| Home > Help Needed / General Tech Chat > Head Gasket failure... | |||||||
17th Sep, 2014 at 11:54:11pm
Hi all after some help. I'm pulling my hair out as to the head gasket failing into the water way.
18th Sep, 2014 at 08:07:56am
Interesting, i have been thinking ahout using a decomp plate on my budget 998ti, very interesting that ist lasted so long,
Yes i moved to the darkside |
18th Sep, 2014 at 09:08:21am
you can 11 sud the small bores
![]() 580 Posts Member #: 9580 Post Whore Surrey |
18th Sep, 2014 at 09:20:18am
I had a solid copper plate made to get rid of the de-comp and gaskets. I used a sealant for belt and braces approach as well but that held up on a 1293 up to 150bhp. |
18th Sep, 2014 at 09:45:18am
This is running a supercharger and injection, right?
18th Sep, 2014 at 12:03:41pm
Paul I was thinking the same thing. I'm changing the exhaust manifold to put the wideband in the pipe for the outers. I will get some pics of the head up.
18th Sep, 2014 at 12:48:43pm
No more meat to come out of the head, or a different head?
18th Sep, 2014 at 12:58:44pm
Our very own turbo Phil said there wasn't much more to come out as it had been skimmed in a previous life.
18th Sep, 2014 at 01:23:13pm
I might be tempted to bung up those big coolant holes close to the chambers on 1 and 4 and between 2/3 and run a commetic MLS big bore gasket On 26th Oct, 2004 TurboDave16v said:
18th Sep, 2014 at 04:56:38pm
I run a home made mls with blue hylomar on it in the bike .never blown.
18th Sep, 2014 at 06:06:21pm
So you're using soft copper as a spacer between two even softer head gaskets ?
18th Sep, 2014 at 06:19:44pm
Robert is suck throughout so no ic
18th Sep, 2014 at 06:32:48pm
ahh i thought with the inj on it you could ic it by popping the charger on the front of the block . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
18th Sep, 2014 at 06:41:41pm
It is running water meth 50/50 injection at just user 5 psi.
18th Sep, 2014 at 08:27:28pm
Either an un skimmed 295 or use a 940 head on it?
18th Sep, 2014 at 08:54:14pm
Would a Dry deck work?
19th Sep, 2014 at 08:20:25am
On 18th Sep, 2014 gr4h4m said:
Robert is suck throughout so no ic Steviet I have the copper plate which is a cometic gasket? And then and head gasket ontop. It was sealed with blue Hylomar spray on the block side. It may be a gasket...but you wouldnt normally use 3 gaskets and expect it to hold either ? Perhaps if the middle spacer was a steel MLS gasket you could get away with it. Copper...Ive never even had any success using them as a gasket, nevermind with 2 other gaskets. What is your CR with the thickest single gasket you can find ? For a low boost setup...water/meth....I'm sure you could be using a fairly high CR with no difficulties. 9.85 @ 145mph
19th Sep, 2014 at 08:58:07am
I ran 2 bk450's for a while up to 12 psi , never blew , also my friend john is still running 2 450's at up to 10 psi , been fine .
19th Sep, 2014 at 09:06:05am
Just for clarity, you can't put a large bore gasket on with a small bore head (well not without blocking up lots of the head's waterways). Fastest 998 mini in the world? 13.05 1/4 mile 106mph
19th Sep, 2014 at 09:24:21am
Possibly pre-ignition rather than detonation. The problem seems to come from the area where the combustion chamber overlaps the bore. Have you got a nice chamfer to the bore edge in that area? Any hot spot could cause pre-ignition.
19th Sep, 2014 at 09:24:48am
ah thanks wil I wasn't sure .
19th Sep, 2014 at 08:26:16pm
Blimey thanks all,
19th Sep, 2014 at 10:52:17pm
heres a pic of the head. the bright flakes you can see in the picture are from the minispares payen head gasket its seemed to have some kind of sealant on it., it was nothing I put on.
20th Sep, 2014 at 06:21:50am
ah fair enough graham, got my which side of the gaket was 'up' mixed up lol.
20th Sep, 2014 at 08:44:42am
Based on the picture of the head, I would say that your fuel distribution is OK, perhaps a little rich.
