| Home > Show Us Yours! > Mayfair rebuild - K1100 Turbo | |||||||
Forum Mod ![]() 1927 Posts Member #: 1761 Stalker Bristol |
4th Jun, 2014 at 12:26:31pm
Thought it was about time I started a build diary for this, as the plans have changed a couple of times since I decided to take the mini off the road, but now they are set Edited by Carl S on 17th Jun, 2014. |
4th Jun, 2014 at 01:01:27pm
Look forward to seeing this progress!
In the 13's at last!.. Just |
4th Jun, 2014 at 01:20:01pm
sounds like a serious engine. I run a supercharger and I don't care the TB is on the wrong side.
4th Jun, 2014 at 03:35:17pm
shell doesn't look too bad |
![]() 1751 Posts Member #: 10190 Post Whore belgium |
4th Jun, 2014 at 04:14:15pm
Is that a metal nurse you use to lift the engine? I have one in the garage but no battery to make it lift. you can do anything if you set your mind to it...
4th Jun, 2014 at 04:29:53pm
I think it's just a hoist used for lifting disabled people, so probably similar to what you describe. It has a pump handle for the hydraulic ram. It's borrowed from Nick on here |
11 Posts Member #: 10858 Member |
4th Jun, 2014 at 07:29:35pm
hi i am just wondering which td04 you are going to use for your project ? |
5th Jun, 2014 at 07:03:16am
It's from a Mk1 Impreza IIRC. The flanges on it are a nightmare though! The hot outlet almost touches the hot inlet so I'm hoping to come across an aftermarket set of manifolds I can modify.
5th Jun, 2014 at 06:34:23pm
Is it finished yet? On 11th Feb, 2015 robert said:
1713 Posts Member #: 8480 MS Paint flat cap champion & Morris Ital Lover From Sheffield now live in York tha noz |
5th Jun, 2014 at 09:58:15pm
Sounds like an interesting project
I am feeling particularly BACish today. On 5th Oct, 2014 Shauna said:
What that's crazy, you go commando hahaha! How heavy is your helmet ? The Morris Ital assassin! |
5th Jun, 2014 at 11:02:23pm
yep i will be following this one !
6th Jun, 2014 at 05:59:24am
Cheers guys.
10th Jun, 2014 at 06:57:00am
Not quite what I expected to happen after being moved in for only a few weeks, but I guess it could happen to anyone... the garage flooded yesterday morning when we had some torrential rain.
10th Jun, 2014 at 07:44:11am
Unlucky mate :( On 26th Jan, 2012 Tom Fenton said:
10th Jun, 2014 at 10:12:25am
Ahhh no way mate Yes i moved to the darkside |
10th Jun, 2014 at 10:25:22am
sounds good, although your target will be smashed with that spec, I think you should see 280 with that spec On 15th May, 2009 TurboDave said:
10th Jun, 2014 at 11:13:41am
Blimey, 280 would be immense! Sounds a little out of reach for the TD04 though.
10th Jun, 2014 at 11:28:27am
iirc matty was running 9.1:1 cr on his! Drives
10th Jun, 2014 at 12:19:50pm
Bad luck with the flood mate - these things are ment to test us I'm sure!
10th Jun, 2014 at 12:28:46pm
Cheers Mark |
10th Jun, 2014 at 05:32:27pm
flanges for the scooby turbo are all over ebay. was going to use that turbo on mine. On 7th Oct, 2010 5haneJ said:
10th Jun, 2014 at 06:01:39pm
Yep I managed to run 30psi with a 9:1 cr, the head gasket has started munching its way into the head though. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
11th Jun, 2014 at 07:08:23am
Blimey, that is good news then, means I need less meat out of the pistons and can run the deck height much less than originally planned.
11th Jun, 2014 at 09:34:28am
high boost and cr is a matter of keeping hot spots under control and charge temps down as well as good spark and fuel of course |
17th Jun, 2014 at 12:06:45pm
A bit more progress at the weekend and last night. Got the front end taken off in readiness for a removable fibre glass front. I'm pretty sure I wont be putting a removable steel front on due to the weight saving a fibreglass one gives, but have been back and forth over the idea for a while.
(he says) Hopefully keeping this thread up to date with goings-ons will enable me to get it finished!
