and on another engine for a rather famous upside down skip, i managed to twist and snap the big centre bolt in the puller, got the flywheel off though
Yes i moved to the darkside |
