| Home > Help Needed / General Tech Chat > turbos | |||||||
269 Posts Member #: 396 Senior Member sheffield/rotherham |
6th Aug, 2005 at 04:57:31pm
hi, im looking at buying the turbo for my mini at mo as i have alot of other parts, speed is the best rush i have ever had!!!
6th Aug, 2005 at 05:22:36pm
A T2 will deliver all the boost and more that your a series will require |
6th Aug, 2005 at 06:26:51pm
ive seen them boosting to around 25psi mate, but sum1 told me a t2 could not handle that inda of boost is that true? speed is the best rush i have ever had!!!
6th Aug, 2005 at 06:50:41pm
A R5 T2 will boost to 25psi, whether it's efficient at that kind of boost, i doubt it !
6th Aug, 2005 at 07:01:21pm
what would you say its most efficient at phil? speed is the best rush i have ever had!!!
6th Aug, 2005 at 07:18:31pm
I would have thought up to 20psi maybe, after this all you'll probably do is create a lot of extra heat and no real power gain.
6th Aug, 2005 at 07:29:23pm
i think they r swaping to t25's mate the 1's who are running higher boost. speed is the best rush i have ever had!!!
195 Posts Member #: 26 Advanced Member Cannock |
8th Aug, 2005 at 12:57:10pm
From what I have read on other places on the net a standard R5 T2 begins to suffer from diminishing returns from about 17 psi onwards. This sort of ties into what Iain and Phil has mentioned.
8th Aug, 2005 at 02:24:09pm
17 psi on a T2 and the temps rocket up!
AlexF |
8th Aug, 2005 at 02:30:50pm
On 08/08/2005 14:24:09 AlexF2003 said:
17 psi on a T2 and the temps rocket up! Yes they will run to 25psi... but they will be moving less air than a T3 at 20 psi!! Pressure is not air flow remember! If your running 20+psi on a t2... think t25 or t3. Alex Surley a t2 turbo, on a 1293 engine, at 6000 rpm at 20 psi would deliver the same amount of air as a t3, t4, or t5. If it could not supply enough air, then it would not give 20psi? I'm nto saying it's going to be as effiecent, but if it's deliverying the same boost, then its got to be the same amount of air. On 15th May, 2009 TurboDave said:
8th Aug, 2005 at 03:29:02pm
I agree with you Jim.
8th Aug, 2005 at 03:51:29pm
I knew this would be a fun thread!
AlexF |
8th Aug, 2005 at 03:58:59pm
WTF!!!
8th Aug, 2005 at 04:07:06pm
well I'm no expert not even got my L plates, were's fab when you need him! On 15th May, 2009 TurboDave said:
8th Aug, 2005 at 04:16:57pm
Can you guys read compressor maps?
AlexF |
8th Aug, 2005 at 04:27:00pm
I don't use maps anymore, I've got GPS On 15th May, 2009 TurboDave said:
8th Aug, 2005 at 04:30:33pm
Hang on now i've thought about it a bit....
8th Aug, 2005 at 04:31:04pm
A T3 produces far more VOLUME of air at a given pressure from its HOUSING than a T2....
AlexF |
8th Aug, 2005 at 04:36:43pm
close mini13..
AlexF |
8th Aug, 2005 at 04:36:56pm
I get it that the t3 will produce more flow at 15 psi than a t2 at 15psi, but if they're blowing up identical balloons (say a 1293) then surely this becomes the limiting factor meaning 15psi will always be x amount of flow no matter what is blowing because the 1293 balloon doesn't change?
8th Aug, 2005 at 04:40:43pm
again another good point Mini13 (I can't keep calling you that, whats your real name?!).
AlexF |
8th Aug, 2005 at 04:56:01pm
So what's this got to do with turbo sizing
AlexF |
8th Aug, 2005 at 04:56:28pm
Yep, the penny's dropped, or at least dropping!
![]() 52 Posts Member #: 593 Advanced Member woking, surrey |
8th Aug, 2005 at 05:36:33pm
wow in one thread i have learnt so much, thanx alex for being bored at work era turbo - not even the mrs gets to drive it |
8th Aug, 2005 at 07:24:31pm
Great info - but admittedly from someone who is biased towards a T3, and also never having driven a T2 mini... Edited by turbodave16v on 8th Aug, 2005. On 17th Nov, 2014 Tom Fenton said:
just look at what the R5 lads boost to!
